Chain dimensioning
Ribbon: Home, Annotate – Dimensions > Continue Dimension
Menu: Dimensions – Dimensions chain
Toolbar: Utilities –
Command line: DCO, DIMCONTINUE, CHAINCONT
The dimensions chain creates a dimension that starts from an extension line of a previously created dimension.
The dimensions chain can be a linear, angular or ordinate.
To draw the dimensions chain, the object must have at least one linear, angular or ordinate dimension.
To draw the dimensions chain:
- Start the Auto command.
- Select the CHain option in the command line or context menu.
- Select the previously created dimension as the base:
- Specify the endpoint of the first dimension:
- Specify the endpoints for all the other dimensions and press ENTER to finish the command:
Info: NanoCAD is a simple, low cost, and yet professional, CAD app for Windows, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware provides groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and buy later, in case you like it.
