Ribbon: Topoplan – Geopoints > Create Groups of Geopoints Manually
Menu: Topoplan – Geopoints > Create Groups of Geopoints Manually
Toolbar: Geopoints > Create Groups of Geopoints Manually
Command line: C3D_CREATE_COGO_POINT_GROUP
Manual creation of a group of geopoints with a name, description, styles, and a prefix of the raw description of the geopoint, which is a criterion for adding points to the group.
The command options are set in the Properties bar:
- Name;
- Description;
- Marker Style (of those existing in the drawing);
- Override Marker Style;
- Label Style (of those existing in the drawing);
- Override Label Style;
- Add with Raw Description prefix – the criterion for adding a point to the group. Allows you to add to the group only points with the specified raw description.
Change parameters in ‘Properties’ window and choose ‘OK’ to create Point Group or ‘Cancel’ to discard any changes <ОK> or [OK/Cancel]: | Yes – a group of geopoints will be created with the current settings. Cancel – if the settings have been changed, they will not be preserved. A group of geopoints will be created with the settings displayed right after the command starts. |
