Ribbon: Insert – Block Definition > Write Block
Command line: WBLOK, ACADWBLOCKDIALOG, W
The command allows you to save in a separate file:
- a whole drawing with all changes made;
- a block contained in a drawing;
- separate fragments of a drawing.
Starting the WBLOCK command opens the Write block dialog box:
Source
Block: | Turns on the mode for selecting from the drop-down list the block to be saved contained in the drawing. Pay attention: If there is not a single block in the drawing, the option is disabled. |
Entire drawing | Turns on the mode for saving the entire drawing in a separate file. |
Objects | Turns on the mode for saving objects selected in the current drawing in a separate file. |
Base point
Pick point | Button that temporary closes the dialog box so that you can specify the base point on the screen by the mouse cursor. |
X: Y: Z: | Enters base point coordinates. |
Objects
Select objects | Button that temporary closes the dialog box so that you can select objects on the screen by the mouse cursor. |
Retain | Turns on the mode for retaining the selected objects in the drawing after they are saved in a separate file. |
Convert to block | Turns on the mode for creating a block reference in place of the selected objects after they are saved in a separate file. |
Delete from drawing | Turns on the mode for deleting the selected objects from the drawing after they are saved in a separate file. |
Objects selected: | Displays the information on the number of objects selected for saving. |
Destination
File name and path: | Button opens the Save Document dialog box to specify the path, name and format of file to be saved. |
Insert units | Drop-down list for selecting measurement units for the file being saved. |
