Add Measurement File
Ribbon: Topoplan – Measurements Archive > Add Measurements
Menu: Topoplan – Measurements Archive > Add Measurements
Command line: GEOFILE_ADD_MEASUREMENT_FILES
Adding measurement files to the archive. The command moves the selected files (without opening) to the measurements archive.
The command can be launched from the ribbon, menu, command line, and context menu of the Geofiles folder in the File Explorer bar.
In the dialog that opens, select the measurement file to be added. Supported formats: DWG, SDR (Sokkia), CSV, XYZ, TXT.
