Construction note
Ribbon: Home, Annotate – Leaders > Construction note
Menu: Draw – Notes > Construction notes…
Toolbar: Utilities –
Command line: NOTEP
This command opens the Construction note dialog box to set the note options:
Use the icons to select the style of the extension line:
None. | |
Arrow. | |
Point. | |
Open arrow. | |
Half-arrow. | |
Oblique. |
By left edge. | |
By center. | |
By right edge. |
Other icons and options:
The Add extension line icon is used to insert additional extension lines. The icon is enabled when you edit a leader inserted into the drawing. | |
Inclination step of extension line | Drop-down list to select inclination. In the list the following inclinations are available:
To create a construction note:
- Select the required note options.
- Click OK.
- Specify a point on the object to which the leader arrow will be directed.
- Specify the shelf position on the drawing.
Info: NanoCAD is a user friendly, inexpensive, and yet professional, CAD app for Windows, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, if you like it.
