Drawing borders
Working with standard formats
CAD drafting DRAWING DESIGN 0Main menu: Mechanica – Drawing title/borders – CAD software DRAWING DESIGN 1Drawing title/borders.
CAD drawing DRAWING DESIGN 2Toolbar: CAD drafting DRAWING DESIGN 3Drawing title/borders ( “MCS Drawing title/borders”).
CAD software DRAWING DESIGN 4Command line: MCFORMAT, FORMAT.
· Filling in the fields of the title block · Drawing title/borders recognitionFundamental rules
Each format type is an element of the database nanoCAD Mechanica23, which is located in the folder “Drawing border templates” library nanoCAD Mechanica23.
emplates major labels and additional fields are located in the subfolder formats “Title block templates”. Renaming or deleting existing items in the folder “Drawing border templates” would make it impossible to insert existing formats.
Insert the format by clicking on the icon CAD drawing DRAWING DESIGN 5Drawing title/borders. This dialog box appears Format:
CAD drafting DRAWING DESIGN 6
This window is defined by:
· Format. · Sheet. · Autonumerate from. · Use zones from. · Center marks.After selecting the type of document, as well as the size and orientation of the sheet is inserted into the selected format.
· To edit the frame size, double-click the left mouse button on the contour of the frame. · To edit the text in the title block, double-click on the text of the left mouse button. · To edit entries in the title block, double-click the left mouse button on any line of the title block.If you remove the first sheet of the scope of its information from the title block is automatically transferred to the second sheet.
To save the settings template attached stamps and their parameters in the database, click on the button CAD software DRAWING DESIGN 7, then enter the path stored in the database and the template name.
General Principles
To change the line frames the template files, edit the frames and other fields.
“Document Type” – Select the document type from the list format template in section database. Depending on the document type is changed appearance and availability of individual dialog items “Format”.
“Format” – the choice of the size of the sheet on the basis of standard size and multiplicity (not available for the types of documents based on the standard ISO, because the multiplicity inherent in the choice of format).
“Leaf” – the choice of template title block for the first or subsequent sheets.
“Orientation” – select page orientation (vertical or horizontal).
“Autonumerate from” – Automatic Numbering sheets. It lets you specify the number of the first sheet.
“Use zones from” – avtoprostanovka zones. It lets you specify the number of the first zone.
CAD drawing DRAWING DESIGN 8Edit main stamp
After you select the document type and size under the proposed set the insertion point of the frame. If you press Enter or right mouse button, the lower left corner of the frame is aligned with the coordinate 0,0.
CAD drafting DRAWING DESIGN 9Set default stamps – restores the template format those stamps which were overwritten while maintaining format template database.
CAD software DRAWING DESIGN 10
To fill the title block fields and additional graph, double-click on any line of the title block.
The main inscription is filled directly into the dialog box, “Stamp”
While filling in the title block previously entered information stored in the section “History” menu. To open the context menu, place the cursor in an editable field and click the right mouse button.
Recent values can be saved in the section “Recent” menu.
Automatically fill fields of the title block
CAD drawing DRAWING DESIGN 11Save as default
The command saves the current filling of the stamp in the memory. In the following fields will be filled automatically stamp
CAD drafting DRAWING DESIGN 12Load defaults
The command loads the stored filling.
CAD software DRAWING DESIGN 13Clear
The team clears stamp field
CAD drawing DRAWING DESIGN 14Change template
The command opens a drop-down menu to change the pattern of the stamp.
CAD drafting DRAWING DESIGN 15Main menu: Mechanica – Recognition – CAD software DRAWING DESIGN 16Drawing title/borders recognition.
CAD drawing DRAWING DESIGN 17Toolbar: CAD drafting DRAWING DESIGN 18Drawing title/borders recognition ( “MCSRecognition”).
CAD software DRAWING DESIGN 19Command line: MCRECF.
Master recognition format enables automatic search and replace formats created from individual primitives nanoCAD, transforming them into an object of the “Format” nanoCAD Mechanica23. Initial primitives are in the drawing.
Recognition takes place in two phases: the first searches for the formats in their dimensions, the second selected title block. Selection is made by comparing the serial patterns of stamps from the library with the existing geometric objects in the drawing. The remaining seals are installed by default. After the successful recognition format graphs stamps are automatically filled with values from the drawing, and the format is placed on the current layer.
Before you create a custom size or stamp is necessary to draw a pattern nanoCAD means in accordance with the required desired view object being created. When drawing templates should adhere to the following rules:
· The template can contain lines, arcs, and circles, text (single-line and multi-line), the objects of the library of standard parts nanoCAD Mechanica23, blocks nanoCAD; · the thickness of the lines that are assigned to the template thickness is not equal to zero, and not “layer” to be adopted in accordance with the thickness of the closest standard value; · the color lines and text included in the template will be saved according to the selected values; · multiline text (mtext) is inscribed in the boundaries of the rectangular area of text is selected when you create it.You can use overhead lines and graphic objects, which are not drawn when inserting format or stamp in the drawing.
To install a drawing object as a service, use the button CAD drawing DRAWING DESIGN 20“Set parameter” toolbar MechWizard, select the object, and in the dialog “Object properties” check the box “Is a working object”:
CAD drafting DRAWING DESIGN 21
· Use the links in the templates · New border wizard · New title wizardUse the links in the templates
Stamps in the format template
Custom format may contain links to templates stamps available in the library. To add a stamp in the format used by the relevant rules.
Stamp Position and orientation when you insert a drawing format will be determined by the insertion point and orientation of text links:
CAD software DRAWING DESIGN 22
the figure shows the format template added referring to stamp basic inscription. When you insert a drawing format drawn stamp recorded in the library under the specified name.
the format can be added to any number of references to the stamps from the library.
Using text fields
In the pattern of the stamp may be used special signage text fields.
Text added to the template and starting with the single character “$”, is recognized as a reference pointer on the field (the Count) input. In the input field of the dialog box, you can edit the stamp to record the text (for example, the name of the developer or check). Name field can contain characters of the Latin alphabet and the national or spaces. Dimensions of the input fields are defined primitives surrounding the insertion point, the reference index. If you found another symbol “$”, the text after it considered the description field:
$Field_name [$field definitions].
the contents of the text box will be displayed in the list of object properties.
To limit the size of the input field or eliminate overlapping fields in the dialog, you can use the service line.
To create a stamp based on an existing base in the sample, the sample to be inserted into the drawing by setting in the dialog box “Stamp” mode “Display field names” CAD drawing DRAWING DESIGN 23. After insertion into the drawing die can be used as the layout of the new stamp.
Standard fields stamps have a description in Russian (GOST), English (ISO) or German (DIN) language, the values of the fields available in the list of object properties.
Name Description Contact with the properties of the document Inventor Note: $Designation Description + $DrawingName Name + $Drawing type Drawing View $Material Material + $Litera 1 Letter 1 $Litera 2 Letter 2 $Litera 3 Letter 3 $Mass Weight $DimScale Scale + Sets the size of generated within the format $Sheet Sheet + Changes in the automatic numbering $SheetCount Sheets + Changes in the automatic numbering $Add.text Position the additional inspection $Author Developed + $Control checked + $TechControl Technical control + $Add.subject Last additionally checked + $NormControl the Regulatory Control + $Approve Approved + $Author (sign) Developer Signature $Control (sign) the signature checking $TechControl (sign) Signature of the technical control $Add.subject (sign) Signature additional inspection $NormControl (sign) Text regulatory control $Approve (sign) the signature approving $Author (date) the date of + $Control (date) Date of Inspection + $TechControl (date) Date engineering controls + $Add.subject (date) Date further verification + $NormControl (date) Date of regulatory control + $Approve (date) Approval Date + $Original # Part Number script $Sign & date 1 Signed and dated 1 $Instead # Instead, inventory number $Duplicate # Inventory number duplicate $Sign $date 2 Signed and dated 2 $Reference # the reference number + $First use the primary use + $Format Format + $Enterprise Enterprise +In the pattern of the stamp can be used table nanoCAD Mechanica23. Included in the stamp table when you insert a drawing can be edited as regular tables nanoCAD Mechanica23 (except that the die table can not be modified in the editing mode screen).
Additional features
Converting from previous versions – In file %ProgramData%\Nanosoft\nanoCAD Mechanica23\DataRO\ru-RU\settings.xml defined fields for name mapping formats of old and new versions. If an entity applies the custom stamps of previous versions, the names of the fields, you can add them into the appropriate section of this file.
Integration with other objects nanoCAD Mechanica23
Tables – Format allows you to use tables as stamps. This preserves virtually all the functionality built-in table.
Universal marker – The values of any fields format can be used in a universal marker.
Dimensions – When you create within the format size, the size takes out set in the title block of the format.
Legend roughness – The format may be associated with the designation of a roughness surfaces unspecified. Icon roughness is automatically transferred to the upper right corner of the format.
Property document – The value of the standard field format is synchronized with the attributes of the file in which it was created.
Technical conditions – Format calculates the coordinates of the columns to accommodate the technical requirements.
Attribute documents TechnologiCS – Exchange values between the fields and the format of the document attributes. You can set the matching fields automatically (by the same name), and then specify manually. Establishing appropriate stored for later use.
Zone format – The format can be calculated, is there any point in it. If so, you can receive the designation area containing the point.
New border wizard
CAD drafting DRAWING DESIGN 24Main menu: Mechanica – Drawing Title/Borders – CAD software DRAWING DESIGN 25New border wizard.
CAD drawing DRAWING DESIGN 26Toolbar: CAD drafting DRAWING DESIGN 27New border wizard ( “MCSDrawing Title/Borders”).
CAD software DRAWING DESIGN 28Command line: MCFORMATWIZ.
CAD drawing DRAWING DESIGN 29
To change the existing format, select it from the drop-down list of templates. The field, located in the center of the panel will be a general view of the selected format.
To add a new format, select the drop down list “Template name” paragraph (new).
Click the left mouse button on the center field, select the drawing created by pre-layout format template, and confirm the selection click OK.
In the dialog box “Format creation” will be recognized image format.
If you create a new format after closing the dialog box by pressing OK, a dialog “Create element”, which follows the format and select the name of the folder in the library of standard parts, which will save the created format:
CAD drafting DRAWING DESIGN 30
By default the path “DB \ Drawing borders template”. If you want to keep the format in another folder, press CAD software DRAWING DESIGN 31 and select the folder that appears in your browser.
Creating a template format is similar to creating templates stamps. Embedded tables are not supported. The texts, starting with the single “#” character, determine the type and position of the stamp format. When you insert the size of the database will be loaded stamped with the name specified in the text (the symbol ‘#’ is ignored and the text “main message” will be replaced with the box on a stamp with the name of “Title Block”), if it is in base. If the name starts with “$” and contains only hexadecimal digits, it is interpreted as UID template stamp in the database. Coordinates, direction and alignment of the text will be applied to the stamp.
Note:
See stamp UID by inserting the drawing title block of the database manager nanoCAD Mechanica23.At the command prompt displays the hexadecimal object UIDPredefined templates are stored in the formats “DB \ Drawing borders template”. It is recommended that the new template is stored in the same folder, but when loading the template can be seen the whole base.
Frame custom format has a fixed size – the one set in the template. There is a special recognition mode that allows the use of standard scalable framework with their stamps. To enable this mode, select from the list in the dialog master the standard by which the frame will be built. In this mode, all of the graphics in the template are ignored, except for text and bounding box. The frame can be of any size – in the final format it replaced with standard frame. All texts are considered names stamps. There are two variants of binding stamps:
· If the text begins with the “#” symbol, it is stored offset from the insertion point to the nearest corner of the bounding box. · If the symbol “#” no stored offset from the text insertion point to the bottom left corner of the bounding box.Note:
Standard sizes have patterns in the database – their patterns are embedded in the program code.
New title wizard
CAD drawing DRAWING DESIGN 32Main menu: Mechanica – Drawing Title/Borders- CAD drafting DRAWING DESIGN 33New title wizard.
CAD software DRAWING DESIGN 34Toolbar: CAD drawing DRAWING DESIGN 35New title wizard ( “MCSDrawing Title/Borders”).
CAD drafting DRAWING DESIGN 36Command line: MCSTAMPWIZ.
CAD software DRAWING DESIGN 37
To change an existing stamp, select it from the drop-down list of templates.
To add a new format, select the drop down list “Template name (new)”.
A template stamp can have up to four different graphical representations: simple and full (advanced) type, including the form of the first sheet and the view for subsequent sheets.
Select one of the tabs: “Simple view” or “Extended view”. Click the left mouse button on one of the fields marked with a stamp type, and select the drawing template you created earlier mock punch. Confirm the selection click OK.
In the dialog box “Create stamp” will be recognized image of the stamp.
If you create a new stamp, after closing the dialog box by pressing OK, a dialog “Create element”, where you must enter the name of the stamp, and choose a library of standard parts folder in which to save the template created by the stamp:
CAD drawing DRAWING DESIGN 38
New templates stamps recommend that you save to the folder “DB \ Drawing borders template \ Title block templates”.
If the layout for the die table to use, it will retain its editing capabilities even being introduced to the format. For these tables are only supported editing in place.
The pattern die may be up to four types:
· the main type of the first sheet, · he main type of follow-up sheets, · an expanded view of the first sheet, · an expanded view of the next sheet.The texts, starting with the single character “$” are recognized as the names of the fields. The editing dialog stamp they will be displayed in the form input fields. Name field can contain spaces and extended characters. Dimensions of the field defined primitives surrounding the point of its insertion. If you found another symbol “$”, the text after it considered the description field. This text will be displayed in the list of properties:
To limit the size of the field or eliminate overlapping fields in the dialog, you can use the service line. This is a primitive with zero thickness or line marked as the utility from mcWizParam. Set the parameter.
If you set daw “Work object”, then stamped on tobrazhatsya these primitives will not.
To create a stamp based on an existing base in the sample, the sample to be inserted into the drawing, and in his dialogue press CAD drafting DRAWING DESIGN 39 “Show Field Names”. View selected stamp button “View”.
After that, the object can be divided (explode), edited and used as the layout.
The dialogue is a choice of the standard, which is taken from a stamp. This standard is used for the selection of the frame formats in recognition of the primitives.
Tables
Tables
CAD software DRAWING DESIGN 40Main menu: Mechanical – Tables – CAD drawing DRAWING DESIGN 41Tables.
CAD drafting DRAWING DESIGN 42Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 43Tables.
CAD drawing DRAWING DESIGN 44Toolbar: CAD drafting DRAWING DESIGN 45Tables (on toolbar “Tables”).
CAD software DRAWING DESIGN 46Command line: MCTABLE.
Causes dialog box to insert a new table.
CAD drawing DRAWING DESIGN 47
· To create a custom table, select Custom. In input fields specify the dimensions of the created table, or on the layout, drag the mouse to the right as many rows and cells as required. When subsequent editing the number of rows, columns, cell sizes can be changed. · To insert a standard table, select load from database. You can insert a standard table of the base elements Building site . In the dialog box, select the table you want. Database elements Building site is available for all major types of standard tables. · To insert a table from a file, select Load from file.Click Browse and select the file table. Supported formats:
· tbl – tables files · dat – data file or a text file · mdb – database Microsoft Access · xls – Spreadsheet Microsoft Office Excel · xlsx – spreadsheet Microsoft Office Excel 2007 · csv – table cell separated by commas · txt – standard text file · xml – XML document · odf – OpenDocument Format.When loading a table of xlsx, xls file, you must select the Excel document sheet.
CAD drafting DRAWING DESIGN 48
Important!
Select the sheet can be made after a table is loaded from the file.
CAD software DRAWING DESIGN 49
CAD drawing DRAWING DESIGN 50
In the properties of a table row source file displays the path to the source file of the table.
Select line Request to enter the desired page of the document. Then in the Table Editor, click CAD drafting DRAWING DESIGN 51Update Table from an external source.
When loading a table from a file mdb drop-down list displays a list of database query.
CAD software DRAWING DESIGN 52
Note:
To import tables from files, you can drag a file from Explorer to the dialog table .
When you drag a file from Windows Explorer in the imported table is added to the existing table.
When you drag a file from Windows Explorer dialog box replaces the existing table to be imported.
· To generate a report based on a sample of objects, select the objects in the sample report. ·To make a selection of items, click Select.
CAD drawing DRAWING DESIGN 53
The search conditions are set in the Quick selection dialog.
Further dialogue is given based on what the attributes are and creates a report on the selected objects.
CAD drafting DRAWING DESIGN 54
Includ attributes for the report in the list by selecting flags
CAD software DRAWING DESIGN 55
· All- selects all attributes · None – the choice is removed from all the attributes · Invert – inverted selection attributesThe table is created with a template report form
=Iff(Exist(Object.“Autoreport”);Object.“Autoreport”;”“)
This formula checks whether there is a line for the attribute named Autoreport, and displays its value in a cell. Otherwise, leave the cell blank.
CAD drawing DRAWING DESIGN 56
The number of columns in the table determined by the number of selected attributes.
· To import a table from Excel, select Import from Excel. To activate this item, the document should be opened. · Select the insertion point of the table. · CAD drafting DRAWING DESIGN 57 · Select the numbering of rows in the table. · CAD software DRAWING DESIGN 58If the switch rows upside down is enabled, the line numbered in reverse order.
· When the checkbox CAD drawing DRAWING DESIGN 59 after you insert the table will start a dialogue format. · Click OK and the insertion point on the drawing table.Note:
If the drawing pre-select a group of objects, and then run the CAD drafting DRAWING DESIGN 60tables, you will be prompted to create a report based on a sample of objects.
Import, export from Excel
Import
CAD software DRAWING DESIGN 61Main menu: Mechanical – Tables – CAD drawing DRAWING DESIGN 62Import table from Excel.
CAD drafting DRAWING DESIGN 63Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 64Import table from Excel.
CAD drawing DRAWING DESIGN 65Toolbar: CAD drafting DRAWING DESIGN 66Import table from Excel (on toolbar “Tables”).
CAD software DRAWING DESIGN 67Command line: MCTABLEEXCELIMPORT.
Transmits data from an open book MS Excel.
· In an open Excel worksheet, select the cells whose data you want to import into a table nanoCAD Mechanica 23. · Go to the nanoCAD, editor of the table, and then click Import tables from Excel. · Data will be transmitted to the table.Export
CAD drawing DRAWING DESIGN 68Main menu: Mechanical – Tables – CAD drafting DRAWING DESIGN 69 Export table to Excel.
CAD software DRAWING DESIGN 70Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 71 Export table to Excel.
CAD drafting DRAWING DESIGN 72Toolbar: CAD software DRAWING DESIGN 73Export table to Excel (on toolbar “Tables”).
CAD drawing DRAWING DESIGN 74Command line: MCTABLEEXCELEXPORT.
Designed to transmit tabular data in MS Excel. After clicking on the button opens a new Excel workbook and it migrates all the tabular data with formatting cells established in the table.
Important!
The tables nanoCAD Mechanica23 not to Excel the following data:
· Blocks nanoCAD · Formatted text · Formulas that do not match the format of ExcelTable recognition
CAD drafting DRAWING DESIGN 75Main menu: Mechanical – Recognition – CAD software DRAWING DESIGN 76Table recognition.
CAD drawing DRAWING DESIGN 77Ribbon: Mechanical – Utilities – CAD drafting DRAWING DESIGN 78Table recognition.
CAD software DRAWING DESIGN 79Toolbar: CAD drawing DRAWING DESIGN 80Table recognition (on toolbar “Recognition”).
CAD drafting DRAWING DESIGN 81Command line: MCRECTABLE.
Table recognition enables automatic search and replace tables created from individual primitives nanoCAD object “Table” nanoCAD Mechanica23. Sources are primitives for drawing.
1. Use the command table recognition. 2. Specify the drawing point at the table.The table is created in the current layer. Dimensions of the recognized table are rounded to integer values.
Text belongs to the workpiece table is recognized as the values of the respective cells of the table.
Real dimensions of the original graphics are multiplied by the scale design, so if it turns out the table with zero height lines, you need to change the scale clearance in accordance with the size of the original graphics.
CAD software DRAWING DESIGN 82Main menu: Mechanical – Tables – CAD drawing DRAWING DESIGN 83Edit table in-place.
CAD drafting DRAWING DESIGN 84Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 85Edit table in-place.
CAD drawing DRAWING DESIGN 86Toolbar: Tables – CAD drafting DRAWING DESIGN 87Edit table in-place.
CAD software DRAWING DESIGN 88Command line: MCIPEDITTBLIPEDITTBL.
CAD drawing DRAWING DESIGN 89Shortcut: CTRL+RBM on table frame.
When editing a table on-screen, the “Edit Table” toolbar appears.
CAD drafting DRAWING DESIGN 90
The active cell is highlighted with a green frame. The text entered into the cell is automatically pre-pressed.
CAD software DRAWING DESIGN 91Group cells.
Serves to combine adjacent cells into one.
Procedure:
· Call command. · Pick the first corner point of the selection. · Pick second corner point of selection. · Selected cells will merge.CAD drawing DRAWING DESIGN 92Ungroup cells.
Undoes the grouping of a previously merged cell from multiple cells.
Procedure:
· Call command. · Pick the first corner point of the selection. · Pick second corner point of selection. · Selected grouped cells that fall within the selected area will ungroup.CAD drafting DRAWING DESIGN 93Split cells.
Serves to divide cells into several smaller cells.
Procedure:
· Call command. · Pick the first corner point of the selection.CAD software DRAWING DESIGN 94
· Pick second corner point of selection.CAD drawing DRAWING DESIGN 95
· In the “Split” dialog box that appears, enter the required numerical values for repartitioning.CAD drafting DRAWING DESIGN 96
· This will result in a new breakdown.CAD software DRAWING DESIGN 97
Note:
When using the “Split” command, the height and width of adjacent cells may be lost.
CAD drawing DRAWING DESIGN 98Pencil.
Serves for splitting cells into several by creating additional borders.
Procedure:
· Call command. · Pick the first point of the dividing line on the table border.CAD drafting DRAWING DESIGN 99
· Pick the second point of the dividing line on the table border.CAD software DRAWING DESIGN 100
· The cells that the dividing line will pass through will be split into new cells. Each cell is independent.CAD drawing DRAWING DESIGN 101
CAD drafting DRAWING DESIGN 102Add row. Adds one row at the bottom of the table.
CAD software DRAWING DESIGN 103Add column. Adds one column to the end of the table.
CAD drawing DRAWING DESIGN 104Insert row. Adds one row to the current position of the table cursor.
CAD drafting DRAWING DESIGN 105Insert column. Adds one column to the current position of the table cursor.
CAD software DRAWING DESIGN 106Delete row. Deletes the row containing the selected cell.
CAD drawing DRAWING DESIGN 107Delete column. Deletes the column that contains the selected cell.
CAD drafting DRAWING DESIGN 108Row properties. Changes the height of the row containing the selected cell. A dialog box is called up in which to specify the line height in millimeters.
