Break Vectors at Point
Ribbon: Home, Draw – Modify > Break at Point
Menu: Modify – Break vectors at point
Command line: VCBREAKATPOINTCMD
The Break vectors at point command breaks lines, arcs, circles, polylines, ellipses, splines and other vector objects into two parts at one point (without deleting part of the object). Some closed objects for example, circle, ellipse cannot be broken in one point.
Select objects or [?]: Select object.
Specify break point: Specify a point.
