Customize Users Interface
Ribbon: Manage – Customization – Interface > Customize interface
Menu: Tools – Customize > Interface…
Command line: CUSTOMIZE
Customize User Interface dialog box is intended to:
- create and edit new menus, toolbars, context menus;
- fill menus and toolbars by commands;
- create new commands;
- add and change actions on objects, accelerators, aliases, tooltips;
- save all changes in a separate .cfg file and manage configuration files.
Customize User Interface dialog contains 9 tabs:
- Ribbon
- Main menus
- Toolbars
- Status bar
- Popup menus
- Accelerators
- Object actions
- Rollover tooltips
- Aliases
Parameters
File name | Field displays the path and name of edited CFG-file. |
File | Commands to manage config files:
Upper left part of dialog displays all elements of opened tab. Move selected element with drag&drop.
Upper right part of dialog contains all nanoCAD tools: commands and controls. Use them to create and edit interface objects: menus, toolbars, status bar.
There is a filter for tools:
- Select a section to display elements of selected category.
- Or type the template to find appropriated tools
Information about the selected element and action to be done with it is displayed in the right bottom corner of the dialogue box.
Properties in the lower left part of dialog displays properties of selected elements; they can be edited.
It is possible to edit and create interface elements in a context menu.
ATTENTION! You should restart nanoCAD to apply changes made in the current configuration file. Use SETCONFIG command to load another configuration file.
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD software tool for personal computer, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software ensures creative, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, if you like it.
