To adjust the height of a row or the width of a column, use the sliders located on the rulers (horizontal and vertical). Move the slider by clicking it and holding down the left mouse button whilst dragging it. While adjusting the height or width, their values are highlighted in color for easy monitoring.
Row height and column width may also be set in the property dialog box that can be opened by right-clicking the header of a row or column.
- In this dialog box, enter the desired width/height in millimetres.
- In the Properties of column dialog box, the Hidden checkbox is available. Using it, you can hide the display of the selected column on the drawing. It can be displayed in the editor mode.
It is also possible to hide a column using the column context menu.
The Substitute zeros command (in numerical cells with a zero value, the cells should have a numerical format) replaces the cells contents with the set text.
NOTE! The format of the cell text value is established in the cell properties on the Content tab.
Close the dialog box by clicking OK.
Info: NanoCAD is a simple, affordable, and yet powerful, CAD application for personal computer, that allows a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program supports progressive, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, if you like it.
