Removing speckle
Ribbon: Raster– Filters> Speckle Remover
Menu: Raster – Filters > Speckle Remover…
Command line: SPECKLEREMOVER
This functionality is available only in the Raster module.The filter removes raster objects (isolated groups of pixels), the size of which is less than the specified value, and automatically estimates the size of spots in the image. This filter can be used after binarization or separation procedures to remove small raster objects from the resulting monochrome layer images.
Fragment of a monochrome raster obtained as a result of binarization
After “speckle” removal
1. Select images to be processed and run the Speckle Remover command.
2. Enter the maximum size of raster objects to be deleted in the current units (left input field) or in points (right input field).
3. Or check the Auto estimating box to let the filter estimate the size of the raster “speckle” before filtering.
To measure the size of a raster object on the screen, click button and specify a point inside the object, or click button and specify two points on the screen. The program will set the “speckle” size equal to the distance between the specified points.
4. Click Apply.
Info: NanoCAD is a simple, inexpensive, and yet powerful, CAD freeware tool for Windows, that allows a great user experience by providing top-level performance, full capability, a classic interface and native.dwg format support. nanoCAD has been built to deliver design and project documentation for all engineering purposes. nanoCAD includes a full suite of basic and advanced CAD tools for 2D/3D drawing and creating industry-standard DWG-compatible CAD files. Our freeware supports progressive, collaborative and customizable features to enhance your efficiency, and includes a few API’s, allowing anything from routine task automation to complex CAD app development. You may try nanoCad for free, using the links below, and buy later, in case you like it.