CAD software DRAWING DESIGN 109
The “Start new page” parameter splits the table in an arbitrary place, i.e. where the cell is selected. Other pagination methods are available in the full editor interface.
CAD drawing DRAWING DESIGN 110Column properties. Changes the width of the column that contains the selected cell. Enter the column width in millimeters in the dialog box.
CAD drafting DRAWING DESIGN 111
The “Hidden” option hides the selected column. You can return visibility to a column from the full editor interface.
The “Substitute zeros with symbol” parameter replaces the null values of the column cells with the row data. In this case, the format of the cells must be numeric.
CAD software DRAWING DESIGN 112Cell properties. Calls up the “Cell Properties” dialog box, which configures the properties of the selected table cell.
CAD drawing DRAWING DESIGN 113Cells properties. Setting properties of a group of table cells. Select the required cells and in the appearing “Cell Properties” dialog box set the parameters of the selected table cells.
CAD drafting DRAWING DESIGN 114Sum
Calculates the sum of the selected area.
Procedure:
· Select the result cell. · Call the command. · Pick the first point of the marquee. · Pick the second point of the marquee. · The formula will be entered into the result cell.CAD software DRAWING DESIGN 115Selective sum
Calculates the sum of the selected cells.
Procedure:
· Select the result cell. · Call the command. · Specify cells. Press “Enter” to finish. · The formula will be entered into the result cell.CAD drawing DRAWING DESIGN 116Notebook
CAD drafting DRAWING DESIGN 117Calculator
CAD software DRAWING DESIGN 118Special symbols
CAD drawing DRAWING DESIGN 119Quit. Exits the table screen editor. You can also exit the on-screen table editor by right-clicking on an empty space in the drawing.
Table editor
The interface is opened by double-clicking on the table, or by selecting the “Edit” command from the context menu of the selected table.
CAD drafting DRAWING DESIGN 120
The dialog box contains:
· main menu; · toolbar; · parted cells with names (addresses) of rows and columns; · status bar with transparency and scale caret;General Provisions
The names (addresses) of rows and columns are adopted similarly to the MS Excel spreadsheet editor. Vertical columns from left to right are named in alphabetical order in English letters (A, B, C, D,…, Z, AA, AB, etc.), horizontal rows are named in numbers in order.
When you click LMB on a row or column name, it is selected.
CAD software DRAWING DESIGN 121
CAD drawing DRAWING DESIGN 122
To select the entire table, select a rectangle at the intersection of the row and column names.
CAD drafting DRAWING DESIGN 123
The shortcut “Ctrl + scrolling mouse wheel” allows you to change the scaling of the table.
The shortcut “Ctrl + click mouse wheel” sets the default table scaling.
CAD software DRAWING DESIGN 124
CAD drawing DRAWING DESIGN 125
When “View sorting” is enabled, sort buttons appear on the right side of the column headings. This sorting is intended to improve the convenience of entering data in the spreadsheet editor and does not affect the state of the table in the drawing.
The button has three states: “Not”, “Ascending”, “Descending”.
Not
CAD drafting DRAWING DESIGN 126
Ascending
CAD software DRAWING DESIGN 127
Descending
CAD drawing DRAWING DESIGN 128
Sorting features:
· Enabling sorting on one column disables sorting on other columns. · Rows are sorted whole, not just the column. · Strings are sorted within a section. · The merging of cells is not broken. · After enabling view sorting, the vast majority of commands are blocked. Allowed: exit, edit single cells and change sort mode.Cell color
CAD drafting DRAWING DESIGN 129
– cell containing expression;CAD software DRAWING DESIGN 130
– non-editable cell, for example, in a report;CAD drawing DRAWING DESIGN 131
– cell with an error in the expression;CAD drafting DRAWING DESIGN 132
– cell containing report section data;Filling adjacent cells with data
To speed up data entry into the table, automatic data filling functions are used. The spreadsheet editor can automatically continue a series of numbers, combinations of numbers and text according to a given pattern. You can quickly fill in different types of data series by selecting multiple cells and dragging the fill handle.
CAD software DRAWING DESIGN 133
Filling cells with a sequence of numbers or combinations of numbers and text according to a given pattern:
1. Select the first of the filled cells.CAD drawing DRAWING DESIGN 134
2. Enter an initial value for a range of values.CAD drafting DRAWING DESIGN 135
3. Enter a value in the next cell to set the fill pattern.CAD software DRAWING DESIGN 136
For example, if you want the sequence 1, 2, 3, 4, 5 …, enter the values 1 and 2 in the first two cells. If you want the sequence 2, 4, 6, 8 …, enter 2 and 4. If you need sequence 2, 2, 2, 2 …, the second cell can be left blank.
As the sequence is completed, it continues as shown in the table below.
Initial value
Continuation of the series
1, 2, 3…
4, 5, 6 …
1st period, 2nd period
3rd period …
Product 1, Product 2
Product 3 …
4. Highlight cell or cells containing seed values.CAD drawing DRAWING DESIGN 137
5. Drag the fill handle over the range you want to fill.CAD drafting DRAWING DESIGN 138
The cells will be filled with the specified sequence of numbers.
CAD software DRAWING DESIGN 139
To fill in ascending order, drag the handle down or to the right. To fill in descending order, drag the handle up or left.
Basic tools
Main menu commands
File
· Open file… – loads table data from a file. Files available for download: * .tbl, * .dat, * .mdb (only for 32-bit Windows), * .txt, * .csv, * .xml, * .xls, * .xlsx. When you select an Excel file, only the first sheet of the workbook is inserted. · Open database… – opens a dialog of library to select a table saved in the database. · Save as file… – writing a table to an external file *.dat, *.txt, *.cvs, *.xml, *.xls. · Save to database… – writing the table to the base of elements. · Edit Form… – opens the form editor. Using the form, you can filter data, control the composition and style of the table. · Show Form… – opens the table filter form. · Imtort from Excel – the command transfers the results of calculating tabular data from an open MS Excel workbook. The content of the active sheet or a selected range of cells is transferred. · Export to Excel – the command is designed to transfer tabular data to MS Excel. After clicking the button, the “Conversion options” dialog opens. After specifying the options, a new Excel workbook is opened and all tabular data is transferred into it, while maintaining the cell formatting set in the table. · Close – saves changes and closes the editor. · Close without saving – closes the editor without saving changes.Edit
· Undo – undo the last action. · Redo – redo the last undone action. · Cut – cuts data from selected cells to the clipboard. · Copy – copies data from the selected cells to the clipboard. · Paste – pastes data from the clipboard.Pencil – serves for splitting cells into several by building additional borders.
CAD drawing DRAWING DESIGN 140CAD drafting DRAWING DESIGN 141CAD software DRAWING DESIGN 142
· Select material… – This tool is designed to insert into a table, technical requirements and technical characteristics of a formatted line-record for material and assortment. Clicking on the button brings up the “Material” dialog box. · Auto calculate expressions – controls the mode of automatic recalculation of values of table cells. By default, the auto-recalculation mode is on. · Recalculate – serves to recalculate data in a table after editing cell values or correcting formulas. · Auto update reports – controls the mode of automatic recalculation of the report. The mode is on by default. · Reports – update of the report. · Synchronize – updates the table with data from a linked file. Available if the table was loaded from a file. For correct synchronization, the data changed in the file must be previously saved.View
· Show rulers – switch, controls the display of the ruler.CAD drawing DRAWING DESIGN 143
· Show expressions -switch manages the formula bar display.CAD drafting DRAWING DESIGN 144
· Formula visualization – switch, controls the display of the formulas in cells.CAD software DRAWING DESIGN 145
· Zoom to objects – centers the original report objects in the drawing. · View sorting – controls the display of the sort buttons of the view.Turned on
Turned off
CAD drawing DRAWING DESIGN 146
CAD drafting DRAWING DESIGN 147
· Calculator… – the command calls calculator. · Notebook… – the command calls notebook.Column
· Add column – adds a new empty column after the selected column. · Insert column – adds a new empty column before the selected column. · Delete column – deletes the selected column. · Hidden – switch, hides the column. The column appears in the editor but does not appear in the drawing. · Properties… – open properties of column.Row
· Add row – adds a line below the selected one. · Delete row – deletes the selected row. · Hide row – hides the line. The line is not visible in both the editor and the drawing. · Show hidden rows – shows hidden lines. To use the command, you must select several lines between which hidden lines are located. · Sort ascending – sorts the table in ascending order relative to the selected column. · Sort descending – sorts the table in descending order relative to the selected column. · Custom sort… – opens a dialogue “Collections editor”. · Merging and Grouping… – opens a dialogue “Row grouping and merging”. · Start new page – switch, controls the page break before the selected line. · Limit rows per page… – opens the “Rows per page” dialog, which indicates the maximum number of lines per page. If there are more lines, a page break is inserted.CAD software DRAWING DESIGN 148
· Limit page height… – opens the “Page height” dialog in which the maximum page height is indicated. If the page height is greater than the specified height, a page break is inserted.CAD drawing DRAWING DESIGN 149
· Single page – the command removes all created page breaks. · Up to down – switch, controls the data display sequence. · Properties… – opens string properties.Cell
· Edit – puts the cell into edit mode. · Expression… – opens a dialogue “Expression builder”. · Properties… – opens a dialogue “Cell properties”. · Group – merges the selected cells. · Ungroup – corrodes the selected cells. · Split… – splits a cell into multiple rows and columns. When the command is called, the “Split” dialog appears.CAD drafting DRAWING DESIGN 150
CAD software DRAWING DESIGN 151
· Cut – cuts data from the selected cells to the clipboard. · Copy – copies data from the selected cells to the clipboard. · Paste – pastes data from the clipboard. · Clear – clears the selected cells. · Insert table – pastes a range of cells copied from Excel.Section
· Header of first page – adds a header for the first page. · Header of following pages – adds a header for pages. · Header of last page – add a header for the last page. · Insert Data section – inserts a data section. If the selected cell is in the data section, then an empty row is added. · Insert Report section – adds a report section. Used when building reports. · Footer of first page – adds a footer for the first page. · Footer of following pages – adds a footer for pages. · Footer of last page – add footer for the last page.Toolbar commands
· Open – allows you to choose one of two commands:CAD drawing DRAWING DESIGN 152Open file- loads table data from a file. Files available for download: * .tbl, * .dat, * .mdb (only for 32-bit Windows) * .txt, * .csv, * .xml, * .xls, * .xlsx. When you select an Excel file, only the first sheet of the workbook is inserted.
CAD drafting DRAWING DESIGN 153Load from base- opens a dialog of standard elements to select a table saved in the database.
· Save – allows you to choose one of two commands:CAD software DRAWING DESIGN 154 Save to base- writing the table to the base of elements.
CAD drawing DRAWING DESIGN 155 Save to file- writing a table to an external file * .dat, * .txt, * .cvs, * .xml, * .xls.
· CAD drafting DRAWING DESIGN 156Import table from Excel – the command transfers the results of calculating tabular data from an open MS Excel workbook. The content of the active sheet or a selected range of cells is transferred. · CAD software DRAWING DESIGN 157Export table to Excel -the command is designed to transfer tabular data to MS Excel. After clicking the button, the “Conversion options” dialog opens. After specifying the options, a new Excel workbook is opened and all tabular data is transferred into it, while maintaining the cell formatting set in the table. · CAD drawing DRAWING DESIGN 158Update table from external source – updates the table with data from a linked file. Available if the table was loaded from a file. For correct synchronization, the data changed in the file must be previously saved. · CAD drafting DRAWING DESIGN 159Pan and zoom view to show objects – centers the original report objects in the drawing. · CAD software DRAWING DESIGN 160Cut selection – cuts data from the selected cells. · CAD drawing DRAWING DESIGN 161Copy selection – copies data from the selected cells. · CAD drafting DRAWING DESIGN 162Paste from clipboard – pastes data from the clipboard. · CAD software DRAWING DESIGN 163Undo last change – undo the last action. · CAD drawing DRAWING DESIGN 164Redo last change – redo the previously undone action. · CAD drafting DRAWING DESIGN 165Move row down – moves the selected line down. · CAD software DRAWING DESIGN 166Move row up – moves the selected line up. · CAD drawing DRAWING DESIGN 167Move column left – moves the selected column to the left. · CAD drafting DRAWING DESIGN 168Move column right – moves the selected column to the right. · CAD software DRAWING DESIGN 169Page division -the tool is designed to split the table into separate parts, without losing integrity. With this function it is possible to split a large table in order to fit on the format, and still retain the ability to edit the table as a single object. · CAD drawing DRAWING DESIGN 170Open form – opens the table filter form. · CAD drafting DRAWING DESIGN 171Sort ascend – sorts the table in ascending order. · CAD software DRAWING DESIGN 172Sort descend – sorts the table in descending order. · CAD drawing DRAWING DESIGN 173Create summary function – sums the contents of the selected cells.CAD drafting DRAWING DESIGN 174CAD software DRAWING DESIGN 175
Procedure:
1. Select the cell in which you want to calculate the amount, press CAD drawing DRAWING DESIGN 176“Create summary function”.
2. Select the cells whose contents you want to summarize, press “Enter”.
· CAD drafting DRAWING DESIGN 177Open calculator – the command calls calculator. · CAD software DRAWING DESIGN 178Open notebook – the command calls notebook. · CAD drawing DRAWING DESIGN 179Insert material – This tool is designed to insert into a table, technical requirements and technical characteristics of a formatted line-record for material and assortment. When you click on the button, a dialog box is called “Material”. · CAD drafting DRAWING DESIGN 180Special symbols – inserting a special character from the list. · CAD software DRAWING DESIGN 181Recalculate table – serves to recalculate data in a table after editing cell values or correcting formulas. · CAD drawing DRAWING DESIGN 182Automatic calculation – controls the mode of automatic recalculation of values of table cells. By default, the auto-recalculation mode is on. · CAD drafting DRAWING DESIGN 183Update reports – update of the report. · CAD software DRAWING DESIGN 184Automatic report update – controls the mode of automatic recalculation of the report. The mode is on by default. · CAD drawing DRAWING DESIGN 185Group selection – serves to combine the selected table cells into one. · CAD drafting DRAWING DESIGN 186Ungroup selected cells – cancels the merge for the selected cells. · CAD software DRAWING DESIGN 187Change number of rows and columns – serves to change the number of rows and (or) columns in the selected range of cells.Procedure:
1. Select one or more cells and call the command.
2. In the “Split” dialog box that appears, enter the desired numeric values to stake.
CAD drawing DRAWING DESIGN 188
· CAD drafting DRAWING DESIGN 189Split table cell with pencil tool – serves for splitting cells into several by building additional borders.CAD software DRAWING DESIGN 190CAD drawing DRAWING DESIGN 191CAD drafting DRAWING DESIGN 192
To split a cell with the mouse cursor, specify the start and end points of the segment that will divide each cell it crosses into two.
Right-clicking on a cell border removes that border.
· CAD software DRAWING DESIGN 193Select cell style – calls the window for applying the style to the selected cells. · Text alignment – serves to control the placement of text in selected cells. Additional buttons are available by pressing the black triangle. The purpose of the buttons is clear from the figure on each of them.CAD drawing DRAWING DESIGN 194
· Fitting text horizontally – controls the horizontal alignment of text in the cell. The following options are available in the drop-down list:CAD drafting DRAWING DESIGN 195No horizontal tolerance
CAD software DRAWING DESIGN 196Shrink horizontally
CAD drawing DRAWING DESIGN 197Word wrap
· Fitting text vertically – controls the vertical alignment of text in the cell. The following options are available in the drop-down list:CAD drafting DRAWING DESIGN 198No vertical tolerance
CAD software DRAWING DESIGN 199Shrink text height
CAD drawing DRAWING DESIGN 200Expand row height
CAD drafting DRAWING DESIGN 201Add virtual rows
· Borders – is designed to control the display of the borders of the selected cells. When you click on the black triangle, additional buttons for displaying borders become available. The purpose of the buttons is clear from the figure on each of them.CAD software DRAWING DESIGN 202
· Color of borders – drop-down list for choosing border colors. To set the border color, you must first select a color and then select the border (using the CAD drawing DRAWING DESIGN 203“Borders” command) to which you want to apply the specified parameters.CAD drafting DRAWING DESIGN 204
· Lineweight of borders -drop-down list of border thickness selection. To set the border thickness, you must first select the thickness and then select the border (using the CAD software DRAWING DESIGN 205“Borders“command) to which you want to apply the specified parameters.CAD drawing DRAWING DESIGN 206
· Text style – drop-down list for choosing the text style of the cell. · Text height – drop-down list for selecting the height of the cell text.CAD drafting DRAWING DESIGN 207
· Text color – drop-down list for choosing the color of the cell text. · Text weight – drop-down list for choosing the thickness of the lines of the cell text.CAD software DRAWING DESIGN 208
· Selected cell coordinate field – displays the coordinates of the selected cell (s) and allows you to enter them.CAD drawing DRAWING DESIGN 209
· Row expressions – formula input field. The line is displayed if the “Main menu – View – Show expressions” switch is active.CAD drafting DRAWING DESIGN 210
Using gestures for shortcuts
Gestures are designed for quick access to commands from the main menu of the table editor. Gestures made with pressed RMB in the table editor.
Note:
If when the prompt appears gesture command being executed, you can omit the RMB.
Right – Calculator
CAD software DRAWING DESIGN 211
Left – Notebook
CAD drawing DRAWING DESIGN 212
Up – Expression
CAD drafting DRAWING DESIGN 213
Down – Cell properties
CAD software DRAWING DESIGN 214
Right hook – Return
CAD drawing DRAWING DESIGN 215
Left hook – Cancel
CAD drafting DRAWING DESIGN 216
The closed area of the selected cells in a clockwise direction – Connection (merged cells pre-allocated)
CAD software DRAWING DESIGN 217
Result:
CAD drawing DRAWING DESIGN 218
The closed area of the selected cells counterclockwise – Disconnection
CAD drafting DRAWING DESIGN 219
Result:
CAD software DRAWING DESIGN 220
Symbol “z” on select cells – Clear (pre-clean cell is released)
CAD drawing DRAWING DESIGN 221
Result:
CAD drafting DRAWING DESIGN 222
Editing the size of rows and columns
To modify the row height or column width, move your mouse to the border of the row or column. Click the left mouse button and holding the button down drag the border. The move will be highlighted by the current value of the row height or column width, as well as its new size.
Resize a row or column can also be done in the properties dialog box, selected by pressing the right mouse button on the header row or column.
1. In the properties dialog box, specify the height (width) in millimeters.CAD software DRAWING DESIGN 223
2. In the Properties dialog box of the column switch is available Hidden. With it, you can disable the display of the selected column in the drawing, however, the Editor will be displayed.CAD drawing DRAWING DESIGN 224
You can also hide a column from the context menu for the column.
CAD drafting DRAWING DESIGN 225
Command string Replace null values (for numeric cells with the value zero, the cell must be a numeric format), replaces the contents of the cells specified text.
Important!
Format text in a cell value is set in the properties of the cell on the tab Content .
Close the dialog by clicking OK.
Cell Properties
In the dialog box Properties parameters are set for table cells.
To edit the properties of a single cell in a table full editor, select the desired cell and issue Properties from the context menu or by pressing Ctrl + Enter, double click on the cell, as a gesture to “down” on the cell. The effect of this command is similar Cell Properties screen table editor.
To edit multiple table cells in the full editor, select the desired cells and issue the Properties from the context menu. The effect of this command is the same action as Properties screen editor table.
CAD software DRAWING DESIGN 226CAD drawing DRAWING DESIGN 227
There are six tabs:
· Flag Content. This tab specifies the type of data in a cell the user, set the formula for calculating values. In the properties of the cell can format values and enter the contents of a table cell. Checking unmodifiable disables the ability to edit the cell. Such a cell is highlighted in color.CAD drafting DRAWING DESIGN 228
- Opens the Expression Builder.
CAD software DRAWING DESIGN 229
CAD drawing DRAWING DESIGN 230
- The tool is used to insert the nanoCAD block the cell.
Select the list that appears in the desired unit from the current drawing file. If necessary, select another file using the menu View.
CAD drafting DRAWING DESIGN 231
After selecting a unit, it is displayed in the properties window of the cell, as well as in a table cell.
CAD software DRAWING DESIGN 232CAD drawing DRAWING DESIGN 233
To disconnect the unit, press the Remove block in the block selection.
CAD drafting DRAWING DESIGN 234
· Bookmark Font. This specifies the text font, color symbols, line thickness, font height, offset from the cell boundaries, the angle that defines the direction of the text, as well as the aspect ratio of the text.CAD software DRAWING DESIGN 235
Switch Vertical change text direction to vertical.
Empty fields oblique Angle and horizontal scaling means that the values are taken from the text style and horizontal indent – that the value is taken from the table settings.
· Bookmark fitCAD drawing DRAWING DESIGN 236
This specifies the cell, cell as well as parameters of inscribing text into the cell.
If the text width exceeds cell bounds
CAD drafting DRAWING DESIGN 237
If the text height exceed cell bounds:
CAD software DRAWING DESIGN 238
Mode Occupy extra row does not change the number of rows in the table, the desired row is made higher by the required number of times and line.
· Bookmark borders. Here you specify the type, color, thickness of the boundary line of the selected cell, you can manage the display of individual cell borders. Enable or disable the display of individual boundaries, you can use buttonsCAD drawing DRAWING DESIGN 239
CAD drafting DRAWING DESIGN 240
or in the preview by clicking the left mouse button near one of the cell borders. Alignment of text within a cell preview is set by clicking the left mouse button.
CAD software DRAWING DESIGN 241
To set the color of individual borders, click the left mouse button on the icon
CAD drawing DRAWING DESIGN 242
and select a color from the drop down list
CAD drafting DRAWING DESIGN 243
To determine the weight of the individual borders, click the left mouse button on the line (By layer) and choose the thickness of the drop-down list.
CAD software DRAWING DESIGN 244
Color, line thickness for the cell borders, and cell shading can be set from the menu.
CAD drawing DRAWING DESIGN 245
To apply the changes in color and thickness, click on the desired boundary. Can also be selected by using the display boundaries.
CAD drafting DRAWING DESIGN 246
· Flag Comment. A field for entering a comment.CAD software DRAWING DESIGN 247
Cell with the comment is displayed in the editor by a green label, which displays a hint when you hover the mouse on it.which is displayed a hint.
CAD drawing DRAWING DESIGN 248
· Bookmark Styles. Here you can set the style for the cell.CAD drafting DRAWING DESIGN 249
To create a style, right-click in the blank area of the Style tab, then on the shortcut menu, select Create.
CAD software DRAWING DESIGN 250
To work with a style template, open the context menu style.
CAD drawing DRAWING DESIGN 251
Using styles
Style assignment to table cells is performed by the command CAD drafting DRAWING DESIGN 252“Select cell style” in the toolbar of the table editor or tab “Fit” in dialogue “Cell properties”. he choice of style is carried out in the graphics window. Also, styles can be created and edited using the context menu.
