There are three types of settings in nanoCAD – symbols, interface settings (highlighted yellow) and organization settings:
Interface settings are set by the user and influence the application’s work.
Design elements settings are written in a separate file. These settings are read when a new document is created and they define how the drawing created with nanoCAD tools will look.
If the design elements settings are changed, the following dialog box is shown after selecting the OK button:
Parameters:
Save to current document | Saves the design element settings in the current document. When a new document is created, the settings will be the same as the settings set in a configuration file; the setting will only be applied to the current document.. |
Save to config file and current document | The new design element settings will be applied to all new documents by default and to the newly created design elements in the current document. To save settings in this file you must have the rights to write to the settings folder. |
Don’t save | Refuse to save the changes to the design element settings. |
his separate saving of design element settings helps to standardize the drawing preparations procedures in an organization: you just have to set a common settings file on a network. Defining who has rights to write to the common file can be done using the operating system tools.
Settings files for users
spot.icf – nanoCAD interface settings file
ObjSettings_spot.cfg – settings file for nanoCAD design elements are stored in the folder C:\Users\%User_name%\AppData\Roaming\Nanosoft\nanoCAD Int 21.0.
To transfer settings to another computer, you should copy them into the corresponding folders and specify the path to them in the Settings dialog.
Info: NanoCAD is a simple, inexpensive, and yet professional, CAD platform for PC, that allows an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software ensures innovative, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
