Import of KML/KMZ files
Ribbon: Topoplan – Import/Export > KML/KMZ import
Menu: Topoplan – Import/Export > KML/KMZ import
Toolbar: Import/Export > KML/KMZ import
Command line: KMLIMPORT
The command imports from KML/KMZ (Keyhole Markup Language) format with a possibility to recalculate data from/to various topographic and geodetic coordinate systems using EPGS codes.
To import KML/KMZ:
1. Run the command.
2. In the file selection dialog that opens, select a file to import.
3. The EPSG Transformations dialog box appears.
4. In the left part of the dialog box, mark the objects to be imported from the file.
5. In the central and right EPSG text field, enter the number of the source and target coordinate systems according to the EPSG classification, focusing on the list provided. Click Apply.
6. Information on the selected target geocoordinate system will appear in the right part of the dialog box. To confirm the transformation, click ОK.