Context menu
· Apply – the command applies the selected style on the cell (group of cells). · Update – the command replaces the selected style with the style of the selected cell. · Rename – command allows you to rename the name of the style. The name of the style is generated automatically during creation. · Delete – command removes the selected style from the list. · Import – command imports style in * .mcd format. · Export – command exports the style in * .mcd format. · Create – command allows you to create a new style.Creation order:
1. Set the cell style.
2. Open the style window
3. Select the “Create” context menu command.
4. A new style will be created. The name of the style is generated automatically during creation.
Division by page
CAD software DRAWING DESIGN 253Division by page. tool is designed to separate the table into separate parts, without losing its integrity. With this feature, you can split a large table in order to place a format, while preserving the ability to edit the table as a single object.
· When the command a dialog box appears page division.CAD drawing DRAWING DESIGN 254
· Switch single page disables table division. · Select the method of dividing the table: 1. Custom- The table can divided into any parts.CAD drafting DRAWING DESIGN 255
Page break before a row is set by start new command from the context menu.
CAD software DRAWING DESIGN 256CAD drawing DRAWING DESIGN 257
Close the dialog. The editor of the table indicate the boundaries of the gap, with the help of it, you can change the row height.
CAD drafting DRAWING DESIGN 258
On the drawing table with a gap will be as follows:
CAD software DRAWING DESIGN 259CAD drawing DRAWING DESIGN 260
Side of the split table can be moved in the drawing independently, double-clicking on any part of the full table editor opens.
CAD drafting DRAWING DESIGN 261
2. By row count enter the desired number of rows in a fragment. Headers do not count.CAD software DRAWING DESIGN 262
By table height enter the total height of a fragment, in millimeters, using the current scal.CAD drawing DRAWING DESIGN 263
Dividing the table into parts allows each part tobe moved independently:
Conversion options
The “Conversion options” dialog is a filter that influences the set of transmitted data. Appears when converting a report to data and when exporting a table to Excel.
CAD drafting DRAWING DESIGN 264
Converting a report to data
Delete hidden rows and columns – affects the conversion of hidden strings. If enabled, hidden rows are not passed to the data.
Table
Turned on
Turned off
line 4 is hidden
no hidden lines
line 3 is hidden
CAD software DRAWING DESIGN 265
CAD drawing DRAWING DESIGN 266
CAD drafting DRAWING DESIGN 267
Note:
The converted hidden lines remain hidden.
Save report template – affects the conversion of report template strings to data. If enabled, strings are transferred.
Table
Turned on
Turned off
CAD software DRAWING DESIGN 268
CAD drawing DRAWING DESIGN 269
CAD drafting DRAWING DESIGN 270
Export to Excel
Delete hidden rows and columns – the option does not affect the result, since hidden rows are not exported.
Save report template – affects the export of report template strings. If enabled, strings are transferred.
Table
Turned on
Turned off
CAD software DRAWING DESIGN 271
CAD drawing DRAWING DESIGN 272
CAD drafting DRAWING DESIGN 273
Using Variables
Important!
This function is available only in vertical applications based nanoCAD
Tables BuildIndustry support the use of additional variables defined in a special dialog (form).
Procedure for creating a set of user-defined variables and their use in the table below:
1. In full table editor from the menu Edit invoke the command Form Editor. 2. Create a form with controls and bind each control to a field (variable). More information about the forms, see Form Editor .CAD software DRAWING DESIGN 274
3. Close the form editor and save the form.CAD drawing DRAWING DESIGN 275
4. To set the variable, call the command form.CAD drafting DRAWING DESIGN 276
5. Open your form. Enter the desired values. Click OK.CAD software DRAWING DESIGN 277
6. Linking table cells with custom variables by using formulas.CAD drawing DRAWING DESIGN 278
Cell value will be associated with the variable.
CAD drafting DRAWING DESIGN 279
Variables can also be used in complex formulations.
Create reports
Reports are necessary in order to organize the data of objects in the drawing.
Recommended report structure:
· Header of first page; · Header of following page; · Header of last page; · Report title; · Report template; · Report; · Report summary; · Footer of first page; · Footer of following page; · Footer of last page;Generating a report
To create a report in the table editor, call the command from “Main menu – Section – Insert Report section”. The command will create a subsection “Report template”.
Additional subsections are added using the “Report template” menu: “Report title”, “Report Summary”.
Header and footer sections are added from “Main menu – Section”.
CAD software DRAWING DESIGN 280
Report template
The report template defines the content and appearance of the report; it can consist of one or several lines. A separate copy of the report lines is created for each object. Formulas in the report are calculated using the properties of the selection objects.
The following commands are available in the “Report template” menu (click on the subsection name):
· “Object filter…” – opens the “Quick Selection” dialog for forming a selection of drawing objects. The command is duplicated by the CAD drawing DRAWING DESIGN 281“Select source objects” button on the right in the “Report template” section. · “Merging and Grouping…” – opens the “Row grouping and merging” dialog in which the parameters of grouping and merging table cells are configured. The command is duplicated by the CAD drafting DRAWING DESIGN 282“Group and merge” button on the right in the “Report template” section. · “Freeze report” – the switch controls the report refresh mode. If the checkbox is selected, the update is performed manually, and the “Update report” command becomes available. · “Update report” – refreshes the values of report objects, the command is available in manual refresh mode. · “Report header” – adds a “Report Title” subsection to the beginning of the report, displayed at the beginning of each part of the table. · “Append Data section” – adds a data section below the report. If the section already exists, an additional line is appended. · “Append Report section” – adds a new report below the current one. · “Remove Report” – deletes the report with all associated subsections. · “Rebuild” – completely rebuilds the report based on the report template. Data entered manually in the “Report” section will be overwritten. · “Convert to Data section” – the command converts sections of the report to data. Blank lines are not converted. Calling the command opens the “Conversion options” dialog. · “Report footer” – Adds the “Report Summary” subsection to the end of the report, displayed after each part of the table.All related subsections of the report are visually combined with brackets.
CAD software DRAWING DESIGN 283
Important!
The report template has absolute priority over custom changes. After the refresh, the report colored by the user will become the same as the specified report template. Automatic report lines corresponding to the collected objects will be automatically formatted strictly according to the report template.
Report
The “Report” displays the values of the template variables.
CAD drawing DRAWING DESIGN 284
The report contains cells (with a lilac background) containing object data, marked with a special color. Selecting cells highlights the corresponding objects in the drawing.
When editing such cells, the changes will be applied to the very object to which they refer. For instance:
1. Take a Bolt GOST 7795-70 with a length of 50 mm and place a leader on it.
CAD drafting DRAWING DESIGN 285
2. Create table, report template and tie to bolt (parametric object).
CAD software DRAWING DESIGN 286
3. Add parameters: Object.Name and Object.L.
CAD drawing DRAWING DESIGN 287
4. Enter the new length, for example 120. Close the table editor.
5. The length of the bolt in the drawing has changed.
CAD drafting DRAWING DESIGN 288
Report title
The following commands are available in the “Report Title” menu (click on the subsection name):
· “Remove section” – deletes the “Report Title” section.Report summary
The following commands are available in the “Report Summary” menu (click on the subsection name):
· “Remove section” – deletes the “Report Summary” section.In the context menu of the “Report Summary” cells, there are the following additional commands: “Sum”, “Average”, “Minimum”, “Maximum”, “Count”.
The commands insert into the selected cell corresponding to the name of the expression. The action is applied to a fragment of a column within one section.
CAD software DRAWING DESIGN 289
Report Template
1. Call up the “Quick Selection” dialog box. Use the “Filter Objects…” command of the “Report Template” menu or the CAD drawing DRAWING DESIGN 290“Select Source Objects” button on the right in the “Report Template” section.
2. Use the “Quick Selection” dialog to filter the objects and click the “OK” button. The selected objects will be associated with the report.
CAD drafting DRAWING DESIGN 291
3. Select a cell in the “Report Template” section. In the context menu of the cell, the parameters of the related objects will be available for insertion.
CAD software DRAWING DESIGN 292
5. Select an option from the context menu. The “Report” subsection will be automatically created. The number of lines in the “Report” subsection corresponds to the product of the number of related objects and the number of template lines.
The report template can consist of several lines. To add rows in the context menu of the “Report Template” row, use the “Add Row” or “Insert Row” commands.
CAD drawing DRAWING DESIGN 293
Rows in a report template can be combined. Changes will be displayed in the “Report” section. Let’s consider a join using the example table below:
CAD drafting DRAWING DESIGN 294
· Select cell A1:A2 and select the “Group” command from the context menu. The selected cells will be grouped.CAD software DRAWING DESIGN 295
· In the “Report template” menu (click on the subsection name), select the “Rebuild” command. The table will look like this:CAD drawing DRAWING DESIGN 296
6. Fill in all the required cells of the “Report Template”.
7. The sample is formed. Close the table editor. Changing the parameters of objects in the drawing will change the values in the report.
Grouping and merging cells
Button CAD drafting DRAWING DESIGN 297Grouping and merging. Report template.
In the Grouping and merging dialog you can specify settings for grouping and merging table cells. Grouping and merging are only applied to cells in the report template.
CAD software DRAWING DESIGN 298
Study the example for how to merge cells.
CAD drawing DRAWING DESIGN 299 CAD drafting DRAWING DESIGN 300
Merging
1. In the Grouping and merging dialog box select Append rule and select Merge.CAD software DRAWING DESIGN 301
2. Select the column name for the cells you want to merge. Selection is made by double clicking on the column name or by dragging it into the Select field.CAD drawing DRAWING DESIGN 302
Note:
To select another column, you must drag it into the column list and then select it.You can select several columns then place them in the required order.
The columns are processed according to the rules of the grouping remplate.
3. If you want to sort, select and don’t sortand sorting, and select sort type.CAD drafting DRAWING DESIGN 303
4. Click OK to check the result in the table editor. Cells having identical values in the D column will be merged.CAD software DRAWING DESIGN 304
CAD drawing DRAWING DESIGN 305
CAD drafting DRAWING DESIGN 306
Grouping
1. In the dialog boxgroupings and click Add Rule select Group.CAD software DRAWING DESIGN 307
2. Select the name of the column whose cells you want to group. Choice is either by double-clicking on the column name, or by dragging it into the Select .CAD drawing DRAWING DESIGN 308
3. If you want to sort, click on the link and sorting, and select the type of sort. 4. Click OK to view the results in the table editor. Table rows that contain the same values ??in column C, will be grouped.CAD drafting DRAWING DESIGN 309
Interface Expression Editor
The Formula Editor (Expression Builder) allows you to set parameters, arithmetic expressions, and object property references for a selected table cell.
The formula editor is invoked:
· By clicking on the “fx” button in the formula bar; · By pressing Shift + F2; · Right-click upward; · From the context menu command “Expression ..”.Dialog
The dialog box consists of the “Expression Input Field”, “Formula Templates”, “List of Registered Functions”, “Quick View Fields” and the “Attach object” button.
CAD software DRAWING DESIGN 310
The “Attach Object” button allows you to attach to objects.
At the top of the dialog there is an expression input field, with which you can manually enter any arithmetic expressions, as well as use reserved variables and object properties.
When entering manually, a list of functions and variables containing the word being entered appears in the list of reserved functions; syntax is also checked. If the formula is incorrect, an error warning or hint will appear in the Quick View.
CAD drawing DRAWING DESIGN 311
In the quick view field, by clicking the mouse on an expression, the text in the input field related to this expression is selected.
CAD drafting DRAWING DESIGN 312
When you click on the CAD software DRAWING DESIGN 313 button in the “Expression input field”, the entered expression is saved on the formula templates panel for quick recall. Pressing the button again removes the expression from the formula template.
CAD drawing DRAWING DESIGN 314
The “Reserved Functions List” contains recently used expressions that are highlighted in yellow. When you click on the CAD drafting DRAWING DESIGN 315 button, expressions are saved in the Formula Templates panel for quick recall. Expressions that are in the Formula Template Bar in the Reserved Functions list will be marked with an asterisk. Pressing the CAD software DRAWING DESIGN 316 button again removes the expression from the formula template.
When you hover the cursor over the button of the saved template, a tooltip will appear with the contents of this template.
CAD drawing DRAWING DESIGN 317
In order to insert an expression from the “Formula template”, place the cursor in the required position, press the button with the template.
To delete an expression template, click the triangle button and uncheck the required template in the list that appears.
Binding to a table cell
In the formula, you can use any cell values of the properties of another object. If using automatic recalculation of the table, the formula object is automatically recalculated. Each cell can attach one or more objects. Objects are named Object1, Object2, and Object3, … sequentially numbered in the table. If the object is not used in a formula, it will detach from the table at the next calculation, and the object references are renumbered.
Binding properties for drawing objects to a single cell then use the expression or the keys Shift+F2. Available in the context menu of the selected cell.
CAD drafting DRAWING DESIGN 318
After selecting the command window opens the Expression Builder.
CAD software DRAWING DESIGN 319
Click Attach it.
Select the object whose data you want to send to the table (eg, Bolt M52). Now the list of expressions appears in the properties of the selected object. Double-clicking on the property (select Object.Name), adds it to the text in a cell. Click OK.
CAD drawing DRAWING DESIGN 320
After connection of the facility to the cell the cell color changes (it says that the formula in the cell) and it will display the calculated result, in this case the name of the object:
CAD drafting DRAWING DESIGN 321
Mathematical operations:
Addition
Subtraction
Multiplication
Division
Involution
sqrt()
Rootsquaring
Logical comparison and selection:
equally
more
less
not
or
not equal
not less
no more
or
and
Functions:
math:
Cos, Sin, Tg – trigonometric functions, the argument given in degrees.
Acos, Asin, Atg – inverse trigonometric functions, the result is given in degrees.
Abs – absolute value of (module).
Int – rounding to whole number.
Summ – returns the sum of the values of the variables in a grouped cells.
Note:
When you type a function should pay attention to the opening and closing brackets.
For example:
Summ(Row) – returns the sum of the numbers of grouped rows..
Summ(Standartnaya_detal.L) – returns the sum of the values ??of the L parameter object “standard part” in the grouped rows.
data conversion:
Str – Data conversion to a string type.
Num – conversion of data into a numeric type.
Frm – convert a numeric value to a string formatted according to the settings of a table column.
For example:
Frm(0.001230) returns a string 0,0012, if the column containing the cell is set to zero suppression and accuracy of 0,0000
selection and comparison:
FmtText – Addition formatted strings.
FmtSub – the creation of a subscript.
FmtSuper – create superscript.
FmtDigit – transfer number in hard copy.
FmtRaw – text without formatting.
DmtDiv – creation of fractions.
If/Iff – The logical choice. Recording Format:
if (Logich_Uslovie; Esli_Istina; Esli_Lozh)
where:
Logich_Uslovie – logical condition using logical comparisons (see above);
Esli_istina – the return value when the logical condition;
Esli_Lozh – return value at default logical condition.
For example:
if(object == Marker_universalny; Marker_universalny.position; “Undefined”) . If an object type, which is connected with the cell column has Marker_universalny value, the function returns the position value of the referenced object. Another type of object it returns a string Undefined .
Exist – Checks whether there is a constant: =IF(EXIST;Object.Name;0)
Min/Max – returns the minimum / maximum value listed in parentheses
For example:
Min(maskimalnoe_znachenie; MinValue ) – nourishes MinValue;
Max(maskimalnoe_znachenie; MinValue) – returns maskimalnoe_znachenie.
Count – returns the number of objects (for grouped rows in the table).
For example:
Count() – returns the number of objects associated with cells grouped rows.
Avg – Calculates the arithmetic mean of the arguments. Takes an arbitrary number of arguments understand ranges. Empty arguments are ignored.
Off – returns the value of the cell, given the relative index. The index is written in the format:
Off(string; column)
For example:
Off(-1;2) – returns the value of cell in the table on one line above (-1) and two columns to the right (2) of the current
Cell – the cell returns the value specified absolute index.
Merge (Cells,Expression) – brings together a range of Cells, if Expression is not equal to 0. Returns the value of Expression.
For example:
=merge(A5:C5; “Title”) – integrates cell A5 to C5, in the summary displays the text “Title”.
SetHeight() – reference line height. In brackets the height value.
Val() – computes the value of the argument.
For example:
=val(“A”+“1”) – calculates the “A1”, and then uses it as another expression (obtained by the value in cell A1). If the argument – not a string, then he comes back, ie =val(10+2) – the same thing =10+2.
=val(“summ(AStr(off(0;-1))“Str(off(0;-1))”)”) – the amount of cells from rows A to D, the number which is introduced into the cell to the left of the current one. In most cases you can do without val. The classic example, when without it – no way: in a custom form, enter the cell address, then to take the value out of it. Create a variable Addr, associate it with an input field on a form and in the table do so: = val (Addr) function allows recursion: = val (val (“A” + “1”)) – to take the value of the cell whose address is recorded in cell A1. Nesting depth is limited to 64.
Geometry(Object) – works as Implement object. Height embedded object shrinks to the line height. Object is taken from the report, or attached to the cell.
SUMM) – Sum of cells in the current column of the section next to the current.
COUNT) – The number of rows in the section containing the cell A3.
Reserved variables:
Pi – pi.
Row – for each cell in the column it returns the number of rows (rows are numbered starting with 1, excluding the header lines).
Col – for all cells in a column returns the column number of the table (column “A” is number 1).
Object – returns the type of the object, which is associated with the cell line.
Object1, Object2, … – objects attached to the cell.
Title – the name of the table.
RowCount – total number of rows.
ColCount – the total number of columns.
Split the table by pages
The “Split the table by pages” tool is similar to the CAD software DRAWING DESIGN 322“Division by page” editor tool, but the result is not a split single table, but several separate tables.
1. Open the table for editing.
CAD drawing DRAWING DESIGN 323
2. In the places where the break will be, set the break with the command “Start new page”.
CAD drafting DRAWING DESIGN 324CAD software DRAWING DESIGN 325
3. Close the editor.
4. Select a table.
5. From the context menu, select the “Split table by pages” command.
CAD drawing DRAWING DESIGN 326
6. The table will be split into separate tables. The separation will occur at the places of the established breaks.
CAD drafting DRAWING DESIGN 327CAD software DRAWING DESIGN 328
Note:
If the command is applied to a report, the following destructive actions are performed:
1. The report is converted into static tables.
2. All connections with objects are broken.
3. All formulas are removed, and the cells begin to display the previously formed text.
4. Rows with report titles are hidden so that the display of the table in the drawing is not changed.
Dimensions
Dimension Style Manager
CAD drawing DRAWING DESIGN 329Main menu: Format – CAD drafting DRAWING DESIGN 330 Dimension Styles….
CAD software DRAWING DESIGN 331Main menu: Dimensions – CAD drawing DRAWING DESIGN 332 Dimension Styles….
CAD drafting DRAWING DESIGN 333Ribbon: Home – Annotation – CAD software DRAWING DESIGN 334 Dimension Style Manager.
CAD drawing DRAWING DESIGN 335Toolbar: Settings – CAD drafting DRAWING DESIGN 336Dimension Style Manager.
CAD software DRAWING DESIGN 337Command line: DIMSTYLE.
The software defaults to a government industry standard dimension style.
Dimension styles allow you to control the appearance of dimensions and quickly format them.
CAD drawing DRAWING DESIGN 338
Dialog box composition
The inscription “Current style: …” – information about the current dimension style, which is used when applying dimensions.
“Styles” list – a list of all dimension styles in the document.
The “Preview of: …” window is a graphical representation of the style selected in the “Styles” list.
Buttons:
· Set current – sets the selected dimension style current. · New… – opens a dialogue “Creating style”. · Modify… – change the parameters of the style selected in the list. Opens dialog “Modify dimension style”. · Override… – change the parameters of the current dimension style. Opens dialog “Modify dimension style”. · Compare… – compare two dimension styles, or view a list of all the properties of a style. The comparison results can be copied to the clipboard. Opens dialog “Comparing Dimension Styles”. · Delete… – deletes the selected dimension style.Restoring the Dimension Style
CAD drafting DRAWING DESIGN 339Command line: MCSETGOST, SETGOST.
This command is necessary to create (restore) the standard dimensional style of the environment nanoCAD Mechanica.
Dimension style settings are stored within drawing files. If the file was not created in nanoCAD Mechanica, then it may not have the required dimension style for correct work in the nanoCAD Mechanica environment.
Creating a dimension style
Button “New…” in the dialog box “Dimension style manager”.
The new style is based on the existing style.
CAD software DRAWING DESIGN 340
Field “New Style Name” – style name.
List “Start With” – the style on the basis of which the new one will be created.
List “Use for” – a dimension sub-style is selected from the list (applicable only to certain types of dimensions).
Button “OK” – opens a dialogue “Modify dimension style”.
In the “Modify dimension style” dialog, properties for a new style are set and parameters of an existing one are edited.
This dialog is called when you click the “Modify…” or “Override…” buttons from the “Dimension Style Manager”, as well as from the “Creating style” window.
The name of the edited style is reflected in the title of the dialog.
CAD drawing DRAWING DESIGN 341
Dialog “Modify dimension style” contains tabs:
· Lines · Symbols and arrows · Text · Fit · Primary units · Alternate units · TolerancesThe model image on each tab shows a preliminary result of the property changes.
Tab Lines
Sets the format and properties of dimension lines, extension lines, arrows, and center marks.
CAD drafting DRAWING DESIGN 342
Simension lines
Color – setting the color of dimension lines.
Linetype – setting the dimension line type.
Lineweight – setting weights for dimension lines.
Extend deyond ticks – when using serifs as dimension arrows, setting the distance the dimension line should extend beyond the extension lines.
Baseline spacing – setting the distance between dimension lines in dimensions from a common base.
Suppress – sets the suppression of the display of dimension lines if they go beyond the extension lines.
· Dim line 1 – suppress the first dimension line. · Dim line 2 – suppress the second dimension line.Extension lines
Color – setting the color of the extension lines.
Linetype ext line 1 – setting the type of the first extension line.
Linetype ext line 2 – setting the type of the second extension line.
Lineweight – setting weights for extension lines.
Suppress – set to suppress extension lines:
· Ext line 1 – suppress the first extension line. · Ext line 2 – suppress the second extension line.Extend beyond dim lines – setting the distance that extension lines should protrude beyond the dimension line.
Offset from origin – sets the distance by which extension lines deviate from object points.
Fixed length extenson lines – sets the full length of the extension lines from the dimension line to the origin of the dimension.
Tab Symbols and arrows
Sets the format and position of arrows, center marks, arc length symbols, and radius dimension polylines.
CAD software DRAWING DESIGN 343
Arrowheads
Controls the appearance of dimension arrows.
First – selection of the arrow type for the first dimension line. When you change the type of the first arrow, the type of the second is automatically changed.
Second – selection of the arrow type for the second dimension line.
Leader – setting the arrow type for the leader.
Arrow size – displaying the existing one and setting a new size for the arrows.
Center marks
Controls the placement of center marks and centerlines when placing a diameter or radius.
None – do not create center mark and centerlines.
