Flat Texture Overlay
Ribbon: Topoplan – Texturing and Calculation> Flat Texture Overlay текстуры
Menu: Ground – Textures > Flat Texture Overlay
Toolbar: Textures and calculations > Flat Texture Overlay
Command line: NG_ORTHO_TEXTURE
Using this command, you can create a textured surface if the drawing contains a point cloud with the can Color attribute (its display should be enabled) and a surface created from this point cloud. The command allows you to create a photorealistic image of the earth model.
After running the command, specify the Submesh object in the drawing.
Texture size | Set in pixels. |
Format | Possible formats are BMP, JPG, PNG, TIFF. |
From the ground | Yes – the color of cloud’s point will be projected onto the surface, as if looking from the ground. If No is selected, the color will be projected as if looking from above |
Apply changes? or [Yes/No]:
- Yes – the texture overlay will be performed with the current settings.
- No – if the settings have been changed, they are not saved. The texture overlay will be performed with the settings that were displayed immediately after running the command.
Mesh before the texture overlay Mesh after the texture overlay
After removing the point cloud from the drawing, the surface preserves the texture:
Info: NanoCAD is an easy-to-use, cheap, and yet powerful, CAD app for Windows, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures creative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
