Remove from Selection
Ribbon: Home – Utilities > Remove from Selection
Menu: Edit – Remove from Selection
Command line: SELREMOVE
Command removes objects of the specified type from selection set.
1. If you have a set of selected objects, start Remove from Selection command.
2. Specify the object to remove.
All objects of this type will be removed from selection.
Info: NanoCAD is an easy-to-use, inexpensive, and yet professional, CAD application for personal computer, that delivers a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures progressive, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
