Tools to Work with Surfaces
The surfaces are automatically created according to the Delaunay triangulation rules. Therefore, after creating a TIN, it is often required to edit some areas. Also, in the process of working with relief, sometimes the task of clarifying the surface arises. To do this, the surface editing functionality is used.
To work with surface editing commands, it is recommended to enable shaded visual styles: 3D Flat-shaded with edges, 3D Gouraud-shaded with edges.
Simplifying the Mesh
Ribbon: Topoplan – Modify TIN > Simplifying the Mesh
Menu: Topoplan – Modify TIN > Simplifying Mesh
Toolbar: Modify TIN > Simplifying the Mesh
Command line: NG_SIMPLIFY
The Simplifying the Mesh command performs triangulation network optimization. The optimization goal is to obtain a more sparse mesh that retains its form.
Target (faces) | Number of faces in the optimized mesh. |
Percent | Percentage of the number of edges in the optimized network compared to the original number of edges The right edge of the slider can be moved, changing the percentage and number of target faces along with it. |
Erase Source | Delete the source mesh or not. |
Boundary Weight | The coefficient that determines the degree of identity of the edge before and after mesh simplification. The parameter values range from 0 to the infinity. The more the value is, the more detailed the mesh will be on its boundaries, and the less will be the deviation of edge of the optimized mesh from its previous position. When the value = 0, the mesh boundary looks “ragged”, the mesh edge is rough. Too large value would lead to excessive detailing of the mesh edge and increased optimization time. Optimal value = 1. |
Preserve Topology | Allows you to create a mesh without self-intersections of faces, which may occur as a result of its optimization. The parameter value should always be Yes. |
Generate Normals | Whether to create vertex-by-vertex normals. It is used for improved display of a mesh.The default value is Yes. |
Face Quality | Whether to strive to create a mesh with faces close to equilateral triangles. When the option is disabled, narrow faces with very long edges can be created. The default value is Yes. |
Ignore Texture | Optimizes a mesh without saving its texture, if any. The default value is Yes. In most cases the option should be enabled, i.e. a mesh should be optimized without saving its texture. In this case the existing texture will be distorted, therefore, at the end of optimization, to re-overlay texture use the Texture Atlas Overlay command. Optimization in the texture saving mode is performed with less quality, than in ignoring mode. It makes sense to optimize a mesh with saving texture in such rare cases, when you need to have texture on the mesh, but it is not possible to restore the texture by point cloud (for example, there is no point cloud by which the mesh was created). |
