Section note
Ribbon: Home, Annotate – Leaders > Section note
Menu: Draw – Notes > Section notes …
Toolbar: Utilities –
Command line: NOTES
This command opens the Section note dialog box to set the note options:
By left edge. | |
By center. | |
By right edge. |
Use the icons to select the secant type:
Single-stroked line. | |
Double-stroked line. |
Other icons:
The Select line icon is used to override the first and second lines of breaking construction. The icon is available when you edit the node secant note inserted into the drawing. |
To create a section note:
- Select the required note options.
- Click OK.
- Specify the first line of breaking construction, perpendicular to which the secant line will be located.
- Specify the second line of breaking construction.
- Specify the shelf position on the drawing.
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD program for PC, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware ensures groundbreaking, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
