Exploding a cloud into points
Ribbon: Topoplan – Create TIN > Splitting the cloud into points
Menu: Ground – Creating TIN > Exploding the cloud into points
Toolbar: Creating TIN > Exploding the Cloud
Command line: NG_EXPLODE_POINTCLOUD
The command options are set in the Properties toolbar.
Options
_.Delete source | If Yes is selected – the source point cloud will be deleted after the split is completed. No – the source point cloud remains in the drawing. |
Use class | If the cloud has been previously classified, it is possible to get only points of the specified class after splitting. |
Apply changes? or [Yes/No]:
- Yes – split into points will be made with the current settings.
- No – if the settings have been changed, they are not saved. Split into points will be made with the settings displayed immediately after starting the command.
Then the Explode dialog box appears.
Drawing objects | The section defines what components will be displayed for points on the screen: Marker, Name, Elevation (Z-coordinate), Code (point description). Each component can be assigned its own layer, color, and signatures – a font. |
Coordinate system | Selects in which coordinate system to import geodata: World or Custom. |
Current profile | Allows you to save all the settings made in the dialog to a profile for later use |
Info: NanoCAD is a user friendly, affordable, and yet professional, CAD platform for personal computer, that allows a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our tool provides creative, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