Mark – create a center mark.
Line – create centerlines.
Size – displays an existing one and sets a new size for the center mark or centerline.
Arc length symbol
Controls the display of the arc symbol in the arc length dimension.
Preceding dimension text – inserts arc length characters before dimension text.
Above dimension text – inserts arc length characters above dimension text.
None – prohibiting the display of arc length symbols.
Radius dimension jog
Controls the display of broken lines (zigzags) of radius dimensions, in cases where the center is located outside the page.
Jog angle – sets the angle of the perpendicular line connecting the extension and dimension lines of the radius dimension.
Tab Text
Setting the format, placement and alignment of dimension texts.
CAD drawing DRAWING DESIGN 344
Text appearance
Text style – selects the current dimension text style from the list.
Text color – setting the color of the dimension text.
Fill color – setting the background color of the text in dimensions.
Text height – sets the current height of the dimension text. If the text style specifies a fixed height (that is, the style’s height value is not 0), then the height entered here is ignored.
Fraction height scale – setting the scale of fractional values relative to the rest of the text. This option is available if the “Unit format” is set to “Fractional” on the “Primary units” tab. The height of fractional texts is determined by multiplying the height of the regular text by a given factor.
Draw frame around text – sets the display of dimension text in a frame.
Text placement
Vertical – select the option to align the dimension text vertically relative to the dimension line:
· Centered – centered dimension text between extension lines. · Above – positioning the dimension text above the dimension line. The distance from the dimension line to the bottom border of the text is equal to the value specified in the “Offset from dim line” option. · Outdise – positioning the dimension text next to the dimension line on the side farthest from the first fit point. · JIS – placement of dimension text in accordance with the requirements of Japanese industrial standards JIS (Japanese Industrial Standards). · Below – the location of the dimension text below the dimension line. The distance from the dimension line to the top border of the text is equal to the value specified in the “Offset from dim line” option.Horizontal – select an option to position the dimension text horizontally along the dimension line relative to the extension lines:
· Centered – centered dimension text between extension lines along the dimension line. · At Ext Line 1 – the location of the text to the left of the first extension line. The distance from the extension line to the text is equal to the sum of twice the dimension arrow (“Symbols and arrows” tab) and the text gap (the “Offset from dim line” option). · At Ext Line 2 – the distance from the extension line to the text is equal to the sum of twice the dimension arrow (“Symbols and arrows” tab) and the text gap (the “Offset from dim line” option). · Over Ext Line 1 – positioning text above or along the first extension line. · Over Ext Line 2 – positioning text above or along the second extension line.Offset from dim line – setting the size of the current text gap (the width of the empty space around the text located at the break in the dimension line). This value is also used as the minimum length of the broken dimension line fragments.
The text is located between the extension lines only if the lengths of these fragments are not less than the size of the text gap. If text is above or below the dimension line, it will only fit between the extension lines if there is enough space for the dimension arrows and dimension text to be spaced apart by the text gap.
Text alignment
Sets the orientation of the dimension text between and outside dimension lines.Horizontal – place text horizontally.
Aligned with dimension line – place text along the dimension line.
ISO standart – place along the dimension line if the text is inside the extension lines, or horizontally if the text is outside.
Tab Fit
Controls the position of dimension text, arrows, leaders, and dimension lines.
CAD drafting DRAWING DESIGN 345
Fit options
Set the layout of text and arrows if there is not enough space between the extension lines to place them together:
Either text or arrows (best fit) – move either the text or arrows outside the dimension lines, whichever is the best location.
Arrows – move outside the extension lines, first arrows, then text.
Text – move outside the extension lines, first the text, then the arrows.
Both text and arrows – if there is not enough space, then both text and arrows are located outside the extension lines.
Always keep text between ext lines – always place text between extension lines.
Suppress arrows if they don’t inside extension lines – if there is not enough space for arrows between the extension lines, they are not displayed.
Text placement
Selecting an action when the dimension text is moved from the default position (specified by the dimension style):
Beside the dimension line – the dimension line moves with the text.
Over dimension line, with leader – dimension lines do not move, but a leader is drawn that connects them and the text. The leader is not drawn if the text is too close to the dimension line.
Over dimension line, without leader – no connections are made between the text and the dimension line.
Scale dimension feature
Use overall scale of – setting the scale factor for all dimension style parameters that specify dimensions, distances and indents, including the height of the text and the size of the arrows.
Scale dimensions to layout – sets a scale factor based on the ratio of units in the current model space viewport and paper space.
Fine tuning
Place text manually – places the dimension at the point specified when prompted for Dimension line position. All horizontal placement modes are ignored.
Draw dim line between ext lines – draw dimension line between extension lines, even if dimension arrows are positioned outside of them.
Tab Primary units
Sets the format and precision of base units, and dimension text prefixes and suffixes.
CAD software DRAWING DESIGN 346
Linear dimensions
Unit format – controls the display and format of tolerances in dimension text.
Precision – setting the number of decimal places in the dimension text.
Fraction format – setting format for fractional texts.
Decimal separator – selection of separator type for sizes expressed in decimal units.
Round off – setting rounding rules for all types of dimensions, except for angular dimensions. Example: for a given accuracy of 0.25, all measured distances are rounded to the nearest multiple of 0.25. When you enter a value of 1.0, all measured distances are rounded to the nearest whole value. The number of digits in fractional parts of distances depends on the precision specified in the “Precision” field.
Prefix – defining the dimension text prefix. You can enter special characters or use control codes to display special characters. For example, the control code “%% c” matches the diameter character. An explicit prefix takes precedence over default prefixes such as those used for diameter and radius.
Suffix – definition of a dimension text suffix. You can enter special characters or use control codes to display special characters. For example, typing the suffix mm will add it to the dimension text. The suffix entered here takes precedence over the default suffixes.
Measurement scale
Scale factor – setting the scale factor for linear dimensions. It is recommended not to change the default value of 1.00. The factor has no effect on angular dimensions, rounding accuracy, positive and negative tolerances.
Apply to layout dimension only – applies a scale factor only to dimensions plotted in layout viewports. It is recommended to disable the setting.
Important!
Changing the value of the scale of the dimensions of a style in a customization changes the value in the dimensions of the same style that are already assigned. This bug is unrecoverable for technical reasons.
Zero suppression – Controls the suppression of leading and trailing zeros, as well as feet and inches zero.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Angular dimensions
Sets the current corner format for angular dimensions.
Units format – selection of units of measure for angular dimensions.
Precision – setting the number of decimal places in angular dimensions.
Zero suppression – control of suppression of leading and trailing zeros.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Tab Alternate units
Setting the format and precision for alternative dimension units.
CAD drawing DRAWING DESIGN 347
Display alternate units – inclusion of the possibility of using alternative dimensional units.
Alternate units
Unit format – setting the format of alternative units.
Precision – setting the number of decimal places after the decimal point.
Multiplier for all units – setting the conversion factor from basic units to alternative ones. Example: To convert inches to millimeters, enter 25.4. The value has no effect on angular dimensions and does not apply to rounding precision or positive and negative tolerances.
Round distances to – sets the rounding rule for all types of dimensions, except for angular dimensions. Example: when setting the accuracy to 0.25, all measured distances are rounded to the nearest multiple of 0.25. When you enter a value of 1.0, all measured distances are rounded to the nearest whole value. The number of digits in fractional parts of distances depends on the precision specified in the “Precision” field.
Prefix – defining the prefix of the alternate dimension text. You can enter special characters or use control codes to display special characters. For example, the control code “%% c” matches the diameter character. An explicit prefix takes precedence over default prefixes such as those used for diameter and radius.
Suffix – defining the suffix of the alternate dimension text. You can enter special characters or use control codes to display special characters. For example, entering the suffix mm will add it to the text. The suffix entered here takes precedence over the default suffixes.
Zero suppression
Controls the suppression of leading and trailing zeros and feet and inches zero.
Placement
Sets the position of alternate units in dimension text.
After primary value – display the value in alternate units immediately following the value in base units.
Below primary value – display the value in alternate units below the value in base units.
Tab Tolerances
Controls the display and format of tolerances in dimension text.
CAD drafting DRAWING DESIGN 348
Tolerance format
Method – choice of method for determining tolerances.
None- disable display of tolerances.
Symmetrical – application of two limit deviations, with which the dimension text is displayed with the same upper and lower limit deviations. The tolerance is separated from the dimension by the “±” symbol. The value is entered in the “Upper value” field.
CAD software DRAWING DESIGN 349
Deviation – application of two limiting deviations. Dimension text is displayed with different upper and lower tolerance limits. When applying a dimension, a plus sign is put in front of the upper limit deviation and a minus sign in front of the lower one.
CAD drawing DRAWING DESIGN 350
Limits – displays dimension text as limit dimensions. The maximum size limit is above the minimum size limit. The largest limit is obtained by adding the upper limit deviation to the nominal size; the smallest – by subtracting the lower limit deviation from the nominal size.
CAD drafting DRAWING DESIGN 351
Basic – displays the dimension text as a nominal boxed dimension.
CAD software DRAWING DESIGN 352
Precission – setting the number of decimal places after the decimal point.
Upper value – setting the value of the upper limit deviation. When the “Symmetrical” method is turned on, both deviations are assigned this value.
Lower value – setting the value of the lower limit deviation.
Scaling for height – setting the current text height for deviations.
Vertical position – alignment of deviation texts:
· Bottom – alignment of deviation and nominal size on the bottom. CAD drawing DRAWING DESIGN 353 · Middle – aligning deviation and nominal size to the middle of the dimension text. CAD drafting DRAWING DESIGN 354 · Top – alignment of deviation and nominal size at the top. CAD software DRAWING DESIGN 355Zero suppression – control of suppression of leading and trailing zeros.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Alternate units tolerance
Alternative unit tolerance formatting.
· Leading – suppress leading zeros in all decimal sizes. Example: 0.3000 is written as .3000. · Trailing – suppress trailing zeros in all decimal sizes. Example: 11.5000 is represented as 11.5 and 30.0000 is represented as 30.Comparing Dimension Styles
The dialog for comparing two dimension styles or viewing a list of all style properties is invoked by the “Compare…” button in the “Dimension Style Manager” dialog.
CAD drawing DRAWING DESIGN 356
“Compare:” field – selects the first dimension style to compare.
“With:” field – selects the second dimension style for comparison.
“Difference table” – the table contains data on non-matching properties.
Table columns:
· Description – parameter name. · Variable – parameter system name. · Variable value columns – parameter values in compared styles.Button CAD drafting DRAWING DESIGN 357“Copy to clipboard” – allows you to copy comparison results to the clipboard.
Auto
CAD software DRAWING DESIGN 358Main menu: Dimensions – CAD drawing DRAWING DESIGN 359Auto.
CAD drafting DRAWING DESIGN 360Ribbon: Annotate – Dimensions – CAD software DRAWING DESIGN 361Auto.
CAD drawing DRAWING DESIGN 362Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 363Dimensions.
CAD software DRAWING DESIGN 364Toolbar: Dimensions – CAD drawing DRAWING DESIGN 365Dimensions.
CAD drafting DRAWING DESIGN 366Command line: MCMDIM, MDIM.
When inserting dimensions, context menu commands are available to switch the dimension view:
· Auto · Aligned · Horizontal · Vertical · Radius · Diameter · Large arc radius · Arc · Ordinate · Angle · Chain · Base · Properties (Opens the size edit dialog) · GroupNote:
If you hold down the CTRL key while placing linear dimensions at the time you select the dimension line, you can skew the dimension extension lines.
If you hold down the SHIFT key while placing linear or angular dimensions while selecting the position of the dimension line, you can move the dimension text along the dimension line.
Linear dimensioning
To apply the dimension you need:
1. Select a segment;
2. Place the dimension number.
Dimensions can change to horizontal, vertical, or parallel, depending on the position of the drop point.
Dimensioning by selecting characteristic (anchor) points
CAD software DRAWING DESIGN 367
To apply dimensions, you must:
1. Select the first node;
2. Select the second node;
3. Place the dimension number.
When selecting anchor points of the circle, the diameter sign is automatically set.
Dimensioning between two parallel lines
CAD drawing DRAWING DESIGN 368
To apply the dimensions shown above, you must:
1. Select the first segment;
2. Select the second segment;
Dimensioning through a point perpendicular to the selected line
CAD drafting DRAWING DESIGN 369CAD software DRAWING DESIGN 370
1. Specify the segment, perpendicular to which the dimension will be applied;
2. Without interrupting the commands, point to the end point of the line segment (a circle of small diameter should appear around the point);
Undo an erroneously inserted dimension without exiting the command
Dimensioning is performed in a cyclic mode, i.e. when applying one dimension, the team does not stop its work, but suggests setting the next dimension or choosing a different type of dimension. In some cases, the previous dimension may not be set correctly. To remove an erroneous dimension, there is the “Undo” context menu command. You can also call the command with the “Ctrl + Z” hotkeys. The command is available when setting the dimension after specifying the dimension number.
Auxiliary markers
Auxiliary autodimension markers appear when you hover over a drawing object and show what type of dimension will be built in this case:
· CAD drawing DRAWING DESIGN 371 Indicates that the diametral dimension will be drawn. · CAD drafting DRAWING DESIGN 372 Shows what a linear dimension will be drawn (horizontal, vertical or parallel). · CAD software DRAWING DESIGN 373 Shows that the angular dimension will be drawn. · CAD drawing DRAWING DESIGN 374 Shows that the chain of dimensions will be built. · CAD drafting DRAWING DESIGN 375 Shows that the slanted dimension will be drawn. · CAD software DRAWING DESIGN 376 Indicates that the radial dimension will be drawn.Linear dimensions
Aligned dimension
CAD drawing DRAWING DESIGN 377Main menu: Dimensions – CAD drafting DRAWING DESIGN 378Aligned.
CAD software DRAWING DESIGN 379Ribbon: Annotate – Dimensions – CAD drawing DRAWING DESIGN 380Aligned.
CAD drafting DRAWING DESIGN 381Toolbar: Dimensions – CAD software DRAWING DESIGN 382Aligned.
CAD drawing DRAWING DESIGN 383Context menu: aLigned – when calling any dimension.
CAD drafting DRAWING DESIGN 384Command line: MCMDIMALI, MDIMALI.
Horizontal dimension
CAD software DRAWING DESIGN 385Context menu: Horizontal – when calling any dimension.
CAD drawing DRAWING DESIGN 386Command line: MCMDIMHOR, MDIMHOR.
Vertical dimension
CAD drafting DRAWING DESIGN 387Context menu: Vertical – when calling any dimension.
CAD software DRAWING DESIGN 388Command line: MCMDIMVER, MDIMVER.
Parallel, horizontal, vertical dimensions
1. Choose dimension;
2. Select the type of binding:
· “nEarest snap gets object” – dimensions the entire selected object; · “nEarest snap gets point” (default) – sets dimension nodes at a selected location on an object.3. Specify the end nodes of the dimension based on the selected snap type:
· “nEarest snap gets object” – specify an object, the end nodes of the dimension will be the end points of the object; · “nEarest snap gets point” – specify the start and end nodes on the selected object.4. Place the dimension number. The dimension will be built.
Auxiliary markers
Construction markers appear when you select a certain linear dimension:
· CAD drawing DRAWING DESIGN 389 Parallel dimension is selected. · CAD drafting DRAWING DESIGN 390 Horizontal dimension is selected. · CAD software DRAWING DESIGN 391 Vertical dimension is selected.Linear dimension
CAD drawing DRAWING DESIGN 392Main menu: Dimensions – CAD drafting DRAWING DESIGN 393Linear.
CAD software DRAWING DESIGN 394Ribbon: Annotate – Dimensions – CAD drawing DRAWING DESIGN 395Linear.
CAD drafting DRAWING DESIGN 396Toolbar: Dimensions – CAD software DRAWING DESIGN 397Linear.
CAD drawing DRAWING DESIGN 398Command line: DIMLINEAR.
Linear dimensioning
1. Call the CAD drafting DRAWING DESIGN 399“Linear” command;
2. Specify the first node;
3. Indicate the second node;
4. Place the dimension number. Linear dimension will be created.
Radius
CAD software DRAWING DESIGN 400Main menu: Dimensions – CAD drawing DRAWING DESIGN 401Radius.
CAD drafting DRAWING DESIGN 402Ribbon: Annotate – Dimensions – CAD software DRAWING DESIGN 403Radius.
CAD drawing DRAWING DESIGN 404Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 405Radius.
CAD software DRAWING DESIGN 406Toolbar: Dimensions – CAD drawing DRAWING DESIGN 407Radius .
CAD drafting DRAWING DESIGN 408Context menu: Radial – when calling any dimension.
CAD software DRAWING DESIGN 409Command line: MCMDIMRAD, MDIMRAD.
CAD drawing DRAWING DESIGN 410CAD drafting DRAWING DESIGN 411CAD software DRAWING DESIGN 412
To apply a radial dimension, you must:
1. Select the “Radius” dimension;
2. Select an arc (circle), the dimension will snap to the arc;
3. Specify the insertion point.
Diameter
CAD drawing DRAWING DESIGN 413Main menu: Dimensions – CAD drafting DRAWING DESIGN 414Diameter.
CAD software DRAWING DESIGN 415Ribbon: Annotate – Dimensions – CAD drawing DRAWING DESIGN 416Diameter.
CAD drafting DRAWING DESIGN 417Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 418Diameter.
CAD drawing DRAWING DESIGN 419Toolbar: Dimensions – CAD drafting DRAWING DESIGN 420Diameter.
CAD software DRAWING DESIGN 421Context menu: Diametral – when calling any dimension.
CAD drawing DRAWING DESIGN 422Command line: MCMDIMDIA, MDIMDIA.
CAD drafting DRAWING DESIGN 423
To apply the dimension of the circle, you must:
1. Select the dimension “Diameter”;
2. Select the circle, the dimension snaps to the circle;
3. Pick an insertion point.
Large arc radius
CAD software DRAWING DESIGN 424Main menu: Dimensions – CAD drawing DRAWING DESIGN 425Large arc radius.
CAD drafting DRAWING DESIGN 426Ribbon: Annotate – Dimensions – CAD software DRAWING DESIGN 427Large arc radius.
CAD drawing DRAWING DESIGN 428Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 429Large arc radius.
CAD software DRAWING DESIGN 430Toolbar: Dimensions – CAD drawing DRAWING DESIGN 431Large arc radius.
CAD drafting DRAWING DESIGN 432Context menu: big RAdius – when calling any dimension.
CAD software DRAWING DESIGN 433Command line: MCDIMHRAD, DIMHRAD.
CAD drawing DRAWING DESIGN 434
To dimension a large arc radius, you need to:
1. Select the “Large arc radius” dimension;
3. Specify the insertion point of the arrow;
4. Specify the insertion point of the value on the arrow.
Arc length dimension
CAD drafting DRAWING DESIGN 435Main menu: Dimensions – CAD software DRAWING DESIGN 436Arc.
CAD drawing DRAWING DESIGN 437Ribbon: Annotate – Dimensions – CAD drafting DRAWING DESIGN 438Arc length.
CAD software DRAWING DESIGN 439Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 440Arc length dimension.
CAD drafting DRAWING DESIGN 441Toolbar: Dimensions – CAD software DRAWING DESIGN 442Arc length.
CAD drawing DRAWING DESIGN 443Context menu: arC – when calling any dimension.
CAD drafting DRAWING DESIGN 444Command line: MCMDIMARC, MDIMARC.
Arc dimension
CAD software DRAWING DESIGN 445
1. Select the arc dimension;
2. Select an arc (the arc dimension will snap to the arc);
Circle dimension
CAD drawing DRAWING DESIGN 446
2. Specify the starting point on the circle;
3. Specify the end point on the circle;
4. Specify the insertion point.
Ordinate dimension
CAD drafting DRAWING DESIGN 447Main menu: Dimensions – CAD software DRAWING DESIGN 448Ordinate dimension.
CAD drawing DRAWING DESIGN 449Ribbon: Annotate – Dimensions – CAD drafting DRAWING DESIGN 450Ordinate.
CAD software DRAWING DESIGN 451Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 452Ordinate dimension.
CAD drafting DRAWING DESIGN 453Toolbar: Dimensions – CAD software DRAWING DESIGN 454Ordinate dimension.
CAD drawing DRAWING DESIGN 455Context menu: Ordinate – when calling any dimension.
CAD drafting DRAWING DESIGN 456Command line: MCMDIMORD, MDIMORD.
CAD software DRAWING DESIGN 457
1. Call the “Ordinate dimension” command.
2. Pick the location of the first dimension of the ordinate chain.
CAD drawing DRAWING DESIGN 458
3. Select the first dimension you set. All subsequent dimensions will be snapped to it. If for some reason dimensioning has been completed (after the first dimension has been added), select the ordinate dimension (or autosize) again and specify the dimensioned.
CAD drafting DRAWING DESIGN 459
4. Sequentially specify the coordinates of the remaining dimensions.
CAD software DRAWING DESIGN 460
5. Press the “Esc” key to end the command.
Angle dimension
CAD drawing DRAWING DESIGN 461Main menu: Dimensions – CAD drafting DRAWING DESIGN 462Fill angle.
CAD software DRAWING DESIGN 463Ribbon: Annotate – Dimensions -CAD drawing DRAWING DESIGN 464Angular.
CAD drafting DRAWING DESIGN 465Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 466Angle dimension.
CAD drawing DRAWING DESIGN 467Toolbar: Dimensions – CAD drafting DRAWING DESIGN 468Angle dimension.
CAD software DRAWING DESIGN 469Toolbar: MCS Dimensions – CAD drawing DRAWING DESIGN 470Angle dimension.
CAD drafting DRAWING DESIGN 471Context menu: aNguLar – when calling any dimension.
CAD software DRAWING DESIGN 472Command line: MCMDIMANG, MDIMANG.
Create an angular dimension by specifying two line segments
CAD drawing DRAWING DESIGN 473CAD drafting DRAWING DESIGN 474CAD software DRAWING DESIGN 475
To apply an angular dimension, you must:
1. Select an angular dimension;
2. Select the first segment;
3. Select the second segment;
4. Pick an insertion point.
Angular dimension of hole centers
CAD drawing DRAWING DESIGN 476CAD drafting DRAWING DESIGN 477CAD software DRAWING DESIGN 478CAD drawing DRAWING DESIGN 479
To apply the angular dimension with the indication of the centers, you must:
2. Specify the center of the axial circle (on which the holes lie);
3. Pick the center of the first hole;
4. Pick the center of the second hole;
5. Pick an insertion point.
Dimensions Chain
CAD drafting DRAWING DESIGN 480Main menu: Dimensions – CAD software DRAWING DESIGN 481Dimensions Chain.
CAD drawing DRAWING DESIGN 482Ribbon: Annotate – Dimensions – CAD drafting DRAWING DESIGN 483Continue dimension.
CAD software DRAWING DESIGN 484Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 485Continue dimension.
CAD drafting DRAWING DESIGN 486Toolbar: Dimensions – CAD software DRAWING DESIGN 487Dimensions Chain.
