Menu: Modify – Object > Attributes > Edit block attributes …
Panel: Edit 2 –
Command line: ATTEDIT
The command opens the Edit of attributes dialog box, where it is possible to change attribute values of the block reference specified in the drawing:
The dialog box displays the block name, prompts and enables to edit values of all attributes contained in the block reference.
Attribute values of the selected block reference can also be changed on the Properties functional panel in the Attributes section:
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD app for Windows, that delivers an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware provides innovative, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and buy later, if you like it.
