Editing raster text
Ribbon: Raster– Rasterize> Editing Raster Text
Menu: Raster– Rasterization > Editing Raster Text
Command line: RTEXTEDITCMD
This functionality is available only in the Raster module1. Run the command
2. In the image set a rectangular area above the text being edited. In the process of specifying the area, you can specify its parameters Base point, Area angle (coordinates of the second point) in the corresponding fields of Options window and the text rotation angle in the Angle field.
3. Specify text base point (bottom left corner of the text).
4. Specify text base line.
5. Draw a rectangle around the raster text, the content of which will be removed from the raster.
6. Enter a text line in the command line or edit the recognized one, if text recognition is enabled.
7. Select the text insertion or rasterization mode.
Info: NanoCAD is an easy-to-use, cheap, and yet powerful, CAD app for PC, that delivers an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our freeware ensures creative, collaborative and customizable features to enhance your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
