Ribbon: Home – Block > Explode Attributes to Text
Menu: Modify – Advanced tools > Explode attributes to text
Command line: BURST
The command allows you to extract text information from block attributes while breaking them. Pay attention that in contrast to Explode command at using which the attribute values are deleted, and only names remain, the BURST command converts block attribute values to single-line and multiple-line texts.
Value of the field inserted during creation of a block attribute is also converted to text.
Hidden block attributes are not converted to text.
- Select the block with attributes.
- Start the Convert block attributes to text command
Info: NanoCAD is an easy-to-use, low cost, and yet powerful, CAD platform for PC, that delivers a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software provides groundbreaking, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
