Associative Arrays
Associativity allows you to quickly make changes in the entire array due to the established relationship between the elements, while all the elements of the associative array are perceived as a single object. In an associative array, you can change the number of elements and the distance between them, set the number of levels. You can control the parameters of an associative array using the array grips or Properties bar.
An associative array can be divided into separate objects by Explode command.
The Associative option of the commands for creating and editing arrays allows you to specify whether the arrays will be associative or non-associative. Associative array elements are selected, edited, and behave like a single dynamic block. Non-associative arrays, after the end of the command, decay into independent objects.
