Modify Hatched Areas
Ribbon: Home – Modify > Edit hatches
Menu: Modify – Object > Hatch …
Toolbar: Modify Object –
Command line: HATCHEDIT
As with any other object, a hatch can be deleted, copied, moved, rotated, etc.
If a hatch is selected, you can change its scale and angle.
You can edit the hatch properties in the Hatch dialog box that is used to create the hatch.
The Edit Hatches command allows you to recreate removed hatch boundaries. When you use the Edit Hatch command, the Recreate boundary option will be available in the Hatch dialog box.
To recreate a boundary:
1. Start the Hatch command from the Modify – Object
2. In the Hatch dialog box, click theRecreate boundary icon.
3. In the command line or context menu, select the Region or Polyline option to specify the object type to recreate the boundary.
4. Select Yes or No In the command line prompt Reassociate hatch with new boundary? [Yes/No] :
5. In the Hatch dialog box click OK.
Info: NanoCAD is a simple, inexpensive, and yet professional, CAD platform for PC, that delivers a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program supports groundbreaking, collaborative and customizable features to enhance your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may download nanoCad for free, using the links below, and buy later, if you like it.
