Create Layouts by Frames
Ribbon: Topoplan –Design of Layouts > Creating Layouts by Frames
Menu: Topoplan – Design of Layouts > Creating Layouts by Frames
Command line: CreateViewFrameLayout
The command creates layouts for designing a drawing according to previously created frames. Each frame has its own layout with the same design, format and scale that were specified when creating the frame by the Create frames command.
After running the command, you should enter the name of the group of layouts, which will be used as a prefix in the layout names created by the split box.
The layout’s frame and stamps are a dynamic block with parameters and attributes that can be edited in the Properties bar or using grips.
Depending on the frame template, the sheet will be designed in accordance with standards or in the form of a topographic tablet.
For tablets, a scheme of the survey area is created, and for standard sheet formats, a scheme for combining sheets.
