Menu: Insert – External References….
Command line: EXTERNALREFERENCES, IMAGES, XREF
nanoCAD allows you to convert the inserted images into other supported raster file formats. The list of supported raster file formats is shown in the Options dialog box (the Tools menu – the Options command).
For the TIFF format, you can also change settings such as color mode, compression, organization, byte order; for JPG and JPEG formats – Image Quality.
To save an image to another format or to change the format parameters:
1. In the External References dialog box select raster references and click Save.
2. In the opened Save Image File dialog box, type the new file name, select the file type from the drop-down list and click the Options button.
3. Depending on the selected file type, the TIFF Options dialog box or the JPEG Options dialog box will be open.
