Sheet set property
Call the Sheet Set Properties dialog from context menu of sheet set.
All the three parameters (properties) are distributed among three tabs: Sheet Set, Project Control, Sheet Creation.
Sheet Set tab involves the following general parameters:
- Name – sheet set name;
- Sheet set data file – .dst file name, with path;
- Description – annotation (description) saved with the sheet set;
- Label block for views – name and location of the block to be used as the view label block in the sheet set;
- Callout blocks – name and location of the block to be used as the callout block in the sheet set.
Project Control tab displays parameters associated with the project (number, name, phase, milestone, object, customer).
Sheet Creation tab displays the parameters concerned with the process of new sheets in the sheet set:
- Sheet storage location – folder for the new sheets to be created and added to the sheet set;
- Sheet creation template – name of the template to be applied to the new sheets;
- Prompt for template – indicates (yes or no) whether template name will be requested with every new sheet creation.
Values of the above mentioned properties can be used in the fields included into drawing text entities.
Info: NanoCAD is a simple, affordable, and yet professional, CAD application for Windows, that delivers a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
