Callout blocks
Callout blocks are used to generate drawing links to other views and layouts. Here is a sample of callout block:
The block has two attributes with values based on fields. The upper attribute displays view number and the bottom one shows sheet number in the sheet set. Attributes can have hyperlinks for fast transit to the view or to the layout.
