Mass Properties
This feature is available only in Pro version of nanoCAD.
Ribbon: Home – Utilities – Inquiry > Mass Properties
Menu: Tools – Inquire > Mass Properties
Command line: MASSPROP
This command calculates mass properties of 3D-solids and regions: volume, area, moment of inertia, center of gravity, etc. Results may be saved into text file.
- Run Mass Properties command.
- Select objects. It’s possible to select several regions if they are collinear to the first one.
- Press ENTER.
Calculated results are displayed in the command line. - Write analysis to a file? [Yes/No]– select Yes to save results into text file. Then specify the path and name of file.
Mass Properties displays different properties depending on selected objects.
Info: NanoCAD is an easy-to-use, cheap, and yet professional, CAD program for PC, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware supports creative, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
