Aligning multileaders
Ribbon: Home, Annotate – Leaders – Multileader Align
Toolbar: Mleaders –
Command line: MLEADERALIGN
Aligns the selected leaders and spaces them at equal intervals in accordance with the preset options.
Options | Specifies options for spacing and aligning the selected multileaders. The command memorizes and by default uses the align method specified last time. |
Distribute | The leaders landings with the content will be evenly distributed between two points specified on the screen. |
Make leader segments parallel | Places content so that last leader lines segments in the selected multileaders become parallel. |
Specify spacing | Specifies the value of spacing between landing lines for the selected multileaders. |
Use current spacing | Uses the current spacings inside the content of multileaders. |
Select multileaders or [?]: | Specify the multileaders to be aligned or distributed depending on the operation selected in the command options. |
Select multileader to align or [?/Options]: | Select the leader on which the rest should be aligned. The query is displayed in the beginning of the align operation. The type of alignment operation is preset in the command options (Options option). |
Info: NanoCAD is an easy-to-use, low cost, and yet professional, CAD program for PC, that delivers a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware provides innovative, collaborative and customizable features to improve your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
