Mechanical note
Ribbon: Home, Annotate – Leaders – Mechanical notes
Menu: Draw – Notes > Mechanical notes…
Toolbar: Utilities –
Command line: NOTE
This command opens the Mechanical note dialog box to set the mechanical note options:
Use the icons to add/remove text input fields and to add a border:
Add string. | |
Remove string. | |
Simple note. | |
Multiline note. |
Use the icons to select the style of the extension line:
None. | |
Arrow. | |
Point. | |
Open arrow. | |
Half-arrow. | |
Oblique. |
By left edge. | |
By center. | |
By right edge |
Other icons and options:
The Add extension line icon is used to insert additional extension lines. The icon is enabled when you edit a leader inserted into the drawing. |
To create a mechanical note:
1.Type the required text into the text fields.
2. Select the required leader options.
3. Click OK.
4. Specify a point on the object to which the leader arrow will be directed.
The following arrow type switching options are available in the command line and context menu:
- None – Creates the extension line without an arrow.
- Arrow – Creates the extension line with an arrow.
- Point – Creates the extension line with a point.
5. Select an option and specify the leader position on the drawing.
Info: NanoCAD is a user friendly, inexpensive, and yet professional, CAD freeware tool for personal computer, that delivers a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drafting and creating industry-standard DWG-compatible CAD files. Our program supports creative, collaborative and customizable features to boost your efficiency, and includes a number of API’s, allowing anything from routine task automation to complex CAD application development. You may try nanoCad for free, using the links below, and buy later, if you like it.
