ORTHO mode
Status bar: the button
Hot key: F8
Command line: ORTO
With orthogonalisation mode set on, vector lines and rubber lines for editing can only be drawn in directions parallel to the coordinate axis. If an angle of a coordinate system is changed, the corresponding ortho mode angle is also changed.
The ORTHO mode has higher priority than the polar tracking mode.
NOTE: You can temporarily switch off the ORTHO mode by pressing and holding the SHIFT button when the command of creation or object editing is running.
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD application for Windows, that provides a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software provides progressive, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
