Change elevation
Ribbon: Topoplan – Modify TIN > Change Elevation
Menu: Ground – Editing TIN > Change Elevation
Toolbar: Editing TIN > Change Elevation
Command line: NG_MESH_VERTEX_MOVE_H
The command changes elevation (Z coordinate) of a node of an existing surface (Submesh or Polyface mesh) and rebuilds triangulation.
To change elevation:
- Run the command.
- In response to the prompt in the command line:
Select vertex to change elevation
select a vertex. When you hover the cursor over the mesh node, it is highlighted in red. - After specifying the node, the prompt follows:
Elevation of this vertex is 200.36. Specify new elevation.
where 200.36 value is the node elevation. You need to enter a new elevation in the drawing units and press Enter.
The surface vertex whose elevation should be changed Surface after changing the vertex elevation
- Elevations of several vertices can be changed in succession. Pressing ESC button ends the command.
Info: NanoCAD is an easy-to-use, inexpensive, and yet powerful, CAD program for personal computer, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware ensures innovative, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and buy later, if you like it.
