Ribbon: Properties > Properties
Menu: Modify – Properties…
Toolbar: Main –
Hotkeys: CTRL+1
Command line: INSP, INSPECTOR, PROPERTIES
There are buttons of object selection modes and commands right below the Properties bar caption:
Modes of object selection
Multiple selection | Mode of multiple object selection; all selected objects are added to the previous selection set. ESC cancels the selection. Objects selected in this mode are excluded from the set if you press SHIFT. |
Single selection | Mode of single object selection; all newly selected objects are added to the selection set. Previously selected objects are removed from the set. You can also add new objects in selection set or exclude them. Hold the SHIFT button during selection to add new objects in current selection set. To unselect certain objects, click them with SHIFT button pressed. |
Commands of object selection
Select | Selection of objects using the cursor. |
Invert selection | Cancels the current selection of objects and selects the rest of the drawing objects. |
Select similar objects | Only objects, whose properties correspond to the specified template object are selected. |
Quick select | Set filter conditions and ways to create a selection set based on these conditions. |
Remove from selection | Excludes the specified objects from the selection set. |
Leave in selection | Leaves only the specified objects in the selection set. |
Select All Objects | Selection of all objects in the drawing. |
Unselect All | Cancels selection. |
To remove objects from a selection set
1. Choose the Select all in the context menu or from the Edit menu:
All objects in the drawing will be selected.
2. Choose the object type that you want to exclude from the set in the drop-down list in the Object type of the Properties bar:
3. Click the Remove from selection. All objects of the specified type will be deleted from the selection set.
4. Select another type of object in the drop-down list.
5. Click the Remove from selection.
6. Selection and removal of objects can be repeated until only the required objects remain.
To leave only specified objects in a selection set:
1. Choose Select all in the context menu or from the Edit menu. All the objects in the drawing will be selected.
2. Choose the object type which you want to exclude from the set in the drop-down list in the Object type of the Properties bar.
3. Click the Leave in selection. All objects, except the specified type, will be deleted from the selection set.
Info: NanoCAD is an easy-to-use, inexpensive, and yet professional, CAD platform for PC, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool supports progressive, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
