Ribbon: Point Clouds – Point Cloud > Transform to Default Coordinates
Menu: Point Clouds > Transform to Default Coordinates
Command line: NPC_TRANSFORM_TO_DEFAULT_COORDINATES
The command allows you to convert point cloud coordinates from the Own or User coordinate system to the World coordinate system.
It is usually used to transform the coordinates of those clouds that were taken in the own coordinate system.
Do you want to transform object coordinates from UCS to WCS or from OCS to WCS or [UCS/OCS]: | Specify from which system the cloud coordinates should be converted to the World coordinate system: from UCS or OCS. |
