Paste as Block
Ribbon: Home – Paste as Block
Menu: Edit – Paste As > 3 As Block
Hotkeys: CTRL+SHIFT+V
Command line: PASTEBLOCK
This command inserts the contents of the clipboard as a block into the document.
Mode | Selection of block insertion mode. The option starts the following prompt in the command line: Enter paste mode [Single/Multiple]: Options:
Name | Specifies a block’s name for insertion. |
Specify insertion point or [Mode/Name]: | Select Mode option. |
Enter paste mode [Single/Multiple]: | Select Multiple option. |
Specify insertion point or [Mode/Name]: | Select Name option. |
Enter block name : | Enter a block’s name or press ENTER. |
Specify insertion point or [Mode/Name]: | Specify an insertion point. |
Specify insertion point or [Mode]: | Specify an insertion point. |
Specify insertion point or [Mode]: | Press ESC to finish the command. |