CAD drawing DRAWING DESIGN 488Command line: MCCHAINCONT, CHAINCONT.
A chain of dimensions is a sequence of dimensions counted from the end of the previous dimension (the beginning of each new dimension coincides with the end of the previous one).
Dimension chains can be linear, ordinate, or angular. Before building the base dimensions, at least one linear, ordinate or angular dimension must be applied to the object.
Ordinate chain of dimensions
Note:
Constructing an ordinate chain of dimensions is similar to constructing ordinate dimensions.
1. Call the command;
2. Select the set ordinate dimension (the dimension from which the ordinate sizes will begin to form);
3. Construct the ordinate dimensions in sequence;
4. Press the “Enter” key to complete the construction.
Linear dimension chain
2. Select the set linear dimension (the dimension from which the chain of dimensions will begin to form);
CAD drafting DRAWING DESIGN 489
3. Specify the required number of anchor points;
CAD software DRAWING DESIGN 490
CAD drawing DRAWING DESIGN 491
Angle chain dimensions
2. Select the preset angular dimension (the dimension from which the chain of dimensions will begin to form);
CAD drafting DRAWING DESIGN 492
CAD software DRAWING DESIGN 493
CAD drawing DRAWING DESIGN 494
Baseline dimension
CAD drafting DRAWING DESIGN 495Main menu: Dimensions – CAD software DRAWING DESIGN 496Base dimension.
CAD drawing DRAWING DESIGN 497Ribbon: Annotate -Dimensions – CAD drafting DRAWING DESIGN 498Baseline dimension.
CAD software DRAWING DESIGN 499Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 500Baseline dimension.
CAD drafting DRAWING DESIGN 501Toolbar: Dimensions – CAD software DRAWING DESIGN 502Base dimension.
CAD drawing DRAWING DESIGN 503Context menu: Base – when calling any dimension.
CAD drafting DRAWING DESIGN 504Command line: MCCHAINBASE, CHAINBASE.
Base dimensions are a sequence of dimensions measured from one base point.
Base dimensions can be linear, ordinate, or angular. Before building the base dimensions, at least one linear, ordinate or angular dimension must be applied to the object.
Note:
The construction of an ordinate chain of dimensions is similar to construction ordinate dimension.
Linear base dimensions
2. Select the set dimension as the base (the dimension from which the base sizes will begin to form);
CAD software DRAWING DESIGN 505
3. Specify the required number of anchor points.
CAD drawing DRAWING DESIGN 506
CAD drafting DRAWING DESIGN 507
Note:
Each new dimension is set at a specified distance from the previous one. The value of the offset of the dimensions is set by the “Step” parameter in the base dimensions in the “Lines” tab of the “Modify dimension style” dialog.
Corner base dimensions
2. Select the preset angular dimension (the dimension from which the base dimensions will begin to form);
CAD software DRAWING DESIGN 508
CAD drawing DRAWING DESIGN 509
CAD drafting DRAWING DESIGN 510
Group dimension
CAD software DRAWING DESIGN 511Main menu: Dimensions – CAD drawing DRAWING DESIGN 512Group dimension.
CAD drafting DRAWING DESIGN 513Ribbon: Annotate – Dimensions – CAD software DRAWING DESIGN 514Group dimension.
CAD drawing DRAWING DESIGN 515Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 516Group dimension.
CAD software DRAWING DESIGN 517Toolbar: Dimensions – CAD drawing DRAWING DESIGN 518Group dimension.
CAD drafting DRAWING DESIGN 519Context menu: Grouped – when calling any dimension.
CAD software DRAWING DESIGN 520Command line: MCDIMGROUP, DIMGROUP.
CAD drawing DRAWING DESIGN 521
2. Select all the objects that will participate in creating the group dimension. To complete the selection press the “Enter” key;
3. Specify the location of the chain of dimensions.
If the setting “Arrows in chains” is set to “Point”, then when dimensioning a chain of small numerical dimensions, intersecting arrows are automatically replaced by dots.
CAD drafting DRAWING DESIGN 522CAD software DRAWING DESIGN 523
Offset dimension
CAD drawing DRAWING DESIGN 524Main menu: Dimensions – CAD drafting DRAWING DESIGN 525Offset dimension.
CAD software DRAWING DESIGN 526Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 527Offset dimension.
CAD drafting DRAWING DESIGN 528Toolbar: MCS Dimensions – CAD software DRAWING DESIGN 529Offset dimension.
CAD drawing DRAWING DESIGN 530Command line: MCDIMOFFSET, DIMOFFSET.
The command allows you to build a size similar to the contour of the selected object. Similarity size is indicated by an arc above the value.
1. Call the command CAD drafting DRAWING DESIGN 531“Offset dimension”.
2. Select the method for specifying the object: “sElection” or “frEe”. The “sElection” method is used in paper space when you need to dimension an object in an inactive viewport. In all other cases, the “frEe” method is used.
3. Specify the object from which the dimension will be built. The selected object can be specified: line, arc, spline, polyline, circle or ellipse.
CAD software DRAWING DESIGN 532
4. Specify the first insertion point (starting point of origin of the dimension) or press the “Space” (or RMB) to automatically add endpoints to the entire length of the object (does not work for closed objects).
CAD drawing DRAWING DESIGN 533
5. Specify the second insertion point (end point of origin of the dimension), if you have not pressed the “Space” (or RMB) key.
CAD drafting DRAWING DESIGN 534
6. Place the dimension leader in the drawing.
CAD software DRAWING DESIGN 535
7. Offset dimension will be built. The command will continue to work in a cyclic mode. Press the “Esc” key to exit cyclic mode.
Grips
1. Dimension value placement grip.
2. Extension line position grips.
3. Dimension endpoint grips.
CAD drawing DRAWING DESIGN 536
Edit dimension
CAD drafting DRAWING DESIGN 537LMB double click on the dimension.
CAD software DRAWING DESIGN 538Context menu: Properties – when calling any dimension.
CAD drawing DRAWING DESIGN 539Context menu: Edit – at the selected dimension.
CAD drafting DRAWING DESIGN 540Command line: MCFEDIT, FEDIT.
The dialog box looks like this:
CAD software DRAWING DESIGN 541
The window is divided into an area of text input fields with the name of the dimension type and a set of dimension design commands.
Additional auxiliary commands are available in the context menu of the dialog box text fields:
· History – the list contains the values previously entered in this field; · Recent – the list contains frequently used values when filling in this type of field; · Insert division- allows you to insert a division; · Pick from drawing – allows you to copy values from drawing objects; · Symbols – allows you to insert symbols from a list or from a symbol table; · etc.The presence of this or that command in the context menu depends on the purpose of the field.
The button in front of the dimension value input field allows you to add special characters to the dimension text.
CAD drawing DRAWING DESIGN 542
Buttons CAD drafting DRAWING DESIGN 543“First arrow” and CAD software DRAWING DESIGN 544“Second arrow” allow you to select the type of arrows. When you click on them, a list with images of arrow options appears.
CAD drawing DRAWING DESIGN 545
Button CAD drafting DRAWING DESIGN 546“Test on leader” – toggles the display mode of the text on the leader.
Button CAD software DRAWING DESIGN 547“Text in rectangle”- toggles the display mode of dimension text in a rectangle.
Button CAD drawing DRAWING DESIGN 548“Dimension value display scale”- provides a list of display scales for the size value. Default 1:1.
Button CAD drafting DRAWING DESIGN 549“Calculate value” – calls the calculator to calculate the value.
Button CAD software DRAWING DESIGN 550“Text style” – calls the text settings dialog box.
CAD drawing DRAWING DESIGN 551
Button CAD drafting DRAWING DESIGN 552“Match properties”- allows you to copy properties from an existing dimension in the drawing.
Buttons selection of bracketsCAD software DRAWING DESIGN 553CAD drawing DRAWING DESIGN 554CAD drafting DRAWING DESIGN 555 – allow you to set the dimension value in brackets.
Button “Method of recording tolerances” – provides a list of options for displaying tolerances.
CAD software DRAWING DESIGN 556
Button CAD drawing DRAWING DESIGN 557“Fit table” – provides the ability to customize tolerance.
CAD drafting DRAWING DESIGN 558CAD software DRAWING DESIGN 559CAD drawing DRAWING DESIGN 560
Button CAD drafting DRAWING DESIGN 561“Technical conditions”. Connects technical conditions and dimension.
Break dimension line
CAD software DRAWING DESIGN 562Main menu: Dimensions – CAD drawing DRAWING DESIGN 563Break dimension.
CAD drafting DRAWING DESIGN 564Main menu: Mechanical – Utilities – Breaks – CAD software DRAWING DESIGN 565Break dimension line.
CAD drawing DRAWING DESIGN 566Ribbon: Annotate – Dimensions -CAD drafting DRAWING DESIGN 567Break dimension line.
CAD software DRAWING DESIGN 568Ribbon: Mechanical – Utilities – CAD drawing DRAWING DESIGN 569Break dimension line.
CAD drafting DRAWING DESIGN 570Toolbar: Dimensions – CAD software DRAWING DESIGN 571Break dimension line.
CAD drawing DRAWING DESIGN 572Toolbar: MCS Breaks – CAD drafting DRAWING DESIGN 573Break dimension line.
CAD software DRAWING DESIGN 574Command line: MCDIMBREAK, DIMBREAK.
To create a dimension line break, you must:
· Call the command; · Select the dimension. If the size was selected before calling the command, you do not need to select it again; · Select two points by specifying a section of the dimension line to create a break; · The break will be made.CAD drawing DRAWING DESIGN 575
First point selection
CAD drafting DRAWING DESIGN 576
Second point selection
CAD software DRAWING DESIGN 577
Result
Restore dimension line
CAD drawing DRAWING DESIGN 578Main menu: Dimensions – CAD drafting DRAWING DESIGN 579Restore dimension.
CAD software DRAWING DESIGN 580Main menu: Mechanical – Utilities – Breaks – CAD drawing DRAWING DESIGN 581Unbreak dimension line.
CAD drafting DRAWING DESIGN 582Ribbon: Unnotate – Dimensions – CAD software DRAWING DESIGN 583Unbreak dimension line.
CAD drawing DRAWING DESIGN 584Ribbon: Mechanical – Utilities – CAD drafting DRAWING DESIGN 585Unbreak dimension line.
CAD software DRAWING DESIGN 586Toolbar: Dimensions – CAD drawing DRAWING DESIGN 587Unbreak dimension line.
CAD drafting DRAWING DESIGN 588Toolbar: MCS Breaks – CAD software DRAWING DESIGN 589Unbreak dimension line.
CAD drawing DRAWING DESIGN 590Command line: MCDIMUNBREAK, DIMUNBREAK.
To restore the dimension line, you must:
· Call the command; · Select the dimension. If the size was selected before calling the command, you do not need to select it again;; · The restoration will be done.Oblique dimension
CAD drafting DRAWING DESIGN 591Main menu: .
CAD software DRAWING DESIGN 592Ribbon: .
CAD drawing DRAWING DESIGN 593Command line: MCDIMOBLIQUE, DIMOBLIQUE.
The command allows you to skew the dimension.
1. Call the command CAD drafting DRAWING DESIGN 594“Oblique Dimension”.
2. Select the required dimensions. Press the “Enter” key to complete the selection.
3. Enter the angle of inclination and press the “Enter” key.
4. The selected dimensions will change the angle of inclination.
Arrange dimensions
CAD software DRAWING DESIGN 595Toolbar: “MCS Dimensions” – CAD drawing DRAWING DESIGN 596Arrange dimensions.
CAD drafting DRAWING DESIGN 597Command line: MCDIMARRANGE.
To arrange, you need:
CAD software DRAWING DESIGN 598
2. Indicate the dimensions to be aligned;
CAD drawing DRAWING DESIGN 599
3. Confirm the selection with the “Enter” key;
4. Pick a new location for the dimension group.
CAD drafting DRAWING DESIGN 600
Fit list
CAD software DRAWING DESIGN 601Toolbar: MCS Dimensions – CAD drawing DRAWING DESIGN 602Fit list.
CAD drafting DRAWING DESIGN 603Command line: MCFITLIST.
The command is designed to create an automatically updated table by dimensions in the drawing.
2. Indicate the position of the table of maximum deviations in the drawing;
3. The table will be automatically filled in. The table is updated automatically when you delete, add or edit dimensions.
CAD software DRAWING DESIGN 604By double clicking, you can edit the tolerance table. For example, specify an alphanumeric designation for a size tolerance.
CAD drawing DRAWING DESIGN 605
Symbols
Designation of surface texture
CAD drafting DRAWING DESIGN 606Main menu: Mechanical – Symbols – Surface Texture – CAD software DRAWING DESIGN 607Surface texture.
CAD drawing DRAWING DESIGN 608Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 609Surface texture.
CAD software DRAWING DESIGN 610Toolbar: CAD drawing DRAWING DESIGN 611Surface texture (toolbar “MCS Symbols”).
CAD drafting DRAWING DESIGN 612Command line: MCSURF.
This command sets the sign of surface texture.
1. Call command;
2. Pick a point on the object. When specifying the location of the specified segment is highlighted;
3. Specify the size and position of the callout. The sign is positioned normal to the surface. To place a character without a callout, press the spacebar;
4. Indicate the position of the roughness mark on the shelf. The editing dialog “Surface texture”;
5. In the “Surface texture” dialog, specify the necessary parameters and click the “OK” button;
Dialog edit
CAD software DRAWING DESIGN 613
Fields (4 field) – Allows you to enter surface texture values and text above and below the shelf.
In the input field through the context menu, you can select the roughness of the series:
CAD drawing DRAWING DESIGN 614
Button “Surface lay and orientation” – allows you to choose the surface texture orientation.
Button CAD drafting DRAWING DESIGN 615“Match properties” – allows you to copy design properties from another surface texture.
Button CAD software DRAWING DESIGN 616“Add extension line” – allows you to add an additional extension line.
Button CAD drawing DRAWING DESIGN 617 “Dimension dependent” – allows you to select a size for setting dependencies. The amount of roughness can be set automatically depending on the quality of the specified size. To do this, click on the “Dimension dependent” icon in the “Surface texture” dialog box and select the size with the quality mark.
Button CAD drafting DRAWING DESIGN 618“Arrow type” – allows you to set the appearance of the callout arrow.
Processing switch – controls the display of the processing method: CAD software DRAWING DESIGN 619Any manufacturing process permitted, CAD drawing DRAWING DESIGN 620Material should be removed, CAD drafting DRAWING DESIGN 621Material should not be removed.
Character switch “By contour” – controls the display of the symbol “By contour”.
Character switch “Surface texture not specified” – controls the display of the symbol “Surface texture not specified”.
Character switch “Braked sign” – controls the display of the symbol “Braked sign”.
Switch “Set next” – Active when building a roughness symbol. When turned on, the switch goes into the mode of continuous construction of roughness symbols with values equal to the first.
Editing with grips
Designation surface texture without callouts
1. Grip flip; 2. Grip turn; 3. Grip movement.CAD software DRAWING DESIGN 622
Designation surface texture with callouts
1. Grip add callout line; 2. Grip of moving the position of surface texture marking along the shelf; 3. Shelf reflection grip; 4. Arrow type grip; 5. Grip move callouts; 6. Grip moving shelves.CAD drawing DRAWING DESIGN 623
Designation of surface texture (old)
CAD drafting DRAWING DESIGN 624Main menu: Mechanical – Symbols – Surface Texture- CAD software DRAWING DESIGN 625Surface texture (old).
CAD drawing DRAWING DESIGN 626Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 627Surface texture (old).
CAD software DRAWING DESIGN 628Toolbar: CAD drawing DRAWING DESIGN 629Surface texture (old) (toolbar “MCS Symbols”).
CAD drafting DRAWING DESIGN 630Command line: MCSURFOLD.
The command sets the sign of the surface texture of previous versions.
1. Call command;
2. Pick a point on the object. When specifying a location, the specified segment is highlighted;
3. Specify the size and position of the callout. The sign is positioned normal to the surface. To place a character without a callout, press the “Space”;
4. Specify the position of the surface texture sign on the shelf. The “Surface texture” edit dialog opens;
5. In the dialog “Surface texture” specify the necessary parameters and click “OK”;
Dialog edit
CAD software DRAWING DESIGN 631
Fields (4 fields) – allows you to enter roughness values and text above and below the shelf.
In the input field through the context menu, you can select the surface texture from the row:
CAD drawing DRAWING DESIGN 632
Button CAD drafting DRAWING DESIGN 633“Match properties” – allows you to copy design properties from another surface texture.
Button CAD software DRAWING DESIGN 634“Add extension line” – allows you to add an additional extension line.
Button CAD drawing DRAWING DESIGN 635 “Dimension dependent” – allows you to select a size for setting dependencies. The amount of roughness can be set automatically depending on the quality of the specified size. To do this, click on the “Dimension dependent” icon in the “Surface texture” dialog box and select the size with the quality mark.
Processing switch – controls the display of the processing method: CAD drafting DRAWING DESIGN 636Any manufacturing process permitted, CAD software DRAWING DESIGN 637Material should be removed, CAD drawing DRAWING DESIGN 638Material should not be removed.
Grips
Designation surface texture without extension line
1. Grip flip; 2. Grip turn; 3. Grip moving.CAD drafting DRAWING DESIGN 639
Designation surface texture with extension line
1. Grip add extension line; 2. Grip of moving the position of surface texture marking along the shelf; 3. Shelf reflection grip; 4. Arrow type grip; 5. Grip relocation extension line; 6. Grip moving shelves.CAD software DRAWING DESIGN 640
Convert old surface texture symbol
CAD drawing DRAWING DESIGN 641Main menu: Mechanical – Symbols – Surface Texture – CAD drafting DRAWING DESIGN 642Convert old surface texture symbol.
CAD software DRAWING DESIGN 643Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 644Convert old surface texture symbol.
CAD drafting DRAWING DESIGN 645Toolbar: CAD software DRAWING DESIGN 646Convert old surface texture symbol (toolbar “MCS Symbols”).
CAD drawing DRAWING DESIGN 647Command line: MCSURCONV.
The command converts the old character surface texture to a new one.
1. Call command;
2. Specify all the required old surface texture characters for the transformation. To complete the selection, press the “Enter” key;
3. The command converts old surface texture symbols to new ones.
Feature control frame
CAD drafting DRAWING DESIGN 648Main menu: Mechanical – Symbols – CAD software DRAWING DESIGN 649Feature control frame.
CAD drawing DRAWING DESIGN 650Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 651Feature control frame.
CAD software DRAWING DESIGN 652Toolbar: CAD drawing DRAWING DESIGN 653Feature control frame (toolbar “MCS Symbols”).
CAD drafting DRAWING DESIGN 654Command line: MCTOL.
The tolerance can be set depending on the quality of the specified size.
1. Call command.
2. Pick a point on the object. When you select a base surface, the graphic element is highlighted in green.
CAD software DRAWING DESIGN 655
3. Point to the next point to pin the line of the mark. The sign line is drawn along the normal to the specified surface.
CAD drawing DRAWING DESIGN 656
The sign line may extend from the corner of the frame or from the middle of its side. To control the display of these elements, you must call the context menu and select “Sides” or “Angles”.
Sides
Angles
CAD drafting DRAWING DESIGN 657
CAD software DRAWING DESIGN 658
When you select the “Base” line in the context menu, a triangle symbol is drawn on the leader.
When you select the “Tolerance” line in the context menu, an arrow is drawn on the callout.
Base
Tolerance
CAD drawing DRAWING DESIGN 659
CAD drafting DRAWING DESIGN 660
4. Next, place a tolerance mark in the place you need. To do this, using the mouse cursor, specify new points in the drawing. To undo the last action, use the “Back” command from the context menu. To finish, press the “Enter” key, a dialog box will appear “Form&plane position tolerance”.
CAD software DRAWING DESIGN 661
5. In the “Form&plane position tolerance” dialog box, enter the required parameters and click the “OK” button.
CAD drawing DRAWING DESIGN 662
6. The tolerance of the form and plane will be built.
CAD drafting DRAWING DESIGN 663
Dialog edit
The editing dialog consists of a toolbar and a workspace.
CAD software DRAWING DESIGN 664
Workspace
The working area of the dialog box is a list of 4 lines, allowing add header and form 3 rows of values in the tolerance.
Lines are divided into 4 columns:
· Type of tolerance columnThe field of this column allows you to add a type of tolerance. In each field, you can enter 2 types of tolerance by selecting the left or right button of the field.
CAD drawing DRAWING DESIGN 665
When you click on the buttons, a form for selecting the type of tolerance appears.
CAD drafting DRAWING DESIGN 666
· Column of tolerance deviationThe tolerance deviation value is entered in the fields of this column. The tolerance deviation value can be taken from the “Standard values” when the context menu is opened in the input field.
CAD software DRAWING DESIGN 667
· Base designation columnIn the fields of this column, the notation for bases is entered.
· Column notesNotes are entered in the fields in this column.
Dialog Toolbar
CAD drawing DRAWING DESIGN 668Dependent tolerance – the command inserts the designation “Dependent tolerance” in the columns “tolerance deviation values” and “bases designation”.
CAD drafting DRAWING DESIGN 669Extended tolerance range – the command inserts the symbol “Extended tolerance range” in the column “tolerance deviation values”.
CAD software DRAWING DESIGN 670Extended tolerance range – the command inserts the symbol “Non-rigid part” in the column “tolerance deviation values”.
CAD drawing DRAWING DESIGN 671Extended tolerance range – the command inserts the symbol “Least material requirement” in the column “tolerance deviation values”.
CAD drafting DRAWING DESIGN 672Extended tolerance range – the command inserts the symbol “Unequally-disposed modifier” in the column “tolerance deviation values”.
CAD software DRAWING DESIGN 673Diameter – the command inserts the designation “Diameter” in the column “tolerance deviation values”.
CAD drawing DRAWING DESIGN 674Set additional leader – the command allows you to set an additional leader for an editable tolerance.
CAD drafting DRAWING DESIGN 675Set additional base – the command allows you to set an additional base for an editable tolerance.
To install additional callouts, you must:
1. Call command; 2. Select object; 3. Bring the callout line to the tolerance mark.CAD software DRAWING DESIGN 676Specify base – the command allows you to specify the base, to do this, call the command and point to the previously placed base symbol on the drawing. The letter designation of the base will be automatically applied in the current input field. When linking the base designation in the drawing, the cursor must be in the base designation input field.
CAD drawing DRAWING DESIGN 677Insert base denotation – allows you to insert a base symbol when it is missing in the drawing.
CAD drafting DRAWING DESIGN 678Linked to dimensions – the command serves to fill the deviation value depending on the quality of the specified size.
To fill the value of the deviation is necessary:
1. Select the type of deviation. 2. Call command “Linked to dimensions”. 3. Indicate the size with the assigned quality. A link will be created, otherwise, if the qualification is not affixed, a corresponding message will be displayed.CAD software DRAWING DESIGN 679
4. From the context menu of the deviation value input field, select “Relative geometry precission”.“Relative geometry precission” has 3 degrees: Normal, Increased and High.
