Cut mesh
Ribbon: Topoplan – Modify TIN > Cut Mesh
Menu: Ground – Editing TIN > Cut Mesh
Toolbar: Editing TIN > Cut Mesh
Command line: NG_MESH_CUT
The command’s purpose is to split a mesh into divisions.
The command options are set on the Properties bar.
_.Save result as | Influences on objects that will be created in the process of performing the command: a Submesh or Polyfacemesh can be created. |
_.Delete source mesh |
_.Specify closed contour |
Apply changes or [Yes/No]:
- Yes – cutting will be performed with the current settings.
- No – if settings have been changed, they are not saved. Cutting will be performed with the settings that were displayed immediately after running the command.
Info: NanoCAD is a user friendly, cheap, and yet powerful, CAD app for PC, that provides an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware provides progressive, collaborative and customizable features to boost your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
