Filling “holes”
Ribbon: Raster– Filters> Hole Remover
Menu: Raster – Filters > Hole Remover…
Command line: HOLEREMOVER
The filter fills small holes in raster objects. In this case, only those “holes” are filled, the size of which is less than the specified value. This filter can automatically estimate the size of holes in image objects.
The filter can be used after binarization or separation procedures to fill in unwanted holes in raster objects.
Original image
After removing “holes”
1. Select images to be processed and run the Hole Remover command.
2. Enter the maximum size of the raster “holes” to be removed in the current units (left input field) or in points (right input field).
3. Or check the Auto estimating box to let the filter automatically estimate the size of raster “holes” before filtering.
To measure the size of the raster “hole” on the screen, click button and specify a point inside the “hole”, or click button and specify two points on the screen. The program will set the “hole” size equal to the distance between the specified points.
4. Click Apply
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD application for Windows, that delivers a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program ensures groundbreaking, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and buy later, in case you like it..