CAD drawing DRAWING DESIGN 680
Note:
If a mark for the shape deviation mark has been applied to the size with the specified quality, the context menu bar of the tolerance value “Relative geometry precission” will be active.
The relationship with the size is NOT associative: the tolerance field established relative to the size will NOT change along with the size value. Moreover, all information about the connection is lost after closing the edit edit form admission dialog.
Thus, if it is necessary to select the value for admission again, the connection will have to be imposed again.
CAD drafting DRAWING DESIGN 681Match properties – this command allows you to copy values from the tolerance already entered.
CAD software DRAWING DESIGN 682Insert separator – the command inserts a separator into the database designation field.
Switch Automatic sorting – manages automatic database sorting. When you turn on the designation of bases are put alphabetically, taking into account the previously used letter designations of species, sections, sections.
Note:
Deleting symbols of basic surfaces or drawing additional designations of types, sections, sections will lead to automatic re-sorting of all associated text symbols, including references to them in the technical requirements.
CAD drawing DRAWING DESIGN 683CAD drafting DRAWING DESIGN 684
Put down two designations of the basic elements: “A”, “B”. Added view “A” to drawing. The designation of bases was adjusted automatically.
Grips
1. Grip moving arrows.
2. Arrow type grip.
3. Grip move the nodes of the arrow (maybe several).
4. Grip joining the sign. Allows you to change the point of attachment of the leader line to the sign both in the corners and along the sides.
5. Sign move grip.
CAD software DRAWING DESIGN 685
Datum identifier
CAD drawing DRAWING DESIGN 686Main menu: Mechanical – Symbols – CAD drafting DRAWING DESIGN 687Datum identifier.
CAD software DRAWING DESIGN 688Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 689Datum identifier.
CAD drafting DRAWING DESIGN 690Toolbar: CAD software DRAWING DESIGN 691Datum identifier (toolbar “MCS Symbols”).
CAD drawing DRAWING DESIGN 692Command line: MCDATID.
1. Call command;
2. Pick a location point. When you select a base surface, the graphic element is highlighted in green;
3. Indicate the position of the mark. The designation of the base will automatically select a free letter.
CAD drafting DRAWING DESIGN 693
Dialog edit
CAD software DRAWING DESIGN 694
Field “Identifier” – input letter field notation.
Switch “Automatic sorting” – manages auto sort identifier. If the switch is on, the letter is taken automatically from the free and the “Identifier” field is inactive.
Switch “Attach” – allows you to attach the base to the object. To attach the base to the object, you must enable the “Attach” switch, select the anchor object and set the new position of the base character.
Editing with grips
1. Grip Rotate – allows you to rotate the sign left or right 90 degrees. 2. Grip direction of the callout or handle move the base. If the attachment base, the knob moves the entire base relative to the attached object. If the base is detached, then the knob controls the direction of the leader line. 3. Grip disconnection – when using this handle, the base is disconnected from the object. 4. Grip select the type of arrow – allows you to select the type of arrow from the drop-down list.CAD drawing DRAWING DESIGN 695
Views, cuts, sections
Views
CAD drafting DRAWING DESIGN 696Main menu: Mechanical – Symbols – Views, Sections – CAD software DRAWING DESIGN 697View.
CAD drawing DRAWING DESIGN 698Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 699View.
CAD software DRAWING DESIGN 700Toolbar: CAD drawing DRAWING DESIGN 701View (toolbar “MCS Symbols”).
CAD drafting DRAWING DESIGN 702Command line: MCVIEW.
1. Call command;
2. Specify the insertion point of view;
3. Specify the direction of the view arrow. A dialog box appears “View”;
4. In the dialog “View” enter your settings. Press button “OK”;
CAD software DRAWING DESIGN 703
5. Place the view symbol in the drawing.
Note:
When you transfer the designation by means of nanoCAD, the integrity of the data in terms of specifying the mutual location and specifying the zones of the drawing can be violated. In this case, you must run the “Update” command.
Editing
Editing is done by double-clicking the LMB on any element of the symbol. This opens a dialog box “Views, cuts, sections”, where you can change the required parameters.
Section
CAD drawing DRAWING DESIGN 704Main menu: Mechanical – Symbols – Views, Sections – CAD drafting DRAWING DESIGN 705Sections.
CAD software DRAWING DESIGN 706Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 707Sections.
CAD drafting DRAWING DESIGN 708Toolbar: CAD software DRAWING DESIGN 709Sections (toolbar “MCS Symbols”).
CAD drawing DRAWING DESIGN 710Command line: MCSECT.
1. Call command;
2. Select the path type: Arc or Segment. Each type has its own order of construction;
· Type Segment. Allows you to create a section as a polyline; · Specify the first point of the section; · Specify the subsequent cut points. To finish entering points, press “Enter”; · Type Arc. Creates an arcuate cut; · Select the desired arc construction method: Arc (3 points), Arc (2 points and bend), Arc (2 points and center); · Draw an arc in accordance with the selection.3. Select the direction of the cut arrows. A dialog box appears “Section”;
4. In the dialog box, enter the required parameters. Press the button “OK”;
CAD drafting DRAWING DESIGN 711
5. Insert the section symbol in the drawing.
Note:
Editing
Editing is done by double-clicking the LMB on any element of the symbol. This opens the “Views, cuts, sections” dialog box, where you can change the required parameters.
Scale fragment view
CAD software DRAWING DESIGN 712Main menu: Mechanical – Symbols – Views, Sections – CAD drawing DRAWING DESIGN 713Scale fragment view.
CAD drafting DRAWING DESIGN 714Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 715Scale fragment view.
CAD drawing DRAWING DESIGN 716Toolbar: CAD drafting DRAWING DESIGN 717Scale fragment view (toolbar “MCS Symbols”).
CAD software DRAWING DESIGN 718Command line: MCEVIEW.
1. Call command;
2. Specify the center of the circle (rectangle);
3. Select the type of contour: Circle or Rectangle;
4. Specify the size of the circle (rectangle);
5. Specify the position of the symbol shelf. A dialog box appears “Views, cuts, sections”;
6. In the dialog box, fill in the required fields. Press “OK”;
CAD drawing DRAWING DESIGN 719
7. Specify the insertion point of the symbol.
CAD drafting DRAWING DESIGN 720
Placing an enlarged view of the selection
Note:
Editing
View and section label
CAD software DRAWING DESIGN 721Main menu: Mechanical – Symbols – Views, Sections- CAD drawing DRAWING DESIGN 722View and section label.
CAD drafting DRAWING DESIGN 723Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 724View and section label.
CAD drawing DRAWING DESIGN 725Toolbar: CAD drafting DRAWING DESIGN 726View and section label (toolbar “MCS Symbols”).
CAD software DRAWING DESIGN 727Command line: MCVSDESC.
Important!
You cannot insert a view (section) symbol separately from the element itself in automatic sorting mode.
1. Call command;
2. Specify the insertion point of the symbol. A dialog box appears “Views, cuts, sections”;
2. In the dialog box, fill in the required fields. Press the button “OK”;
CAD drawing DRAWING DESIGN 728
Editing
Sort views and sections…
CAD drafting DRAWING DESIGN 729Main menu: Mechanical – Symbols – Views, Sections – CAD software DRAWING DESIGN 730Sort views and sections….
CAD drawing DRAWING DESIGN 731Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 732Sort views and sections….
CAD software DRAWING DESIGN 733Toolbar: CAD drawing DRAWING DESIGN 734Sort views and sections… (toolbar “MCS Symbols”).
CAD drafting DRAWING DESIGN 735Command line: MCSORT.
Important!
For the command to work, all symbols in the drawing must be bound to objects.
This command is used if views, sections, and sections were built without auto-sorting.
1. Call command.
2. Will be sorting types, cuts and sections (especially designated species, then the cuts-section).
Dialog for editing views, cuts, sections
One of the features of nanoCAD Mechanica 23 in the application of symbols of types, sections, sections is to support the functions of design control. We have implemented alphabetical arrangement of the letter designation, automatic generation of the zone designation and the sheet in the drawing.
The view, section, section, and detail symbol command allows you to dynamically link a symbol to information in technical requirements.
CAD software DRAWING DESIGN 736
Letter and index input fields – allows you to enter letters and indexes of views, cuts, and sections.
When auto sort is enabled, fields are not editable.
With auto sort enabled, it is possible to see previously used letters. To do this, place the cursor in the input field of the letter and click RMB, a dialog box with a list of the presented letters will appear.
CAD drawing DRAWING DESIGN 737
List “Scale” – allows you to assign a scale.
Switch “Turned” and “Unfolded” – allow to insert to the symbol characters are rotated and deployed.
Field “Zone” – allows you to specify a reference to a zone.
Field “Sheet” – allows you to specify a reference to the sheet number.
You can configure the type of the sheet number reference designation record in the setup “Sheet template”.
Group switch designation type – switches the symbol type from “Cut” to “Section” and back.
Switch “Automatic sorting” – controls the automatic designation of views, sections, and sections.
If the switch “Automatic sorting” is enabled, first of all the views are indicated, then the sections.
To comply with the automatic sorting rule, you must specify whether the specified symbol belongs to a particular type of symbol.
In the global settings of the system, the user can enable the function of automatic placement of zones in the drawing – in this case, when you move the designation to another place in the drawing or change the format of the frame, the designation of zones in all sheets will be automatically changed.
Switch “Add zone automatically” – automatic zone detection.
Switch “Automatically add sheet number” – automatic detection of the sheet.
Switch “Insert designation” – controls the ability to insert a text symbol for a view, cut, section .
Welds
Welding…CAD drafting DRAWING DESIGN 738Main menu: Mechanical – Symbols – Permanent connection – CAD software DRAWING DESIGN 739Welding….
CAD drawing DRAWING DESIGN 740Toolbar: “Symbols” – CAD drafting DRAWING DESIGN 741Welding….
CAD software DRAWING DESIGN 742Command line: MCISOWELD.
Setting notes refer to welding.
CAD drawing DRAWING DESIGN 743
The dialog box consists of three tabs:
General
On the tab, the graphical display and fill in the drawing note.
CAD drafting DRAWING DESIGN 744
For convenient entry process, you can use Process list.
Process list poddrerzhivaet multiple selection processes.
CAD software DRAWING DESIGN 745
Above side
Tab necessary to fill in the values above the side
The type of weld and its parameters.
CAD drawing DRAWING DESIGN 746
Below side
Tab necessary to fill in the values below the side
CAD drafting DRAWING DESIGN 747
Simple welding
CAD software DRAWING DESIGN 748Main menu: Mechanical – Symbols – Permanent connection – CAD drawing DRAWING DESIGN 749Simple welding.
CAD drafting DRAWING DESIGN 750Toolbar: “Symbols” – CAD software DRAWING DESIGN 751Simple welding.
CAD drawing DRAWING DESIGN 752Command line: MCWLEG.
This command is used to render the weld leg between two intersecting segments.
1. Enter the first rib. 2. Enter the second rib. 3. Press “Enter” or right mouse button to exit the cyclic command.Weld seam
CAD drafting DRAWING DESIGN 753Main menu: Mechanical – Symbols – Permanent Connection- CAD software DRAWING DESIGN 754Weld seam.
CAD drawing DRAWING DESIGN 755Toolbar: “Symbols” – CAD drafting DRAWING DESIGN 756Weld seam.
CAD software DRAWING DESIGN 757Command line: MCWELD.
1. In the dialog box “Weld seam” press the button corresponding to the desired type of weld. Click OK.CAD drawing DRAWING DESIGN 758
2. Specify the first point of the circuit (or P – polyline, C – circle M – magnet). 3. Specify the next point of the contour (or L – line A – arc, C – close, U – rollback, M – a method for constructing the arc). 4. Press Enter or right mouse button to exit the cyclic command.In the dialog box are available 16 types of welds. Each type of weld corresponds to the button with his picture. To select the desired type of seam, press the button and confirm with the OK button.
Construction of the circuit is made by the following methods:
L – via line: construction of straight segments of the weld points introduced;
A – by arc: construction of the weld arc segments in three points;
C – close: automatic generation of the last segment, closing the main line of the weld;
U – recoil: undo the last segment of the weld;
M – a method for constructing the arc: T – tangentially, S – by three points.
Button CAD drafting DRAWING DESIGN 759Side hatch allows you to select the direction of the hatch.
Change the direction of the hatch, you can select the “handle” the reflection side hatch:
CAD software DRAWING DESIGN 760
Fixed joint
CAD drawing DRAWING DESIGN 761Main menu: Mechanical – Symbols – Permanent connection – CAD drafting DRAWING DESIGN 762Fixed joint.
CAD software DRAWING DESIGN 763Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 764Fixed joint.
CAD drafting DRAWING DESIGN 765Toolbar: “MCSSymbols” – CAD software DRAWING DESIGN 766Fixed joint .
CAD drawing DRAWING DESIGN 767Command line: MCFIX.
1. Call the command CAD drafting DRAWING DESIGN 768“Fixed joint”.
2. Indicate the place of the fixed joint.
CAD software DRAWING DESIGN 769
3. Pick a break point.
CAD drawing DRAWING DESIGN 770
4. Specify the end point of the leader or press the “Enter” key, then the end point of the leader will be the break point. The “Joints” editing dialog will open.
CAD drafting DRAWING DESIGN 771
5. Set the type of joint in the “Joints” editing dialog and confirm the setting with the “OK” button.
6. The Fixed joint will be built.
CAD software DRAWING DESIGN 772
Dialog
Important!
When you select the fixed joint “Soldired Joint Leg” or “Weld point”, you cannot call the dialog from the object for editing.
CAD drawing DRAWING DESIGN 773
The editing dialog contains additional commands and two tabs: “Simple representation” and “Full representation”.
· CAD drafting DRAWING DESIGN 774Technical conditions – the command associates a designation with a item of technical conditions. · CAD software DRAWING DESIGN 775Place spot welds – the command is intended for insertion of weld point elevations in the drawing. · CAD drawing DRAWING DESIGN 776Along closed contour – the command is intended to add the symbol “Joint along closed contour” to the connection designation. · The “Simple representation” tab allows you to select the type of fixed joint.CAD drafting DRAWING DESIGN 777
The following designations for fixed joints are available:
Seam denotation
Soldering Pasting together Clamps, type 1CAD software DRAWING DESIGN 778
CAD drawing DRAWING DESIGN 779
CAD drafting DRAWING DESIGN 780
CAD software DRAWING DESIGN 781
Clamps, type 2 Lacing Soldired Joint Leg Weld pointCAD drawing DRAWING DESIGN 782
CAD drafting DRAWING DESIGN 783
CAD software DRAWING DESIGN 784
CAD drawing DRAWING DESIGN 785
Depending on the selected type, the “Full representation” tab will be available. · The “Full representation” tab allows you to customize the fixed joint symbol.CAD drafting DRAWING DESIGN 786
Input fields and graphic elements are edited on the tab. To edit input fields and turn on / off graphic elements, click LMB on them. When editing input fields, dialogs for editing fields appear, containing an input field and additional commands.
1. Graphic element “Field joint”.
CAD software DRAWING DESIGN 787
2. Graphic element “Joint along closed contour”.
CAD drawing DRAWING DESIGN 788
3. Number designation input field.
CAD drafting DRAWING DESIGN 789
The editing dialog contains:
· Value input field. · Command CAD software DRAWING DESIGN 790Technical conditions – associates value with a technical conditions item. · Command CAD drawing DRAWING DESIGN 791“Sum” – the number of welded seams with the same number is counted. Deleting or changing a seam number designation is automatically displayed in the full designation for that joint number. · Command CAD drafting DRAWING DESIGN 792“Copy properties” – allows you to copy properties from an existing dimension in the drawing. · Command CAD software DRAWING DESIGN 793“OK” – closes the dialog, saving changes. · Command CAD drawing DRAWING DESIGN 794“Cancel” – closes the dialog without saving changes.4. Input field for the designation of the control complex or the seam control category.
CAD drafting DRAWING DESIGN 795
· Value input field. · Command CAD software DRAWING DESIGN 796“Copy properties” – allows you to copy properties from an existing dimension in the drawing. · Command CAD drawing DRAWING DESIGN 797“OK” – closes the dialog, saving changes. · Command CAD drafting DRAWING DESIGN 798“Cancel” – closes the dialog without saving changes.5. Input fields for the symbol.
CAD software DRAWING DESIGN 799
· Value input field. · Buttons for quick insertion of special symbols for fixed joint:CAD drawing DRAWING DESIGN 800 – Soldered leg;
CAD drafting DRAWING DESIGN 801 – Remove weld reinforcement;
CAD software DRAWING DESIGN 802 – Treat seam overflows and unevenness with graded junction to parent metal;
CAD drawing DRAWING DESIGN 803 – Discrete double unfaced seam;
CAD drafting DRAWING DESIGN 804 – Discrete double faced seam;
CAD software DRAWING DESIGN 805 – Opened contour seam.
· Command CAD drawing DRAWING DESIGN 806“Copy properties” – allows you to copy properties from an existing dimension in the drawing. · Command CAD drafting DRAWING DESIGN 807“OK” – closes the dialog, saving changes. · Command CAD software DRAWING DESIGN 808“Cancel” – closes the dialog without saving changes.Properties
Seam denotation:
· Text above self of leader · Text under self of leader · Text above leader · Text under leader · Enable calculate joints · Count of joints · Field joint · Joint along closed contourSoldering, Lacing, Clamps type 1, Clamps type 1, Pasting together:
· Joint along closed contour · TR item numberGrips
Seam denotation:
1. Move grips – Move the endpoints of the parts of the weld symbol.
2. “Mirror arrow side” grip – changes the side of the arrow.
3. “Weld seam properties” grip – opens a list of available graphic elements. In the list, you can enable or disable the display.
CAD drawing DRAWING DESIGN 809
2. Joint type selection grip – opens a drop-down list for selecting a joint type.
CAD drafting DRAWING DESIGN 810
CAD software DRAWING DESIGN 811
Soldered Joint Leg:1. Move grip – allows you to move the leg.
2. Grips “Change leg size” – allow you to change the size of the leg.
CAD drawing DRAWING DESIGN 812
Weld point:
1. Move grip – Allows you to move the weld point in the drawing.
CAD drafting DRAWING DESIGN 813
Simplified weld joint
CAD software DRAWING DESIGN 814Main menu: Mechanical – Symbols – Permanent connection – CAD drawing DRAWING DESIGN 815Simplified weld joint.
CAD drafting DRAWING DESIGN 816Toolbar: “Symbols” – CAD software DRAWING DESIGN 817Simplified weld joint.
CAD drawing DRAWING DESIGN 818Command line: MCWJ.
CAD drafting DRAWING DESIGN 819
Important!
As the rods and plates can be used primitives nanoCAD: circle and polyline (a special case polylines: rectangles, and polygons).
To use the unit as a plate or an object from the database, you must use when choosing an instrument Magnet plate for constructing the circuit plate.
Primitives must be tangent to each other.
Type: two rods overlap joints.
To add an overlap joint:
1. Call the command. 2. Select the drawing first rod . 3. Select the second rod. 4. To select the direction of one-way seam weld placement.CAD software DRAWING DESIGN 820Two-way joint.
CAD drawing DRAWING DESIGN 821One-way joint.
CAD drafting DRAWING DESIGN 822Two-way joint.
Type: T-connection between two rods..
To add a T-joints:
1. Call the command. 2. Select the drawing first plate . 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD software DRAWING DESIGN 823Two-way joint.
CAD drawing DRAWING DESIGN 824One-way joint.
CAD drafting DRAWING DESIGN 825Two-way joint.
CAD software DRAWING DESIGN 826Two-way joint.
Type: two plates overlap joints.
1. Call the command. 2. Select the drawing first plate. 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD drawing DRAWING DESIGN 827Corner seam-sided.
CAD drafting DRAWING DESIGN 828Corner sided seam.
Type: Butt joint of two plates.
To add a butt joint:
1. Call the command. 2. Select the drawing first plate . 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD software DRAWING DESIGN 829One-way butt weld.
CAD drawing DRAWING DESIGN 830Sided butt weld.
CAD drafting DRAWING DESIGN 831One-way butt weld.
CAD software DRAWING DESIGN 832Sided butt weld.
Type: Angular connection of two plates.
1. Call the command. 2. Select the drawing first plate. 3. Select the second plate. 4. To select the direction of one-way seam weld placement.CAD drawing DRAWING DESIGN 833Corner seam-sided.
CAD drafting DRAWING DESIGN 834Corner seam-sided.
Edge preparation
CAD software DRAWING DESIGN 835Main menu: Mechanical – Symbols – Permanent connection- CAD drawing DRAWING DESIGN 836Edge preparation.
CAD drafting DRAWING DESIGN 837Toolbar: “Symbols” – CAD software DRAWING DESIGN 838Edge preparation.
CAD drawing DRAWING DESIGN 839Command line: MCEDGEPREPARATION.
Provides cutting edge parts in the drawing.
CAD drafting DRAWING DESIGN 840
Elements of the dialogue:
1)The list of standard cutting edges for welding;
CAD software DRAWING DESIGN 841
2) List of types of connection plates welded: Butt, T-bar, angle;
CAD drawing DRAWING DESIGN 842
3) List of connection options;
CAD drafting DRAWING DESIGN 843
4) Filter the list by the thickness of the plates;
CAD software DRAWING DESIGN 844
When you enter a numeric value thickness dialogue filters only those types of cutting edges, matching the thickness of the part. The filter is made by pressing the CAD drawing DRAWING DESIGN 845“Apply filter”, or by pressing Enter. The value of the thickness in the filter can be measured by the meter to be launched on the CAD drafting DRAWING DESIGN 846“Measure”.
5) Zoom menu created design elements
CAD software DRAWING DESIGN 847
Menu is disabled if Auto is enabled check box. In this case, the scale created by the size and design elements set to the current scale decoration.
If you turn off Auto box, it will be possible to create a drawing cutting edges in arbitrary scale is selected in this dialog.
Operation
For the cutting edges must be vyponit following:
1. Select the type of connection: butt, T-bar or angle; 2. If necessary, filter preparation method edges, depending on their thickness. This can be done directly by entering the minimum thickness of the edges, or by measuring the drawing; 3. Determine the scope of dimension lines; 4. Double-click method of preparing the edges; 5. Specify the edge of the weld joint. Depending on the method of preparation is required to select the left and right edges alternately.CAD drawing DRAWING DESIGN 848
When you create a cutting edge bevel one team will cycle to offer select sites for the creation of such ramps.
When you create a cutting edge bevel two team provides consistently indicate bevel for one, and then to other parts of the joint.
Important!
The plates can be used as primitives nanoCAD, as well as objects nanoCAD Mechanica.
Turn inserted edge welded connection can hold down Shift. It is necessary to include the “Object Snap” mode and “nearest” or in the settings nanoCAD Mechanica against the item “Connections” Nearest “automatically when you insert objects” put “Yes”.
