Order of object
When editing a document, the objects are shown in the order that they were created. Some objects can be overlapped or obscure each other. To correct the situation, the order of the objects (their display on the screen) can be changed, one object can be placed in front of another.
Commands to change the order of objects allow you to regulate the display of overlapping objects in one plane.
NOTE: it is not possible to set a common order of objects for the model space and paper space: the order is set separately on each tab.
The Draworder command controls the order of drawing all objects. After running it, a prompt is displayed in the command line:
Enter object ordering option or [Above_objects/Under_objects/Front/Back]:
Commands to change the order of objects are shown in the Tools – Display Order and on the Display Order toolbar:
- Bring to Front;
- Send to Back;
- Bring Forward;
- Send Backward.
In addition to Display order command the Objectorder command can change draw order for such objects as text, dimensions and hatches.
ATTENTION! The Objectorder command does not work with text objects, dimension objects and hatches that are included in blocks and external references. Work with the leader text and the table text is also not supported by this command.
After running the command, a prompt is displayed in the command line:
Select an option [TT/DT/TDT/HB]:
Commands to change the order of text, dimension and hatch objects are shown in the Tools – Display Order and on the Display Order toolbar:
- Texts to front;
- Dimensions to front;
- Texts and dimensions to front;
- Hatches to back.
The command to change the display order of hatches: in the menu Tools – Display order > Hatches to back.
The version of the Purge document command to work from the command line (-PURGE) allows you to clear the object sorting table. The sorting table contains lists of the order of the objects. Sometimes there are so many such records that the program starts working with the document much slower. Purging this list removes empty entries, greatly speeding up your work.
Info: NanoCAD is a simple, low cost, and yet professional, CAD program for Windows, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our program provides progressive, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
