Editing Text
Text objects can be edited like other objects: rotated, removed, copied etc.
If you are editing rotated texts – you can specify should be all drawing rotated or only edited text in Options – Text settings – Rotate text in edit mode.
If this option is tuned on – only text object will be rotated, otherwise all drawing will be rotated.
The properties of text objects can be changed in the Properties panel.
NOTE: It is only possible to change single-line text properties in the Properties panel.
