Creating a Block
Ribbon: Insert – Block Definition > Create Block
Menu: Draw – Block > Make …
Panel: Draw –
Command line: ACADBLOCKDIALOG, B, BLOCK, BMOD, NEWBLOCK, NEWBL
The Create block command is also available in the context menu.
The Block definition dialog box opened by the Create block command allows you to specify parameters for creating a new block or redefining the description of already existing block:
Name: | Names the block being created. To redefine the existing block, select the name from the drop-own list. |
Base point
Specify On Screen | B1 |
Pick point | Button that temporary closes the dialog box to specify the base point on the screen by mouse cursor. |
X: Y: Z: | Fields to specify coordinates of the block insertion point. |
Objects
Specify On Screen | Turns on/off the mode for selecting objects after the dialog box is closed. |
Select objects | Button that temporary closes the dialog box to specify objects on the screen by mouse cursor. |
Retain | Turns on the mode for retaining the selected objects in the drawing after the block is created. |
Convert to block | Turns on the mode for creating a block reference at the location of selected objects after the block is created. |
Delete | Turns on the mode for deleting the selected objects from the drawing after the block is created. |
Objects selected: 4 | Displays information on the number of objects selected to create the block. |
Behavior
Scale uniformity | Turns on/off the mode that specifies the uniform block scale by X, Y, Z axes. |
Allow exploding | Turns on/off the mode for breaking the block after it is inserted by the Explode command. |
Block units: | Drop-down list for selecting measurement units of the block being created. |
Description: | Field for entry of the text description (hidden attribute) to simplify future identification and search of the block. |
Info: NanoCAD is a simple, cheap, and yet professional, CAD platform for personal computer, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware ensures innovative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
