Recovery of document
nanoCAD button – Utilities > Recover
Menu: File – Drawing Utilities > Recover
Command line: RECOVER
The command allows recover a document that cannot be opened.
Full recovery and correction of all errors are not guaranteed.
After command launch, a standard dialog box to open a file appears, you have to select the folder and the name of the damaged file and after that click the Open button.
The report is shown in the command line and is similar to the report of the Audit command:
AcDbLine(117689). Error:: Inactive XData handle (1157FE) was found.
Audit: Invalid.
Fixed:: Replaced: Set to Null.
AcDbCircle(119E1F). Error:: Inactive Z coordinate – 1e+100 was found.
Audit: Invalid.
Fixed:: Replaced: Set to 0.
To see the report press F2.
Info: NanoCAD is a simple, low cost, and yet professional, CAD platform for PC, that allows a great user experience by providing enhanced performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our software provides innovative, collaborative and customizable features to raise your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD software development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
