Ribbon: Home – Block > Synchronize Attributes
Panel: Edit 2 –
Command line: ATTSYNC
Updates block references taking into account new and modified attributes from the specified block definition.
The command updates all instances of blocks containing attributes that were redefined with help of BEDIT command. The command does not change values assigned to attributes of the existing blocks.
Command query
Define option [?/Name/Select]
? | Opens the list of all block definitions in the drawing. |
Name | Enters names of blocks that should be updated with the specified current attributes. |
Select | Selects on the screen the blocks whose attributes should be updated. |
ATTENTION! The ATTSYNC command deletes any change of format or property made in the block attribute management commands ATTEDIT or EATTEDIT. It also deletes any additional data associated with the block and can influence on dynamic blocks or blocks created in third party applications.
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD platform for PC, that delivers an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program supports groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
