Change Space
Ribbon: Layout – Layout Viewports > Change Space
Menu: Modify > Change Space
Layout context menu: Change Layout
Command line: CHSPACE
Transfers selected objects between model space and paper space.
The command is available only in paper space in presence of active viewports.
The transferred objects are scaled automatically in the new space.
Transfer of paper space objects to the model space selected in the layout viewport
Select objects or [?]: | Select paper space objects. |
Set the TARGET viewport active and press ENTER to continue: | Click inside layout viewport to make it current and press ENTER. The transferred objects are scaled automatically to preserve visual representation. |
Transfer of model space objects to paper space
Select objects or [?]: | Select model objects in the active layout viewport. |
Set the SOURCE viewport active and press ENTER to continue: | Click inside layout viewport to make it current and press ENTER. The transferred objects are scaled automatically to preserve visual representation |
If there is only one viewport in the paper space, the selected objects are transferred without additional prompts with information about the scale factor value:
Objects were scaled with factor 10.893 to preserve visual representation.
Info: NanoCAD is a simple, inexpensive, and yet powerful, CAD app for personal computer, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program ensures innovative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, if you like it.
