Extract from View
Ribbon: Point Clouds > Point Cloud > Extract from View
Menu: Point clouds > Extract from view
Command line: NPC_EXTRACT_FROM_VIEW
This command extracts points from viewport to a new point cloud. If source point cloud was clipped with one of clip or section commands, then only visible points includes in a new cloud. If point cloud has a Class attribute then only points from visible unblocked and unfrozen layers will be extracted. All metadata remains unchanged, new point cloud object will be created on the current layer.
Command Prompt:
Use all clouds in view? or [Yes/No]: | This prompt is displayed when there are more than one point cloud in the viewport. |
Yes | Creates one point cloud that includes all visible points of all point clouds of the viewport. All points, which are invisible in active viewport, because they are outside viewport margins, will be also extracted. |
No | Displays the prompt: Select point clouds or [?]: Specify the cloud to be extracted or select the ?.option |
? | Displays the selection prompt: Select an option or [Window/Last/Crossing/Box/ALl/ Fence/WPolygon/CPolygon/Group/Add/Remove/Previous/AUto]: |
Info: NanoCAD is a user friendly, inexpensive, and yet powerful, CAD app for Windows, that delivers a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our software supports groundbreaking, collaborative and customizable features to improve your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and purchase later, in case you like it.
