Smart Trim
Ribbon: Home, Draw – Modify > Break Vectors
Menu: Modify – Break vectors
Toolbar: Modify –
Command line: SMARTTRIM
The Smart trim command differs from the Trim vectors in automatically selecting all vector objects in the document as potential cutting edges. Selected objects are cut to the nearest cutting edges
? | Opens the additional options to select objects. |
Fence | Selection of objects by a crossing line which can consist of several segments. |
Crossing Selection of objects with a crossing frame.
Project Mode of cutting objects by intersection of their projections with the boundary in 3D space.
The option opens the prompt in the command line:
Enter a projection option [None/Ucs/View/] :
Options%%(color-blue):
None Only objects that are crossed by the specified boundary in 3D space are selected .
Ucs Defines the projections of objects in the XY plane of the current UCS and cuts objects which are not intersected by the boundary in 3D space.
View Defines the projections of objects in the direction of the specified view and cuts objects which are not intersected by the edge.
Edge Specifies the cutting mode of objects by imaginary extension of the edge.
Enter an implied edge extension mode [No extend/ Extend] :
No extend Switches off the cutting of objects by imaginary extension of the edge.
Extend Switches on the cutting of objects by imaginary extension of the edge.
eRase Deletes the selected objects.
Back Cancels the last change executed during performance of the command.
Select object to trim or
[?/Fence/Crossing/Project/Edge/eRase/Back]: Select objects to be cut.
[?/Fence/Crossing/Project/Edge/eRase/Back]: Select eRase.
Select objects to erase or [?]:
Select objects and press ENTER to delete them.
[?/Fence/Crossing/Project/Edge/eRase/Back]: Select Back to cancel deleting.
[?/Fence/Crossing/Project/Edge/eRase/Back]: Press ENTER to finish the command.
Info: NanoCAD is a user friendly, cheap, and yet powerful, CAD freeware tool for personal computer, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our tool supports innovative, collaborative and customizable features to boost your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