Marking symbol
CAD drafting DRAWING DESIGN 849Main menu: Mechanical – Symbols – CAD software DRAWING DESIGN 850Marking symbol.
CAD drawing DRAWING DESIGN 851Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 852Marking symbol.
CAD software DRAWING DESIGN 853Toolbar: CAD drawing DRAWING DESIGN 854Marking symbol (toolbar “MCS Symbols”).
CAD drafting DRAWING DESIGN 855Command line: MCMARK.
1. Call command CAD software DRAWING DESIGN 856“Marking symbol”.
2. Specify the place of marking.
CAD drawing DRAWING DESIGN 857
3. If necessary, select the arrow type in the context menu: Arrow or Point.
4. If necessary, select the type of designation in the context menu.: Mark or Brand.
CAD drafting DRAWING DESIGN 858
5. Indicate the position of the mark. Open dialog “Marking and branding”.
CAD software DRAWING DESIGN 859
6. Adjust the settings and click “OK.”
7. A marking or branding mark will be created.
CAD drawing DRAWING DESIGN 860
Dialog edit
CAD drafting DRAWING DESIGN 861
The “Marking and branding” dialog contains:
· Graphic switch sign type: CAD software DRAWING DESIGN 862Marking or CAD drawing DRAWING DESIGN 863Branding. · Graphic switch arrow type:CAD drafting DRAWING DESIGN 864Arrow or CAD software DRAWING DESIGN 865Point. · Button CAD drawing DRAWING DESIGN 866Technical conditions. Allows you to add technical conditions. The last item added will automatically bind to the marking.The number of the selected item is displayed in the field next to the technical conditions button.
Note:
The item number in the technical conditions will match the number in the designation in the drawing, even after changing the order of the items in the editor.
· Drop-down list “Contents”. Allows you to specify the content type of the mark marking or branding. · Drop-down list “Method of marking”. Allows you to specify the method of applying the mark marking or branding.Properties
· Type – Type of mark: Marking or Branding. · Arrow type – Arrow type: Arrow or Point. · Content · Method of marking · Text position – The position of the text content and method of applying to the extension line. The value changes from 0 to 1. The report starts from the place of marking. · TR item number. · Coeff. of compression of TR item text.Grips
1. Grip type designation: Marking or Branding.
2. Grip position of the mark.
3. Grip position text on the extension line.
4. Grip select the type of arrow.
5. Grip position of the arrow.
CAD drafting DRAWING DESIGN 867
Notes
Mechanical note
CAD software DRAWING DESIGN 868Main menu: Draw – Notes – CAD drawing DRAWING DESIGN 869Mechanical note.
CAD drafting DRAWING DESIGN 870Main menu: Mechanical – Symbols – Notes – CAD software DRAWING DESIGN 871Mechanical note.
CAD drawing DRAWING DESIGN 872Ribbon: Annotate – Leaders – CAD drafting DRAWING DESIGN 873Mechanical note.
CAD software DRAWING DESIGN 874Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 875Mechanical note.
CAD drafting DRAWING DESIGN 876Toolbar: Notes – CAD software DRAWING DESIGN 877Mechanical note.
CAD drawing DRAWING DESIGN 878Command line: MCNOTE, NOTE.
CAD drafting DRAWING DESIGN 879
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Mechanical note” dialog opens. In the “Mechanical note” dialog box, enter text and define the note options. Click “OK”. 3. Pick a point on the object (position of the leader arrow). 4. Place a note leader in the drawing. 5. If the “Show dialog before inserting objects” option is disabled, the “Mechanical note” dialog will open.In the “Mechanical note” dialog box, enter text and define the note options. Click “OK”. 6. Note will be biuld.Menu
· CAD software DRAWING DESIGN 880Add string – command adds an extra input field; · CAD drawing DRAWING DESIGN 881Remove string – command deletes the input field where the cursor is located; · CAD drafting DRAWING DESIGN 882Simple note – command toggles the display of the note; · CAD software DRAWING DESIGN 883Multiline note – command toggles the display of the note; · CAD drawing DRAWING DESIGN 884Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD drafting DRAWING DESIGN 885Frame – text under the shelf is framed; · Type arrows: · CAD software DRAWING DESIGN 886None, · CAD drawing DRAWING DESIGN 887Arrow, · CAD drafting DRAWING DESIGN 888Point, · CAD software DRAWING DESIGN 889Open arrow, · CAD drawing DRAWING DESIGN 890Half-arrow, · Align text horizontally; · CAD drafting DRAWING DESIGN 891By left edge · CAD software DRAWING DESIGN 892By center · CAD drawing DRAWING DESIGN 893By right edge · CAD drafting DRAWING DESIGN 894Insert special symbol – the command allows you to insert a special character into the input field; · CAD software DRAWING DESIGN 895Match properties – command copies appearance parameters from another object; · CAD drawing DRAWING DESIGN 896Add extension line – the command allows you to add an additional note line; · CAD drafting DRAWING DESIGN 897Technical conditions; · Designations: · CAD software DRAWING DESIGN 898Surface, · CAD drawing DRAWING DESIGN 899Dimension, · CAD drafting DRAWING DESIGN 900Others; · CAD software DRAWING DESIGN 901Dulling dimension.Context menu
The context menu opens in the input field. View Context menu entry fields.
Fields
By default, “Mechanical note” contains one text box for the label above the leader flange.
Using the CAD drawing DRAWING DESIGN 902“Simple note” and CAD drafting DRAWING DESIGN 903“Multiline note” menu commands, you edit the presence of additional shelves.
Use the CAD software DRAWING DESIGN 904“Add string” and CAD drawing DRAWING DESIGN 905“Remove string” menu commands to edit the number of leader ledges. When using a simple note, these commands control the presence of text under the shelf.
Note:
Hotkeys are available for the CAD drafting DRAWING DESIGN 906“Add string” command. “Ctrl + Enter” – adds a shelf below the selected shelf. “Shift + Enter” – adds a shelf above the selected shelf.
The CAD software DRAWING DESIGN 907“Multi-line text” option allows you to display multiline text on the shelf. When this parameter is enabled, the transition to another line is performed by the “Ctrl + Enter” key combination.
CAD drawing DRAWING DESIGN 908
CAD drafting DRAWING DESIGN 909
CAD software DRAWING DESIGN 910
Auto sort modes
Note:
The submenu (in our example – the letter A) is activated in cases of using the auto sort mode when applying letters to the drawing.
CAD drawing DRAWING DESIGN 911
CAD drafting DRAWING DESIGN 912Surface – reference surface designation (When automatic lettering sorting is enabled).
CAD software DRAWING DESIGN 913Dimension -dimension designation.
CAD drawing DRAWING DESIGN 914Others – designation of other elements, such as holes.
CAD drafting DRAWING DESIGN 915Dulling dimension – special note to indicate blunt edges.
Construction note
CAD software DRAWING DESIGN 916Main menu: Draw – Notes – CAD drawing DRAWING DESIGN 917 Construction note.
CAD drafting DRAWING DESIGN 918Ribbon: Annotate – Leaders – CAD software DRAWING DESIGN 919Construction note.
CAD drawing DRAWING DESIGN 920Command line: MCNOTEP, NOTEP.
CAD drafting DRAWING DESIGN 921
1. Call the command CAD software DRAWING DESIGN 922“Construction note”.
2. If “Show dialog before inserting the object” is active, the “Construction Note” dialog opens. In the “Construction Note” dialog box, enter text and define the leader options. Click the “OK” button.
3. Pick a point on the object (select the object) to which the leader arrow will point. To select an object, use the “Select” context menu command; to freely specify a point in the drawing, use the “Free” context menu command.
4. Place the leader shelf in the drawing.
Note:
If the parameter “Angle step of extension line” is arbitrary, it is possible to place the leader ledge orthogonally in the ORTO mode (F8). When you turn on the ORTO mode via the “SHIFT” key, Object Snap (F3) must be turned on.
5. If the “Show dialog before inserting the object” option is disabled, the “Construction Note” dialog will open. In the “Construction Note” dialog box, enter text and define the leader options. Click the “OK” button.
6. The note is built.
· CAD drawing DRAWING DESIGN 923Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD drafting DRAWING DESIGN 924Frame – text under the shelf is framed; · Type arrows: · CAD software DRAWING DESIGN 925None, · CAD drawing DRAWING DESIGN 926Arrow, · CAD drafting DRAWING DESIGN 927Point, · CAD software DRAWING DESIGN 928Open arrow, · CAD drawing DRAWING DESIGN 929Half-arrow, · Align text horizontally: · CAD drafting DRAWING DESIGN 930By left edge, · CAD software DRAWING DESIGN 931By center, · CAD drawing DRAWING DESIGN 932By right edge; · CAD drafting DRAWING DESIGN 933Insert special symbol – the command allows you to insert a special character into the input field; · CAD software DRAWING DESIGN 934Add extension line – the command allows you to add an additional note line;Context menu
Fields
The default positional leader contains two input lines and a list for specifying the pitch of the bevel angle.
The first line is for the label above the leader shelf, the second is under the leader shelf.
In the “Angle step of extension line” list box, the slope angle of the leader lines is selected:
· Custom – a leader line is placed arbitrarily (default); · step 15° – the leader line is put down with a step multiple 15°; · step 30° – the leader line is put down with a step multiple 30°; · step 45° – the leader line is put down with a step multiple 45°; · step 90° – the leader line is put down with a step multiple 90°.Arrow type selection context menu
CAD drawing DRAWING DESIGN 935
Comb leader note
CAD drafting DRAWING DESIGN 936Main menu: Draw – Notes – CAD software DRAWING DESIGN 937 Comb leader note.
CAD drawing DRAWING DESIGN 938Main menu: Mechanical – Symbols – Notes – CAD drafting DRAWING DESIGN 939Comb leader note.
CAD software DRAWING DESIGN 940Ribbon: Annotate – Leaders – CAD drawing DRAWING DESIGN 941Comb leader note.
CAD drafting DRAWING DESIGN 942Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 943Comb leader note.
CAD drawing DRAWING DESIGN 944Toolbar: Notes – CAD drafting DRAWING DESIGN 945Comb leader note.
CAD software DRAWING DESIGN 946Command line: MCNOTEC, NOTEC.
CAD drawing DRAWING DESIGN 947
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Comb leader note” dialog opens. In the “Comb leader note” dialog box, enter text and define the note options. Click “OK”. 3. Insert the required number of leader lines. When you specify the location of the leader line, the specified line segment is highlighted. Press the “Enter” key to complete the paste. 4. Specify the slope of the leader lines. Commands for switching the ridge direction are available in the context menu: H – horizontal, V – vertical, P – parallel (parallel to the selected line). 5. Place a note leader in the drawing. 6. If the “Show dialog before inserting objects” option is disabled, the “Comb leader note” dialog will open.In the “Comb leader note” dialog box, enter text and define the note options. Click “OK”. 7. Note will be build.Menu
· CAD drafting DRAWING DESIGN 948Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD software DRAWING DESIGN 949Frame – text under the shelf is framed; · Type arrows: · CAD drawing DRAWING DESIGN 950None, · CAD drafting DRAWING DESIGN 951Arrow, · CAD software DRAWING DESIGN 952Point, · CAD drawing DRAWING DESIGN 953Open arrow, · CAD drafting DRAWING DESIGN 954Half-arrow, · Align text horizontally; · CAD software DRAWING DESIGN 955By left edge · CAD drawing DRAWING DESIGN 956By center · CAD drafting DRAWING DESIGN 957By right edge · CAD software DRAWING DESIGN 958Insert special symbol – the command allows you to insert a special character into the input field; · CAD drawing DRAWING DESIGN 959Add extension line – the command allows you to add an additional note line;Context menu
Fields
Comb leader note by default contains: two lines of input, a list for specifying the pitch of the angle of inclination and the orientation of the ridge.
· Custom – a leader line is placed arbitrarily (default); · step 15° – the leader line is put down with a step multiple 15°; · step 30° – the leader line is put down with a step multiple 30°; · step 45° – the leader line is put down with a step multiple 45°; · step 90° – the leader line is put down with a step multiple 90°.In the “Comb orientation of extension lines” list box, you can select the ridge orientation of the leader lines:
· Custom; · Horizontal; · Vertical.The list is equipped with an additional button CAD drafting DRAWING DESIGN 960“Select line”, which allows you to select the direction of the ridge of the leader lines parallel to any line segment in the drawing.
The CAD software DRAWING DESIGN 961“Multi-line text” option allows you to display multiline text on the shelf. When this parameter is enabled, the transition to another line is performed by the “Ctrl + Enter” key combination.
CAD drawing DRAWING DESIGN 962
Grips
1. Text alignment toggle grip.
2. Leader lines grip.
3. Arrow type switch-grip.
4. Ridge line rotation grip.
5. Shelf rotation grip.
CAD drafting DRAWING DESIGN 963
Chain note
CAD software DRAWING DESIGN 964Main menu: Draw – Notes – CAD drawing DRAWING DESIGN 965Chain note.
CAD drafting DRAWING DESIGN 966Ribbon: Annotate – Leaders – CAD software DRAWING DESIGN 967 Chain note.
CAD drawing DRAWING DESIGN 968Command line: MCNOTEH, NOTEH.
CAD drafting DRAWING DESIGN 969
A chain note has several coaxial (collinear) series-connected pointers.
If the first node of the note is placed on a line segment, then the note will be located perpendicular to this segment.
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Chain note” dialog opens. In the “Chain note” dialog box, enter text and define the note options. Click “OK”. 3. Specify note nodes, at least two. To complete the selection of nodes, press “Enter”. 4. Specify the position of the leader where the text will go. 5. If the “Show dialog before inserting objects” option is disabled, the “Chain note” dialog will open.In the “Chain note” dialog box, enter text and define the note options. Click “OK”. 6. Note will be build.Menu
· CAD software DRAWING DESIGN 970Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD drawing DRAWING DESIGN 971Frame – text under the shelf is framed; · Type arrows: · CAD drafting DRAWING DESIGN 972None, · CAD software DRAWING DESIGN 973Arrow, · CAD drawing DRAWING DESIGN 974Point, · CAD drafting DRAWING DESIGN 975Open arrow, · CAD software DRAWING DESIGN 976Half-arrow, · Align text horizontally; · CAD drawing DRAWING DESIGN 977By left edge · CAD drafting DRAWING DESIGN 978By center · CAD software DRAWING DESIGN 979By right edge · CAD drawing DRAWING DESIGN 980Insert special symbol – the command allows you to insert a special character into the input field; · CAD drafting DRAWING DESIGN 981Add extension line – the command allows you to add an additional note line;Context menu
Fields
Chain note contains two lines of input by default.
Input fields are expandable. Switching to another line of the input field is performed by the “Ctrl + Enter” key combination.
CAD software DRAWING DESIGN 982
Section note
CAD drawing DRAWING DESIGN 983Main menu: Draw – Notes – CAD drafting DRAWING DESIGN 984 Section note.
CAD software DRAWING DESIGN 985Ribbon: Annotate – Leaders – CAD drawing DRAWING DESIGN 986Section note.
CAD drafting DRAWING DESIGN 987Command line: MCNOTES, NOTES.
CAD software DRAWING DESIGN 988
2. If the option “Show dialog before inserting objects” is active, the “Section note” dialog opens. In the “Section note” dialog box, enter text and define the note options. Click “OK”.
3. Select the insert mode “Free” or “Selection”:
· “Selection” – you need to specify the first and second lines to place the note, the cursor is in the form of a square, · “Free” – no lines are required, can be placed anywhere by 2 points, the cursor is in the form of a cross.To switch from the “Selection” mode to the “Free” mode, press the RMB and select the “Enter” command in the context menu. To switch from the “Free” mode to the “Selection” mode, press the RMB. Also, switching modes is carried out with the “Space” key.
4. Pick the first point (select the first line) in the drawing.
5. Pick the second point (select the second line) in the drawing.
6. Specify the position of the leader.
7. If the “Show dialog before inserting objects” option is disabled, the “Section note” dialog will open.In the “Section note” dialog box, enter text and define the note options. Click “OK”.
8. Section note will be build.
· Align text horizontally; · CAD drawing DRAWING DESIGN 989By left edge · CAD drafting DRAWING DESIGN 990By center · CAD software DRAWING DESIGN 991By right edge · Lines; · CAD drawing DRAWING DESIGN 992Single-stroked line · CAD drafting DRAWING DESIGN 993Double-stroked line · CAD software DRAWING DESIGN 994Insert special symbol – the command allows you to insert a special character into the input field; · CAD drawing DRAWING DESIGN 995Select line – the command allows you to relocate the location of the leader line by specifying a line in the drawing;Context menu
Fields
Section note contains two lines of input by default.
The first line of input consists of two fields for specifying the “Node (sheet) number”.
Second line of input for specifying the “Node address”.
CAD drafting DRAWING DESIGN 996
Node note
CAD software DRAWING DESIGN 997Main menu: Draw – Notes – CAD drawing DRAWING DESIGN 998 Node note.
CAD drafting DRAWING DESIGN 999Ribbon: Annotate – Leaders – CAD software DRAWING DESIGN 1000Node note.
CAD drawing DRAWING DESIGN 1001Command line: MCNOTEK, NOTEK.
CAD drafting DRAWING DESIGN 1002
2. If the option “Show dialog before inserting objects” is active, the “Node note” dialog opens. In the “Node note” dialog box, enter text and define the leader options. Click “OK”.
3. Pick the center of the leader oval (circle).
4. Specify the size of the leader oval (circle).
5. Show the position of the shelf or enter in advance in the command line the step of the angle of inclination of the leader line.
6. If the “Show dialog before inserting objects” option is disabled, the “Node note” dialog will open.In the “Node note” dialog box, enter text and define the leader options. Click “OK”.
7. Node note will be build.
· Align text horizontally; · CAD software DRAWING DESIGN 1003By left edge · CAD drawing DRAWING DESIGN 1004By center · CAD drafting DRAWING DESIGN 1005By right edge · CAD software DRAWING DESIGN 1006Insert special symbol – the command allows you to insert a special character into the input field;Context menu
Fields
Node note by default contains: two input lines and a drop-down list for specifying the pitch of the slope.
In the drop-down list “Angle step of extension line”, the slope angle of the leader lines is selected:
CAD drawing DRAWING DESIGN 1007
CAD drafting DRAWING DESIGN 1008Main menu: Draw – Notes – CAD software DRAWING DESIGN 1009 Note for multilayered constructions.
CAD drawing DRAWING DESIGN 1010Ribbon: Annotate – Leaders – CAD drafting DRAWING DESIGN 1011Note for multilayered constructions.
CAD software DRAWING DESIGN 1012Command line: MCNOTEM, NOTEM.
CAD drawing DRAWING DESIGN 1013
1. Call the command. 2. If the option “Show dialog before inserting objects” is active, the “Note for multilayered constructions” dialog opens. In the “Note for multilayered constructions” dialog box, enter text and define the leader options. Click “OK”. 3. Pick a point on an object (drawing). 4. Specify the position of the shelf. 5. If the “Show dialog before inserting objects” option is disabled, the “Note for multilayered constructions” dialog will open. In the “Note for multilayered constructions” dialog box, enter text and define the leader options. Click OK. 6. The note will be built.Menu
· CAD drafting DRAWING DESIGN 1014Add string – command adds an extra input field; · CAD software DRAWING DESIGN 1015Remove string – command deletes the input field where the cursor is located; · CAD drawing DRAWING DESIGN 1016First line – the command adds a border (vertical line before the line) for the first line; · CAD drafting DRAWING DESIGN 1017Multi-line text – the switch controls the display of multi-line text on the shelf; · CAD software DRAWING DESIGN 1018Frame – text under the shelf is framed; · Type arrows: · CAD drawing DRAWING DESIGN 1019None, · CAD drafting DRAWING DESIGN 1020Arrow · CAD software DRAWING DESIGN 1021Point, · CAD drawing DRAWING DESIGN 1022Open arrow, · CAD drafting DRAWING DESIGN 1023Half-arrow, · CAD software DRAWING DESIGN 1024Right angle; · Align text horizontally; · CAD drawing DRAWING DESIGN 1025By left edge · CAD drafting DRAWING DESIGN 1026By center · CAD software DRAWING DESIGN 1027By right edge · CAD drawing DRAWING DESIGN 1028Insert special symbol – the command allows you to insert a special character into the input field; · CAD drafting DRAWING DESIGN 1029Select line – the command allows you to relocate the location of the leader line by specifying a line in the drawing;Context menu
Fields
By default, “Note for multilayered constructions” contains 5 input fields.
The number of fields is edited using the menu commands “Add string” and “Remove string”.
With the help of the “First line” menu command, the presence of a border on the first line is edited.
Using the “Multi-line text” menu command, you edit the presence of shelves in multiline notes.
CAD software DRAWING DESIGN 1030
Linear aligned note
CAD drawing DRAWING DESIGN 1031Main menu: Draw – Notes – CAD drafting DRAWING DESIGN 1032 Linear Aligned note.
CAD software DRAWING DESIGN 1033Ribbon: Annotate – Leaders – CAD drawing DRAWING DESIGN 1034Linear Aligned note.
CAD drafting DRAWING DESIGN 1035Command line: MCLINM, LINM.
CAD software DRAWING DESIGN 1036
1. Call the command. A dialogue will open “Linear aligned note” 2. In the “Linear aligned note” dialog box, enter text and define the leader options. Click the “OK” button. 3. Specify the subassembly line on which the line subassembly will be located. 4. Specify text position. 5. “Linear aligned note” will be build.Menu
· CAD drawing DRAWING DESIGN 1037Multi-line text – the switch controls the display of multi-line text on the shelf; · Align text horizontally; · CAD drafting DRAWING DESIGN 1038By left edge · CAD software DRAWING DESIGN 1039By center · CAD drawing DRAWING DESIGN 1040By right edge · CAD drafting DRAWING DESIGN 1041Insert special symbol – the command allows you to insert a special character into the input field; · CAD software DRAWING DESIGN 1042Select line – the command allows you to relocate the location of the leader line by specifying a line in the drawing; · CAD drawing DRAWING DESIGN 1043Auto repeat – when the switch is on, the “Linear aligned note” command, upon completion of the previous command, is restarted; · CAD drafting DRAWING DESIGN 1044Multiple insert – when the switch is on, the insert is looped. To exit the cycle, press the “Enter” key.Context menu
Fields
By default “Linear aligned note” contains 2 input fields.
The first field for the label is above the linear structure, the second – under the linear structure.
The CAD software DRAWING DESIGN 1045Multi-line text parameter allows you to display multi-line text on the shelf. When this parameter is enabled, the transition to another line is performed by the “Ctrl + Enter” key combination.
CAD drawing DRAWING DESIGN 1046
Editing Notes
There are 3 commands for editing leaders:
Append leader
CAD drafting DRAWING DESIGN 1047Main menu: Mechanical – Symbols – Notes – CAD software DRAWING DESIGN 1048 Append leader.
CAD drawing DRAWING DESIGN 1049Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 1050 Append leader.
