Line by two points
Linear Objects
Ribbon: Home, Draw – Draw > Line Menu: Draw – Two points Toolbar: Draw –Hotkeys: CTRL+ALT+L
Command line: L, LINE
The two point segment is one of the base primitives and is often used for drawing. Segments can be drawn separately and as a set of several segments, merged into zigzag lines. Each segment closed or unclosed line is a separate segment, which is edited separately.
Undo
Deletes the last created segment of a created set of segments in an inverse order.
Close
Creates the segment, connecting the last point of the last segment with the start point of the first segment. This option is available after the creation of the second segment.
Specify first point:
Specify point 1.
Specify next point:
Specify point 2*.
Specify next point [Undo]:
Specify next point or select Undo to cancel previous action.
Specify next point [Undo/Close]:
Specify next point or press ENTER to finish the command.
Info: NanoCAD is an easy-to-use, affordable, and yet powerful, CAD application for Windows, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware supports groundbreaking, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
