Explode text
Ribbon: Annotate – Text > Explode Text
Menu: Modify – Additional tools > Explode text
Command line: EXPLODETEXT, TXTEXP
You can explode text, to convert it into individual elements – solids (for TrueType texts if TEXTFILL=1 or Text=Filled in command options), polylines (for TrueType texts if TEXTFILL=0 or Text=Boundary in command options) or lines and polylines for SHX fonts. During the command, you can set different exploding options.
If you start Explode command with preselected texts – command will process with previous (or default) settings.
? | Additional options for object selection. |
Settings | Text explode settings: [Autoselect/Source/Properties/Text/Exit] |
Settings:
Autoselect | Select created objects after explode:
Source | Keep or Erase source text:
Properties | Specify object properties source:
Text | Fill settings for TrueType texts:
Exit | Return to object selection. |
elect text object for explode or [?/Settings]: | Choose Settings. |
Settings/ Command settings [Autoselect/Source/Properties/Text/Exit] | Specify desired settings. Then choose Exit or press Enter. |
Select text object for explode or [?/Settings]: | Select text objects for explode, then press ENTER. |
Info: NanoCAD is an easy-to-use, affordable, and yet powerful, CAD program for Windows, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool provides innovative, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, if you like it.