CAD software DRAWING DESIGN 1051Toolbar: CAD drawing DRAWING DESIGN 1052Append leader ( “Notes”).
CAD drafting DRAWING DESIGN 1053Command line: MCPLADD.
1. Call the team.
2. Pick a point on the object (point of arrow position).
3. Indicate the required number of intermediate points that form a break in the leader line.
4. Point to the desired leader inserted in the drawing to complete the command.
Detach leader
CAD software DRAWING DESIGN 1054Main menu: Mechanical – Symbols – Notes – CAD drawing DRAWING DESIGN 1055 Detach leader.
CAD drafting DRAWING DESIGN 1056Ribbon: Mechanical – Symbols – CAD software DRAWING DESIGN 1057 Detach leader.
CAD drawing DRAWING DESIGN 1058Toolbar: CAD drafting DRAWING DESIGN 1059Detach leader ( “Notes”).
CAD software DRAWING DESIGN 1060Command line: MCPLDEL.
1. Call the team.
2. In the drawing, select the leader line you want to delete.
Edit leader
CAD drawing DRAWING DESIGN 1061Main menu: Mechanical – Symbols – Notes – CAD drafting DRAWING DESIGN 1062Edit leader.
CAD software DRAWING DESIGN 1063Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 1064 Edit leader.
CAD drafting DRAWING DESIGN 1065Toolbar: CAD software DRAWING DESIGN 1066Edit leader ( “Notes”).
CAD drawing DRAWING DESIGN 1067Command line: MCPLREC.
1. Call the team.
2. Highlight on the drawing a leader line that should be chained.
3. Pick a point on the desired leader in order to fix the new position of the leader line.
Adaptive note
nanoCAD Mechanica 23 allows you to use “Fields (Fields) drawing”.
1. In the context menu of the callout input field, select the “Insert field…” command. The “Field” dialog will open.
CAD drafting DRAWING DESIGN 1068
2. In the dialog box, link to the desired field and click the “OK” button.
3. The link will be created. When you click on a field link, the scope will move to the linked object.
CAD software DRAWING DESIGN 1069
Note:
To update data in adaptive callouts, use the command “Regenerate”.
Save template note
If necessary, save the callouts for later use, you need to create a balloon, defining it related parameters.
CAD drawing DRAWING DESIGN 1070
Further, by selecting it, specify the context menu – “Save object as template”.
In the “Template wizard” press button “Create template”.
In the dialog box “Create element” specify the storage folder in the base elements, Name and Note (if necessary). Press “OK”. Again we return to the dialog box “Template wizard”.
CAD drafting DRAWING DESIGN 1071
Press button “Update template” and close “Template wizard”.
Update the tree base elements, the template will be created by the note.
CAD software DRAWING DESIGN 1072
Subsequently, this note can be inserted into a drawing for new objects. Adaptive communication with new objects and their settings will be saved.
Gradient symbol
CAD drawing DRAWING DESIGN 1073Main menu: Mechanical – Symbols – CAD drafting DRAWING DESIGN 1074Gradient symbol.
CAD software DRAWING DESIGN 1075Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 1076Gradient symbol.
CAD drafting DRAWING DESIGN 1077Toolbar: Symbols – CAD software DRAWING DESIGN 1078Gradient symbol.
CAD drawing DRAWING DESIGN 1079Command line: MCGRAD.
2. Using the “Properties” context menu command, open the “Gradient symbol” dialog box. Make the gradient symbol settings and confirm the changes with the “OK” button.
3. Select the line in the drawing for which you want to set the gradient symbol.
4. Place the gradient symbol on the selected line or leader flange.
5. The gradient symbol is drawn and associated associatively with the specified line.
Dialog
CAD drafting DRAWING DESIGN 1080
· Selection button type of designation: Gradient without designation, Left gradient and Left taper.CAD software DRAWING DESIGN 1081
· Input field for gradient symbol value. The input field is active if the associativity mode is disabled. If necessary, turn off the associative connection mode by turning off the CAD drawing DRAWING DESIGN 1082“Associative” switch (when setting, the associativity mode is turned on automatically). · CAD drafting DRAWING DESIGN 1083“Pick from driwing” button. When the associativity mode is off, the button is active and allows you to measure the gradient symbol value in the drawing. · Switch CAD software DRAWING DESIGN 1084“Associative”. Controls the display of the gradient symbol value. If the switch is on, the value is taken from the associated line, if it is off, it is entered manually. · Drop-down list “Representation”. Allows you to select how the slope units are represented: · As is · Ratio · Decimal · Percent · Permille · Degree · “Text on leader” checkbox. Toggles whether the gradient symbol is on a shelf or on a line.Grips
CAD drawing DRAWING DESIGN 1085
1. Grip for selecting the slope symbol representation.
2. Shelf movement grip.
3. Base move grip. When you move, the associativity with the line is lost and an additional fourth grip appears.
4. Grip for changing the angle of inclination of the base.
Position
CAD drafting DRAWING DESIGN 1086Main menu: Mechanical – Symbols – CAD software DRAWING DESIGN 1087Position.
CAD drawing DRAWING DESIGN 1088Toolbar: CAD drafting DRAWING DESIGN 1089Position (toolbar “MCS Symbols”).
CAD software DRAWING DESIGN 1090Command line: MCPOS.
1. Specify the insertion point to the first marker position or call the context menu command “P-properties.” 2. In the dialog box Tagging enter text. 3. Select an arrow. Click OK. 4. Insert the desired number of drawing markers. Subsequent node number is automatically incremented from the previous.Fundamental rules
This command draws the drawing reference numerals used in the drawings.
Sequencing
Insert position by specifying the datum marker
CAD drawing DRAWING DESIGN 1091
Next, mark the position statement of the position:
CAD drafting DRAWING DESIGN 1092
Inserted into a single command cycle positions are automatically numbered
CAD software DRAWING DESIGN 1093
To specify additional options position must call dialog “Position”, where you can specify the text position display option arrows (switches below the text input field).
CAD drawing DRAWING DESIGN 1094
Hole group
CAD drafting DRAWING DESIGN 1095Main menu: Mechanical – Symbols – CAD software DRAWING DESIGN 1096Hole group.
CAD drawing DRAWING DESIGN 1097Ribbon: Mechanical – Symbols – CAD drafting DRAWING DESIGN 1098Hole group.
CAD software DRAWING DESIGN 1099Toolbar: “MCSSymbols”) – CAD drawing DRAWING DESIGN 1100Hole group.
CAD drafting DRAWING DESIGN 1101Command line: MCFILL.
Universal command for drawing holes. With its help, you can draw a new hole with centerlines, or by specifying a group of holes to assign them general properties with filling of a sector.
1. Draw holes from circles.
CAD software DRAWING DESIGN 1102
2. Call the command CAD drawing DRAWING DESIGN 1103“Hole group”.
CAD drafting DRAWING DESIGN 1104
3. Select the required circles. Press the “Enter” key to complete the selection. The “Holes” dialog will open.
CAD software DRAWING DESIGN 1105
4. Adjust the hole settings and click “OK”. The parameters will be applied to the holes. The holes will be created.
CAD drawing DRAWING DESIGN 1106
Dialog
The “Holes” editing dialog is opened by double-clicking. The dialog consists of: Toolbar, Parameter List, Graphics Window.
CAD drafting DRAWING DESIGN 1107
Toolbar
CAD software DRAWING DESIGN 1108Match properties – this command allows you to copy parameters from holes already installed in the drawing.
CAD drawing DRAWING DESIGN 1109Select holes – the command allows you to select additional holes from the drawing.
CAD drafting DRAWING DESIGN 1110Create holes – the command creates holes of the specified diameter. To dynamically set the radius on the screen, hold down the left mouse button and move the cursor.
Parameter List
Designation
· Number – specifies the number of the hole in the group. · Description – specifies the hole table description field. · Standard – sets the field to the standard of the hole table. · Roughness – allows you to specify the roughness of the hole (displayed in the hole table).Dimensions
· Diameter – hole diameter. · Tolerance – the “…” button opens the “Tolerances” dialog, from which you can select a tolerance. · Thread pitch – hole thread pitch.Representation
· Hole – hole display switch. · Label – label display switch. · Axes – axis display switch. · Threaded hole – thread display switch. · Diam. dimension – diametrical dimension display switch. · Center identifier – drop-down list for selecting the hole center designation.Note:
Also, the parameters of the “Representation” section can be configured through the graphics window.
Graphics Window
The graphics window allows you to see the resulting hole representation and customize the representation by directly specifying elements.
Threaded hole
Axes
Fill first quarter
CAD software DRAWING DESIGN 1111
CAD drawing DRAWING DESIGN 1112
CAD drafting DRAWING DESIGN 1113
Fill second quarter
Fill third quarter
Fill fourth quarter
CAD software DRAWING DESIGN 1114
CAD drawing DRAWING DESIGN 1115
CAD drafting DRAWING DESIGN 1116
Properties
The parameters on the “Properties” functional panel are similar to the parameters from the list of parameters of the “Holes” dialog.
Grips
1. Hole position change grip.
2. Diameter change grips.
3. Grip for changing the position of the hole number.
4. Hole rotation grip.
5. View adjustment grip.
CAD software DRAWING DESIGN 1117
Hole chart
CAD drawing DRAWING DESIGN 1118Main menu: Mechanical – Symbols – CAD drafting DRAWING DESIGN 1119Hole chart.
CAD software DRAWING DESIGN 1120Ribbon: Mechanical – Symbols – CAD drawing DRAWING DESIGN 1121Hole chart.
CAD drafting DRAWING DESIGN 1122Toolbar: CAD software DRAWING DESIGN 1123Hole chart (on toolbar “MCS Symbols”).
CAD drawing DRAWING DESIGN 1124Command line: MCHOLECHART.
The command is designed to create automatically updated statements for a group of holes.
1. Call command CAD drafting DRAWING DESIGN 1125“Hole chart”.
2. Specify the insertion point of the coordinate system.
CAD software DRAWING DESIGN 1126
3. Set the angle of rotation of the coordinate system.
CAD drawing DRAWING DESIGN 1127
4. Specify the required holes and circles in the drawing, or create new ones using the “Create N” context menu command. To complete the selection (creation), press the “Enter” key. The “Hole chart” dialog opens.
CAD drafting DRAWING DESIGN 1128
5. In the “Hole chart” dialog, specify the name and type (dekatrov or polar) of the coordinate system, add (or delete), if necessary, holes.
6. Insert into the drawing the necessary tables: List of coordinates, Table of holes, Table of values.
7. Click “OK.” Tables will be built. Holes will be associated with tables and coordinate system.
Note:
To see the holes in the drawing associated with this coordinate system, double-click on the anchor.
Edit dialog
The “Hole chart” dialog is called for editing by double-clicking on the coordinate system.
CAD software DRAWING DESIGN 1129
The “Hole chart” dialog contains:
· Graphic switch type coordinate system: CAD drawing DRAWING DESIGN 1130Cartesian or CAD drafting DRAWING DESIGN 1131Polar. · Hole table creation buttons: · CAD software DRAWING DESIGN 1132List of coordinates – an automatically updated table is formed with the coordinates of each hole. · CAD drawing DRAWING DESIGN 1133Hole table – a table is formed, grouped by hole diameter. Each group of identical holes is assigned a letter. · Button CAD drafting DRAWING DESIGN 1134Number holes – the command automatically assigns consecutive numbers or letters to the holes (according to the setting for Hole Designation). · Button CAD software DRAWING DESIGN 1135Add holes – this command allows you to add holes to the report. · Button CAD drawing DRAWING DESIGN 1136Remove holes – this command allows you to remove holes from the report. · Field “Name” – the name of the coordinate system. It is added to the hole designation as a prefix.Grips
The handles of the report tables are similar to the handles of ordinary tables.
Coordinate system:
1. Axle Strength Handles.
2. Handles parallel transfer axes.
3. Handle move the designation of the coordinate system.
4. Handle rotation coordinate system.
5. Handle transfer coordinate system.
CAD drafting DRAWING DESIGN 1137
Text
CAD software DRAWING DESIGN 1138Main menu: Mechanical – Drawing title/ Borders – CAD drawing DRAWING DESIGN 1139Technical conditions.
CAD drafting DRAWING DESIGN 1140Ribbon: Mechanical – Title blocks – CAD software DRAWING DESIGN 1141Technical conditions.
CAD drawing DRAWING DESIGN 1142Toolbar: CAD drafting DRAWING DESIGN 1143Technical conditions (on toolbar “Drawing title/ Borders”).
CAD software DRAWING DESIGN 1144Command line: MCTT.
A distinctive feature of nanoCAD Mechanica 23 is the possibility of linking the designation of textual information on the drawing with the text in the technical requirements.
When writing paragraphs of technical requirements (hereinafter TC), you can make reference within the proposal of the paragraph of technical requirements to any position or affixed view.
The textual information is the tolerances and dimensions, drawing zones, designations of types, cuts, sections, marking signs, marking of welded joints, position.
A change in the value of the textual information (for example, a part position number) will result in an automatic change in the TC text. If this position has been deleted, a warning will appear about the need to check a particular item of requirements.
The relationship between the TC and the designation works in the opposite direction. Changing the order of the points of the requirements (their numbering) is automatically reflected in the designation on the drawing (for example, a marking mark, the designation of which contains the item number from the technical requirements).
Editor
CAD drawing DRAWING DESIGN 1145
Main menu
· File · Clear – clear TC. · Open file – the command opens the TC from a previously saved file. · Save file – command saves TC to * .rtf file. · Close without save – the command closes the TC editing dialog box without saving. · Edit · Undo – command cancels last action. · Redo – the command repeats the previously canceled action. · Insert title – command inserts a title in front of TC items. · Delete title – command removes TC title.Toolbar
· CAD drafting DRAWING DESIGN 1146Open file – the command opens the TC from a previously saved file. · CAD software DRAWING DESIGN 1147Save file – command saves TC to * .rtf file.Important!
The special characters used in the editor are lost when they are transferred to an external file.
· CAD drawing DRAWING DESIGN 1148Fill in MSWord – the command opens a new document in MSWord and inserts the text TC.Important!
· CAD drafting DRAWING DESIGN 1149Notebook – command opens interface notebook.CAD software DRAWING DESIGN 1150
· CAD drawing DRAWING DESIGN 1151Undo – command cancels last action. · CAD drafting DRAWING DESIGN 1152Redo – the command repeats the previously canceled action. · CAD software DRAWING DESIGN 1153Add paragraph (CTRL+ENTER) – command adds a new TC item. · CAD drawing DRAWING DESIGN 1154Delete paragraph (CTRL+DEL) – command deletes TC item. · CAD drafting DRAWING DESIGN 1155Replace paragraph up – the command moves the TC item at which the cursor is located, higher up in the list. · CAD software DRAWING DESIGN 1156Replace paragraph down – the command moves the TC item at which the cursor is located, down the list. · CAD drawing DRAWING DESIGN 1157Decrease Indent – the command reduces the indent of selected items.CAD drafting DRAWING DESIGN 1158CAD software DRAWING DESIGN 1159
· CAD drawing DRAWING DESIGN 1160Increase indent – command increases the indent of selected items.CAD drafting DRAWING DESIGN 1161CAD software DRAWING DESIGN 1162
· CAD drawing DRAWING DESIGN 1163Line Spacing – the command opens the list for setting the line spacing. Adjust line spacing of selected items.CAD drafting DRAWING DESIGN 1164
· 1 – set 1 leading (unit for measuring line spacing). Line spacing is added after the TC item. · 1.5 – set 1.5 leading. Line spacing is added after the TC item. · 2 – set 2 leading. Line spacing is added after the TC item. · Set line spacing… – the command allows you to specify your own line spacing. Line spacing is added after the TC item. · CAD software DRAWING DESIGN 1165Superscript – translates the selected text into superscript.CAD drawing DRAWING DESIGN 1166
· CAD drafting DRAWING DESIGN 1167Subscript – translates the selected portion of the text into a subscript. · CAD software DRAWING DESIGN 1168Insert fraction – the command calls the “Fraction” dialog box in which the numerator and denominator are specified. The fraction is inserted into the text TC.CAD drawing DRAWING DESIGN 1169
· CAD drafting DRAWING DESIGN 1170Insert tolerance – provides the ability to insert a tolerance. When called, the “Tolerances” dialog box opens.CAD software DRAWING DESIGN 1171CAD drawing DRAWING DESIGN 1172CAD drafting DRAWING DESIGN 1173
· CAD software DRAWING DESIGN 1174Insert material – provides the ability to insert material. When called, opens the “Material” dialog.CAD drawing DRAWING DESIGN 1175
· CAD drafting DRAWING DESIGN 1176Insert spec symbol – allows you to insert special characters in the text TC. · CAD software DRAWING DESIGN 1177Numeration – the command allows you to select the design option for TC items.CAD drawing DRAWING DESIGN 1178
Note:
To create a hierarchical list it is necessary to press the “Tab” key on an empty item. A new child level has been created. To return to the previous level, press the “Enter” key on an empty item.
· CAD drafting DRAWING DESIGN 1179Insert position – the command associates text fragments in the TC with a graphical representation of the positions in the drawing.To insert a link in the TC editor, place the cursor on the insertion point of the associated symbol and click on the “Insert position” button, select a position in the drawing.
Related information is displayed in blue in the TC editor. When you click on a link, the application will display the associated graphical representation.
· CAD software DRAWING DESIGN 1180Insert view/cuts – the command associates text fragments in TC with a graphical representation of views, sections and sections in the drawing.To insert a link in the TC editor, place the cursor on the insertion point of the associated symbol and click on the “Insert view / cuts” button, select the view, section or section.
· Ruler. The ruler is used to position the lines relative to the entire TC document. Sliders are used to position the lines.CAD drawing DRAWING DESIGN 1181
1. The bottom slider adjusts the indentation of all paragraph lines except the first line.
2. The top slider adjusts the indent of the first paragraph line.
3. The angle slider adjusts the text indent from the numbered list marker.
Context menu
The context menu uses standard commands for text fields.
Setting text options
To set the TC text parameters (font height and slope, indent from the title block, etc.) open the dialog box “Settings”.
Technical parameters
CAD drafting DRAWING DESIGN 1182Main menu: Mechanical – Drawing title/ Borders – CAD software DRAWING DESIGN 1183Technical parameters.
CAD drawing DRAWING DESIGN 1184Ribbon: Mechanical – Title blocks – CAD drafting DRAWING DESIGN 1185Technical parameters.
CAD software DRAWING DESIGN 1186Toolbar: CAD drawing DRAWING DESIGN 1187Technical parameters (on toolbar “Drawing title/ Borders”).
CAD drafting DRAWING DESIGN 1188Command line: MCTD.
Working with the technical description editor is similar to working with the TC editor. The main difference is that the typed text can be placed anywhere in the drawing.
Editor
CAD software DRAWING DESIGN 1189
Main menu
· File · Clear – clear TP. · Open file – the command opens the TP from a previously saved file. · Save file – command saves TP to * .rtf file. · Close without save – the command closes the TP editing dialog box without saving. · Edit · Undo – command cancels last action. · Redo – the command repeats the previously canceled action. · Insert title – command inserts a title in front of TP items. · Delete title – command removes TP title.Toolbar
· CAD drawing DRAWING DESIGN 1190Open file – the command opens the TP from a previously saved file. · CAD drafting DRAWING DESIGN 1191Save file – command saves TP to * .rtf file.Important!
· CAD software DRAWING DESIGN 1192Fill in MSWord – the command opens a new document in MSWord and inserts the text TP.Important!
· CAD drawing DRAWING DESIGN 1193Notebook – command opens interface notebook.CAD drafting DRAWING DESIGN 1194
· CAD software DRAWING DESIGN 1195Undo – command cancels last action. · CAD drawing DRAWING DESIGN 1196Redo – the command repeats the previously canceled action. · CAD drafting DRAWING DESIGN 1197Add paragraph (CTRL+ENTER) – command adds a new TP item. · CAD software DRAWING DESIGN 1198Delete paragraph (CTRL+DEL) – command deletes TP item. · CAD drawing DRAWING DESIGN 1199Replace paragraph up – the command moves the TP item at which the cursor is located, higher up in the list. · CAD drafting DRAWING DESIGN 1200Replace paragraph down – the command moves the TP item at which the cursor is located, down the list. · CAD software DRAWING DESIGN 1201Decrease Indent – the command reduces the indent of selected items.CAD drawing DRAWING DESIGN 1202CAD drafting DRAWING DESIGN 1203
· CAD software DRAWING DESIGN 1204Increase indent – command increases the indent of selected items.CAD drawing DRAWING DESIGN 1205CAD drafting DRAWING DESIGN 1206
· CAD software DRAWING DESIGN 1207Line Spacing – the command opens the list for setting the line spacing. Adjust line spacing of selected items.CAD drawing DRAWING DESIGN 1208
· 1 – set 1 leading (unit for measuring line spacing). Line spacing is added after the TP item. · 1.5 – set 1.5 leading. Line spacing is added after the TP item. · 2 – set 2 leading. Line spacing is added after the TP item. · Set line spacing… – the command allows you to specify your own line spacing. Line spacing is added after the TP item. · CAD drafting DRAWING DESIGN 1209Superscript – translates the selected text into superscript.CAD software DRAWING DESIGN 1210
· CAD drawing DRAWING DESIGN 1211Subscript – translates the selected portion of the text into a subscript. · CAD drafting DRAWING DESIGN 1212Insert fraction – the command calls the “Fraction” dialog box in which the numerator and denominator are specified. The fraction is inserted into the text TP.CAD software DRAWING DESIGN 1213
· CAD drawing DRAWING DESIGN 1214Insert tolerance – provides the ability to insert a tolerance. When called, the “Tolerances” dialog box opens.CAD drafting DRAWING DESIGN 1215CAD software DRAWING DESIGN 1216CAD drawing DRAWING DESIGN 1217
· CAD drafting DRAWING DESIGN 1218Insert material – provides the ability to insert material. When called, opens the “Material” dialog.CAD software DRAWING DESIGN 1219
· CAD drawing DRAWING DESIGN 1220Insert spec symbol – allows you to insert special characters in the text TP. · CAD drafting DRAWING DESIGN 1221Numeration – the command allows you to select the design option for TP items.CAD software DRAWING DESIGN 1222
Note:
· Ruler. The ruler is used to position the lines relative to the entire TP document. Sliders are used to position the lines.CAD drawing DRAWING DESIGN 1223
1. The bottom slider adjusts the indentation of all lines of the paragraph except the first line.
2. The top slider adjusts the indentation of the first line of the paragraph.
Context menu
To set the TP text parameters (font height and slope, indent from the title block, eTP.) open the dialog box “Settings”.
Text editing
CAD drafting DRAWING DESIGN 1224
If it’s set multiline text editing with tools nanoCAD Mechanica 23, then clicks on the test will be called dialogue editing.
CAD software DRAWING DESIGN 1225
In this dialog may ask, besides the text, its color, and the Height, and add special symbols.
