Group dimensioning
Ribbon: Home, Annotate – Dimensions > Group Dimension
Menu: Dimensions – Group dimension
Toolbar: Utilities –
Command line: QDIM, DIMGROUP
The Group dimension command is particularly useful for creating a series of vertical or horizontal dimensions.
To specify the group dimensions:
- Start the Auto command.
- Select the Grouped option in the command line or context menu.
- Select the objects you want to dimension:
- Press ENTER to end the selection of objects:
Depending on the direction of the cursor movement (vertical or horizontal), the chain of vertical or horizontal dimensions will be dynamically displayed. - Move the cursor to change the character from red to blue :
- Left click to specify the location of the dimension lines:
When dimensioning the objects that have a small length
The crossed arrows are automatically replaced by notches or points:
The setting for replacement of intersecting arrows is performed in the nanoCAD – Options dialog box (The Tools menu – Settings Parameters):
Info: NanoCAD is a user friendly, low cost, and yet professional, CAD platform for Windows, that allows a great user experience by providing high performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all industries. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D design and creating industry-standard DWG-compatible CAD files. Our freeware ensures groundbreaking, collaborative and customizable features to improve your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may download nanoCad for free, using the links below, and purchase later, if you like it.
