Angular dimensions
Ribbon: Home, Annotate – Dimensions > Angular
Menu: Dimensions – Angle dimension
Toolbar: Utilities –
Command line: MDIMANG
To draw the angle between two segments:
- Start the Auto command.
- Place the cursor over one of the segments to show its dynamic highlighting and display the character . Left click to confirm the dimensioning:
- Place the cursor over the second segment to show its dynamic highlighting and display the character . Left click to confirm the dimensioning:
- Left click to set the location of the dimension line:
For dimensioning the angular dimension using characteristic points:
- Select the anGular option in the command line or context menu.
- Specify the first point of the angular dimension (vertex of angle):
- Specify the second point of the angular dimension:
- Specify the third point of the angular dimension:
- Specify the location of the dimension line:
- Press ENTER to finish the command
Angle ordinate dimension
Ribbon: Home, Annotate – Dimensions > Angle ordinate
Menu: Dimensions – Angle ordinate dimension
Command line: DIMAORD
Info: NanoCAD is a user friendly, low cost, and yet powerful, CAD software tool for personal computer, that provides an outstanding user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware ensures innovative, collaborative and customizable features to raise your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD software development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
