Ribbon: Point Clouds – Clip and Section – Clip > Clip By 3 Points
Menu: Point Clouds – Clip > By Rectangle
Toolbar: Point Clouds > By Rectangle
Command line: NPC_CLIP_RECT_ROTATED
Create rectangle clip boundary by angle and two sides. Boundary is perpendicular to the view plane. The cloud is clipped perpendicular to the plane of the viewport in the view direction.
A cloud can be clipped in one viewport (source), with the result displayed in another viewport (target), specified by the user. When the clip result is displayed in the target viewport, the same view will be set that was in the original viewport during clipping operation.
Enter first base point: | Specify the first point of boundary. |
Enter second base point: | Specify the length of the first side. |
Enter diagonal point: | Specify the length of the second side. |
Select view: | Specify needed view to display the clip. |
Command clip only mapping of point cloud in the target view. The cloud remains unchanged in the rest of viewports.
Info: NanoCAD is a simple, cheap, and yet powerful, CAD app for PC, that delivers an outstanding user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industrial purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our program ensures creative, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
