Scale List
In most cases, drawings are printed at an accurate scale. When printing a model space, the plot scale is set in the Plot dialogue box. This scale determines the ratio of the unit of length in the printed drawing to the real unit used in creation of the drawing. When printing one of layout tabs, the scale is applied to the model itself displayed in the layout viewports. It defines, for each viewport, the ratio of the paper format dimensions to the model dimensions in the viewport.
Standard scales are available from the list of scales in the corresponding nanoCAD tools:
In the Plot dialogue box:
For a selected or active viewport:
- in the status bar
- in the Properties toolbar:
The list of scales is managed in the Edit drawing scales dialogue box
Ribbon: Annotate– Annotation scaling > Scale List
Menu: Format– Scale List Edit…
Command line: .SCALELISTEDIT
In the dialogue, you can add new scales, edit the existing ones, rebuild the scale list and delete unnecessary ones.
Scale list Displays the content of the current scale list.
Opens the Add Scale dialogue box to create a new scale. The dialogue box sets the following parameters:
Scale name to be displayed in the Scale list.
Scale properties – ratio of paper units to drawing units.
Opens the Edit scale dialogue box to edit parameters of the selected scale.
Moves the selected scale one position up or down in the list.
Deletes the scale selected in the list.
Deletes all custom and unused scales and restores the standard scale list. In the Reset dialogue box, select the scale list to be restored.
Show xref scales
Enables the display of scales contained in external references and different from the document scales in the scale list. The xref scales are also available for editing.
To display the standard scales in certain units of measurement in the list, press Reset button, in the Scale List dialogue box select to restore the list of scales in required units.
Info: NanoCAD is an easy-to-use, cheap, and yet professional, CAD software tool for PC, that delivers an outstanding user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our software provides progressive, collaborative and customizable features to raise your efficiency, and includes several API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, in case you like it.
